#3143146 - 04/06/16 03:26 PM
'07 Vic w/5-speed swap
Just like the caption says, I bought a 5-speed swapped Vic. Although I broke my tradition of buying $600 cars with this one, I am happy with the purchase. It's a 2007 Westerville (OH) cruiser and has the scuffs to prove it. The previous owner, a member here, installed the following goodies: -TR3650 -10.5" clutch -Pier's pedals -Modular Head Shop stage 2 cams -Kook's LT headers This combo allegedly makes 270WHP and 299TQ on a 93 octane tune. I will likely have this re-tuned in the next month (more on this later in the post) or so and see what they left on the table. Annnnyway, I brought it home yesterday and introduced it to the Marauder...  And the Marquis...  Today, I replaced a burnt-out taillight bulb and spent an hour getting the interior to a livable level...  Mechanically, there are some issues. I feel confident in some of them; not all of them: -tackle the grinding sound/feel in the right front wheel when I'm turning (wheel bearing?) -brakes all the way around - hoping for just pads - they squeal...bad. - (this is the big one) re-tune the car, have MIL eliminators installed, turn the rear O2s back on in the tune, and HOPE TO GOD this thing passes Ohio's E-check. (they won't even test it with a P1000 code, which currently surfaces any time the car is started) On the interior, the list is much shorter: -clean clean clean -fix the floor, shift boot, bezel, etc. It's...not right. Cosmetically: -who cares? It's a P71. All of that being said, this is a very solid car. Rowing your own is fun, but third gear pulls are downright intoxicating. Haters...hit me with your best shot.
#3143186 - 04/06/16 03:42 PM
Re: '07 Vic w/5-speed swap
[Re: a_d_a_m]
Insert witty title here
Loc: Chicago, IL
I'm jealous. Really jealous.
 2003 Crown Vic HPP- 226,xxx miles. Projector Retrofit. 3.27s. Dual exhaust. 11.25" torque converter. Arnott Limo Duty HPP-rate rear air springs. (Stolen by the old man) 1995 Impala SS- 28,293 miles. The Lovely Lady 2003 BMW 325i Sedan- 138,xxx miles. Eibach Springs, Bilstein shocks, polyurethane bushings, Projector Retrofitted lights, 330i brakes, 330i rear-end, 235/45/r17 Sport Comp 2s. Autocross machine. 2003 BMW 325i Wagon- 118,xxx miles. Eibach Springs, Koni Yellow shocks, M3 differential (LSD), M3 rear suspension/brakes, 330i front brakes, M3 6 Speed manual, Alcantara headliner. 2017 Mazda3 GT Hatchback- 57,xxxx miles. 2.5L, fully loaded. The Daily Grind.
#3143290 - 04/06/16 04:47 PM
[Re: a_d_a_m]
Loc: Who wants to know...
I like it, but my god does that thing need carpet, I hate the rubber floors. Otherwise most good.
And that does really need a tune. Manual swaps on these result in the computer freaking the hell out.
I try not to take things personally... Everyone's a person, how else are they supposed to take it? 'The portal to hell is opened with the incantation of good intentions'
#3143578 - 04/06/16 08:51 PM
[Re: a_d_a_m]
Once you get it legalized (Like what my car is currently going through) I'd go carpet and some center console.
Otherwise it's perfect.
#3143922 - 04/07/16 12:29 AM
[Re: a_d_a_m]
Loc: PA
Rotors are so cheap for this car, just do a full brake job, I'm sure with the level of maintenance the previous owner clearly put into this car, the rotors are below minimum thickness as it is. Make sure you do a full bleed to, just in case its still factory fluid.
MIL eliminators + a retune should work fine, Vince passed for years in NJ with no cats and MIL eliminators.
Ryan #22004 Mercury Mcgruber Eaton M112, 3.4 Billetflow upper, Accufab SBTB + Plenum, Tremec T-56 Magnum, 4.10's, Stainless Works LT's, 2.5" Exhaust W/ Borla Stingers, FX-R projectors, Addco F/R swaybars2003 Mercury Marauder Stainless Works LT's, Stainless Works catback, Mo's tune, JLT1996 Ford Bronco 4" lift, 35" BFG A/T's, MH1 projectors2000 BMW M5 Evolve CAI + AlphaN Tune, Dinan strut bar + rear swaybar, Stoptech ST40BBK, UUC Shifter2016 Ford Mustang GT Performance Pack
#3144026 - 04/07/16 01:19 AM
[Re: a_d_a_m]
Looks like a great little project Adam, keep the updates coming and good luck with it.
2008 P71 - Vortech V2-SQ, 3.4" pulley, 2nd cats removed - Sold 2013 Silverado 2500 6.0 4X4 - Sold 2017 Challenger 392
#3144066 - 04/07/16 01:38 AM
[Re: Ezbok58a]
EUTM
Loc: Michigan
Otherwise it's perfect. Nice looking P71 Adam. I second the need for carpet and a console. A Sport console shouldn't be too hard to find cheap at a junkyard. Swap that in kinda like JustBob has done with his manual Marauder.
 2004 DTR Marauder, tune, 4.10's, K and N intake, stainless bumper inserts, misc other mods CVN Panther of the Month December 2015 2004 Crown Victoria Sport, stock
#3144130 - 04/07/16 04:40 AM
[Re: 04RauderDTR]
I drove it around a bit here and there yesterday. My god, does this thing need rear control arms - I've never axle-hopped a Panther in wet weather before.  I have the old ones off the Marauder laying around, so I might try my hand at boxing a set instead of plunking down four bills for Heinous/Metco pieces. The wheel bearing is job #1. Since I got called in to work early, so I decided to spend my coffee hour researching the job. It should be in my skill-set, as long as there's no other issues in there. I've got a bearing on order; now I just need to order some motivation and nice weather. Rotors are so cheap for this car, just do a full brake job I might. But I did find a box of brand-new front pads in the garage...no idea where they came from, so...yeah. Gonna have the rotors turned (there's a ton of rotor left) and go that route first. MIL eliminators + a retune should work fine, Vince passed for years in NJ with no cats and MIL eliminators. That's what I'm hoping for. I want to get this car safe to roll down the road before I start in on emissions-related BS. To the people crying for a Sport/Marauder center console, let me repeat myself: I like the shifter coming straight out of the floor. I don't plan to change that.
#3144210 - 04/07/16 07:36 AM
[Re: a_d_a_m]
EUTM
Loc: Michigan
To the people crying for a Sport/Marauder center console, let me repeat myself: I like the shifter coming straight out of the floor. I don't plan to change that.  Didn't the Bandit Trans Am have a center console?
#3144226 - 04/07/16 08:19 AM
[Re: a_d_a_m]
#3144610 - 04/07/16 11:47 AM
[Re: a_d_a_m]
EUTM
Loc: Michigan
My point is, what's good enough for Bo Darville, is good enough for you, so you should get a console. And it makes it look less like the interior of a early 70s farm truck.
