#3130010 - 03/29/16 12:04 PM Best replacement watts link?
MasterofNone08 Offline
Loc: Idaho
Need to replace my watts link. I saw theres about 4 options on rockauto. Anyone know if one company used a stiffer material than the other? My luck I will buy the most flimsy one.
2008 P71. Aem drop in filter/180* Tstat. Small airbox "mod" OEM ported plenum/P&P 618 Jerrys OEM TB. Factory P71 tune FTW. flasher mod, rear bumper tuck, Fenix trunk security plates. Bendix-Police pads/rotors, moog poly bushings,tierods,endlinks. KYB Police-spec shocks- -ISO 21mm rearbar.. Sweet custom roof paint flake
1985 Mustang-Gt40/b303 HCI build. j&m LCA's, tokico illuminas, steeda kmember brace,JBA shorties+sve H pipe, slps, ignition stuf,blah blah blah other racecar stuff. Needs NX plate kit..
Volunteer FF tryhard
#3130026 - 03/29/16 12:27 PM Re: Best replacement watts link? [Re: MasterofNone08]
mdnos Offline
Loc: not here any longer
Metco, CHE but they will run you around $400 with shipping, but are the strongest
#3130194 - 03/29/16 02:58 PM Re: Best replacement watts link? [Re: MasterofNone08]
Merc1973 Offline
Loc: MI
You Can buy a Motorcraft one from ebay or Tasca for just over $200. I wouldn't buy anything cheaper than that.
Beware they now have Chinese bushings. I installed mine last month, time will tell.
[img]https://imgur.com/a/Y8I4i3r[/img]
2001 Grand Marquis GS, Tropic Green... MOD LIST:
17mm Sway bar, Bilstein shocks, ADTR Widened steel wheels, Tork Tech supercharger kit with m112 blower, 2.93 upper pulley, glowshift gauges, JMod, 2800 stall monster trans TC, BBK Longtube headers, aluminum driveshaft, 3.73 rar with LSD. 16 PSI screamer!
might know me on Discord as nowen97
#3130242 - 03/29/16 03:53 PM Re: Best replacement watts link? [Re: MasterofNone08]
Blackcvpi Offline
Cynical Jackass
Loc: Somewhere in the CRC
Rockauto has a Dorman replacement for less then 50 bucks. It is Chinese
Also as mentioned Metco. Thats what I have.
http://adtr.net/product/ford-crown-victoria/metco-billet-watts-link-98-whales/
#3298114 - 07/25/16 07:21 PM Re: Best replacement watts link? [Re: MasterofNone08]
PALEO Offline
Loc: Spicewood Texas, USA
I have 125,000 on it. I am replacing everything I guess. Dorman is the only one I can find. 60 bucks only. Somebody mentioned the stock watts link is a great make, but wouldnt mine be worn after those miles? Something about the name Dorman that scares me.Does moog make one?
turtle beat the rabbit=here I come
2000 CPVI with all new Moog Suspension, 17 by 8 wheels, 245/45/17 tires, PI intake manifold, granatelli ported plenum, 1/2 inch plenum spacer, Ford racing 70mm ported TB, Marauder air box/MAF, New plugs and MSD coils, flownasters, 3.55 gears, Marauder spoiler, Addco sway bars, Steeda underdrives, and a 93 LONNIE tune! 133,308 miles----learned a little----I need another
1993 Dodge D150/318 - 2003 Chevy Trailblazer LTZ - 1999 Chevy Tahoe LT-350 - 1981 Suzuki GS1100e
Born on Groundhog Day!
#3298378 - 07/25/16 11:34 PM Re: Best replacement watts link? [Re: MasterofNone08]
mdnos Offline
stock one is stamped steel..metco is billet aluminum..dpends on your goals for the car..stock works fine for what it is..
#3298634 - 07/26/16 11:31 AM Re: Best replacement watts link? [Re: MasterofNone08]
If you buy Dorman, it WILL be the flimsiest one...
Motorcraft is prolly the best overall value-for-money, where the Metco and CHE units are bullet-proof.
#3298714 - 07/26/16 01:00 PM Re: Best replacement watts link? [Re: MasterofNone08]
MEDCsean Offline
Loc: SoCal
as others have said, che, metco..
I run a custom MEDC watts..
If talking a OEM replacement, ford watts can be had on ebay, and sometimes on amazon.
09 P71: MEDC Coilovers & Suspension stuff, MEDC go fast stuff, MEDC chemical boost stuff..
04 P71: RACECAR.. huge displacement modular.. jerico.. custom suspension.. adjustable downforce..
MEDC "spherical all things"
find MEDC on instagram@MEDC_Sean
#3327265 - 08/21/16 12:43 PM Re: Best replacement watts link? [Re: MasterofNone08]
EZlivin11 Offline
Loc: Central Coast Of CA USA
I am looking for a HD bell crank for the watts link. Does anyone make such an animal? I find complete watts links, or just the arms, but no bell crank. I am going to try these, so I can adjust it. My only reservation is its straight, and I can not find any thing on why it is curved, other than clearance.
The Gray Ghost
AKA: The Murranator
IF It's Not Broke, It Must Be Time For An Upgrade
2008 Ford Crown Victoria P71 4.6-2v
Upgrades /Mo's /1/2ShaftTB /P&PIntake /Steeda /Steering /Brakes /Suspension /Driveline /Rear-Axle3.55TL /BodySuspension-EnergySuspension /Interior /LTC-Leather /200Amp-Powerdistrabution-System /AuxBattery /SonyBluetooth /
#3328593 - 08/22/16 06:59 PM Re: Best replacement watts link? [Re: MasterofNone08]
If you mean the arm bolted to the pumpkin, thats a rather robust cast iron piece. If you don't worry about pitman arms on pre-rack 'n pinion cars, then you got nothing to worry about. =-)
Alex.
#3328633 - 08/22/16 07:47 PM Re: Best replacement watts link? [Re: MasterofNone08]
EZlivin11 Offline
Here is hat I'm seeing
1st the watts arms are stamped flex-steel made for comfort not performance
2nd The CVPI is now lowered a bit, so the bell-crank is not centered anymore
3rd A lesson that You should never to forget, when you stiffen a chassis or suspension, the force from that area WILL be transmitted somewhere else... If you do not complete the processes form beginning to end of the path that that force travels, You will be chasing it till you do stiffen it start to finish. EX. If you firm up the front the force will move to the rear, so If you jump to the rear and firm up there, it will head back to the front to a point where it is or becomes lose so you firm it up there and back it goes and so on... That having been said the watts link is the last section in the rear suspension, and with the stamped arms I can feel the wrap up in a corner when those arms flex under pressure. I have the ARB bolt with oversized tubular arms, leaving the bell-crank bearing being the weak link left for the force to travel to, so it should be looked at for possible upgrade, or keep a spare on hand...
The Gray Ghost
AKA: The Murranator
#3329041 - 08/23/16 07:04 AM Re: Best replacement watts link? [Re: MasterofNone08]
chipdog4 Offline
Loc: SouthWest Indiana
Can't tell what diameter rod that is, but I'm sure it will still bend or break before the bell crank does.
99 LSE clone
#3329633 - 08/23/16 04:07 PM Re: Best replacement watts link? [Re: MasterofNone08]
EZlivin11 Offline
You have a point the strut rod is 3/4 od x 1/2 id.. it is a camber adjusting rod for a 90's Pontiac Grand prix, and I used it on a 95 SHO for rear control arms. Recycled engineering or as the American Pickers call it Repurposing. It will become a watts link, both arms are connected up, so after lunch I am going to begin measuring compression, drop, along with every moving plane in the rear suspension and insure there is not any binding.
The Gray Ghost
AKA: The Murranator
#3330377 - 08/24/16 06:23 AM Re: Best replacement watts link? [Re: MasterofNone08]
PALEO Offline
This is what I just got. It wasnt quiet as described. I dont like the way it looks. Looks like I could almost bend it with me. Its not a Dorman, I guess. I dont like it. Its on my car now. Maybe its ok with the Addco rear? It is from AM Auto parts?
Edited by PALEO (08/24/16 06:24 AM)
#3330985 - 08/24/16 05:04 PM Re: Best replacement watts link? [Re: EZlivin11]
Merc1973 Offline
Loc: MI
Nice, Are those a one off custom or available for purchase?
3 registered (Scuba_Steve, CarMon, alumarine), 108 Guests and 9 Spiders online.
