Page 16 of 24 < 1 2 14 15 16 17 18 23 24 >
#3197777 - 05/09/16 10:25 PM Re: Manual transmission for the crown vic [Re: 2004_p71]
Fordguy78 Offline
Loc: Minnesota
So on my 09 , I'm not super familiar with the vehical speed system, would I be able to just solder In a vss sensor to get the speedo reading? After a reflash would the pcm just ignore the speed input?
I MAY NOT KNOW IMORTANT THINGS, BUT I KNOW WHAT I AM TALKING ABOUT.....I THINK
#3198033 - 05/10/16 05:52 AM Re: Manual transmission for the crown vic [Re: Fordguy78]
Originally Posted By Fordguy78
So I under stand you sell pedals . what are my optikns for clutches like hydraulic or mechanical . I would love a hydraulic clutch but putting one on 3650 would be kinda hard wouldnt it ? Oh crud! What do you charge for pedals or can I use the set from a 04 or the newer 05?
Yes I do make and sell them smile
My kits are compatible with the stock cable system and the mcleod hydraulic system .
My pedals are going for 325$ shipped.
heres some more info about it
#3198041 - 05/10/16 05:53 AM Re: Manual transmission for the crown vic [Re: Black_Sunshine]
Originally Posted By Black_Sunshine
There aren't any pedals that you can just throw in. The '05+ gas pedal assembly is large. Pier has the pedal assembly down. If I were to go manual I wouldn't think twice about just getting one of his sets.
thank you smile
#3198049 - 05/10/16 05:55 AM Re: Manual transmission for the crown vic [Re: Fordguy78]
You alredy have a VSS (vehicule speed sensor) and the tr3650 has one too so it,s just a matter of splicing two wires.
#3199705 - 05/11/16 02:16 AM Re: Manual transmission for the crown vic [Re: 2004_p71]
Fordguy78 Offline
Loc: Minnesota
I see says the blind man.
#3199761 - 05/11/16 02:40 AM Re: Manual transmission for the crown vic [Re: Fordguy78]
Black_Sunshine Offline
As he picked up his hammer and saw.
75mm DBW TB
� hood ornament
� c-pillar emblems
� LS style body side moldings
CarDomain
Facebook
#3200161 - 05/11/16 01:20 PM Re: Manual transmission for the crown vic [Re: Black_Sunshine]
Chaplian Offline
Insert witty title here
Loc: Chicago, IL
Isn't it "As he waved his wooden leg"?
#3201569 - 05/12/16 09:36 AM Re: Manual transmission for the crown vic [Re: 2004_p71]
Fordguy78 Offline
Loc: Minnesota
Either witch way, its as clear as mud. Well I think its settled for me. As it goes the plans is
1. Tork tek and Eaton
2. 05ish five speed
3. Headers and exhaust.
#3201785 - 05/12/16 12:33 PM Re: Manual transmission for the crown vic [Re: 2004_p71]
BigNSlow Offline
Aussie powered
Loc:
FYI 05ish five speed uses hydraulic clutch setup and has a flange on the back of the tranny rather than a hole for a yoke.
Originally Posted By Ezbok58a
He runs a fake equipment install company just so he could run his vehicles with lights on them, and his hobbies include running motorcycles off the road, terrorizing civilians in Walmart parking lots, handing out pamphlets on Open Carry, backing into parked cars and then blaming it on the parked car, securing perimeters, getting into conflicts that no rational person gets into, and helping stranded motorists...
I'm sure I'm missing some but that's techno as we know him...
#3258914 - 06/23/16 02:23 PM Re: Manual transmission for the crown vic [Re: 2004_p71]
PantherForever Offline
Loc: Chicago, il
If starting with a 03+ MGM what parts are needed for the manual swap in addition to the following:
1. transmission (most likely tr3650)
2. clutch components (clutch, flywheel, bearings, cabling)
3. Pier's pedal system
4. XCT tuner for installing computer changes to accept new trans
Is any work required to the stock steel driveshaft to allow it to mate to the new transmission?
Does anyone sell the clutch kit as single package?
The impetus for these questions is to generate an average cost sheet for performing the conversion which hopefully be helpful not just for me but also others contemplating the conversion themselves.
#3391561 - 10/10/16 12:48 PM Re: Manual transmission for the crown vic [Re: 2004_p71]
BigNSlow Offline
Aussie powered
Loc:
So here is a question for those with 5 speeds. Have you guys broken anything yet?
I think I cracked my transmission tailshaft housing. I took my car up to 110 mph and felt a bit of driveline vibration. When I got home I noticed a strong smell of tranny fluid. Next morning I found a small puddle of fluid under the car. Upon closer inspection I couldn't determine the source. There was fluid drops hanging off the crossmember where the tranny mount is but no other visible leaks. What are the chances the housing is cracked somewhere near the tranny mount?
#3391601 - 10/10/16 01:05 PM Re: Manual transmission for the crown vic [Re: 2004_p71]
Other than the syncros of the third gear doing stupid burnouts nothing was broken on any of the trans I installed and god know how much abuse it seen behind the 5.4.
One thing I always do is I use new shaft and they are installed by a shop who balance the whole drive shaft .
#3413801 - 10/27/16 01:29 PM Re: Manual transmission for the crown vic [Re: 2004_p71]
mechanic58 Offline
Loc: North Carolina
Fixin to start a TR3650 swap on my '06 LX. Just picked up all the parts today. I got a good used trans, clutch, flywheel, shifter and the correct driveshaft yoke and a mustang pedal assembly all for $475. I plan to make my own pedal assembly using parts off the Mustang setup. Can't wait to get this going. My car already has all the P71 suspension parts on it and a 3.55 gear and some other goodies. The 5-speed should really make it a blast to drive. I'm excited!
2006 Crown Victoria LX
Complete P71 running gear and suspension
Duals with 40 series Flowmasters
3.55s w/tracloc
Home grown SCT tune
#3413849 - 10/27/16 01:52 PM Re: Manual transmission for the crown vic [Re: 2004_p71]
cool let us know how it goes
#3413953 - 10/27/16 03:15 PM Re: Manual transmission for the crown vic [Re: 2004_p71]
Ross413 Offline
Loc: SE PA USA
5-speed is the most fun I have had in this car. Almost 30 auto-x events so far and still having a blast.
Thanks Ross
2004 P71 Fleet
3 registered (hot__box, Bangster, 1 invisible), 96 Guests and 338 Spiders online.
bluejay_32 161
a_d_a_m 106
Old_Guy_Stu 101
Rainbowpizza 37
