#343894 - 01/13/04 01:47 AM Progress...
Flavio Offline
I changed the spark plugs, the rotor, the distribution cap and the wires and the car run smoothly now and has a faster pick up , Hopefully it will consume a smaller amount of gas (not like 16 gallons of fuels in 60 miles). What do you think ??
All Stock <img src="/ubbthreads/images/graemlins/banana.gif" alt="" />
<img src="/ubbthreads/images/graemlins/usaflag1.gif" alt="" />[b]F[b]ix [b]O[b]r [b]R[b]epair [b]D[b]aily<img src="/ubbthreads/images/graemlins/usaflag1.gif" alt="" />
"My name is Rick James B!tch"
#343895 - 01/13/04 01:57 AM Re: Progress...
Petely Offline
Loc: Chicago, IL
We hope that but that is a lot of gas (just under 4mi/gal). I suspect a leak.
Peter
1987 Mercury Grand Marquis
*sold to some guy on cvn for $1
New Long List of Rules Compliant Sig
#343896 - 01/13/04 01:59 AM Re: Progress...
Flavio Offline
hmmm.... I looked under the car and there is no sign of leaking though... where else should I check ???
#343897 - 01/13/04 02:04 AM Re: Progress...
Petely Offline
Loc: Chicago, IL
Well, I suppose drive it and see if the symptoms persist. The fuel line runs along the drivers side of the car. Look for any damp areas or smell of gas. I would also be thinking about oxygen sensors, temp sensor, or maybe MAP sensor but I would wait to see if the problem persists as the sensors are not cheap.
Peter
#343898 - 01/13/04 02:10 AM Re: Progress...
Flavio Offline
Thanks for all the help Pete
#343899 - 01/13/04 02:12 AM Re: Progress...
moneypit Offline
mine was doing about that bad. check the fuel press. regulator. does it idle ok?
Shameless plug:
www.ventureonline.org
Give us money!!!
#343900 - 01/13/04 02:14 AM Re: Progress...
Flavio Offline
now its doing better though, atleast it doesnt shake... when you adjusted the fuel press. regulator did it work fine ???
#343901 - 01/13/04 02:16 AM Re: Progress...
moneypit Offline
i replaced it. (a.k.a.: pain in the @$$)
pull the vaccuum line off of the regulator while the car's idling and see if any gas comes out of the regulator.
Shameless plug:
Give us money!!!
#343902 - 01/13/04 02:17 AM Re: Progress...
Petely Offline
Loc: Chicago, IL
The stock fuel pressure regulator is non adjustable. It should be about 30 - 35 psi. If it is much higher or lower then you have a problem either with the regulator or pump.
Peter
#343903 - 01/13/04 02:22 AM Re: Progress...
Flavio Offline
Another funny thing though I found an unplugged hose in the middle of the engine and it psses right next to the spark plugs on the left side and goes all the way to the right front of the car and joins with some other hose around there, I dont know what is that hose from
#343904 - 01/13/04 02:25 AM Re: Progress...
Petely Offline
Loc: Chicago, IL
Describe it. It could be the breather hose for the oil filler.
Peter
#343905 - 01/13/04 02:30 AM Re: Progress...
Flavio Offline
ok, its just a hose which my dad found right under the Valve cover (I guess). Its where on the top says Ford 5.0 EFI it has a space right under it and thats where my dad found that hose
#343906 - 01/13/04 02:32 AM Re: Progress...
moneypit Offline
could be the hose to the fp regulator which would explain the craptastic mileage. is it red?
Shameless plug:
Give us money!!!
#343907 - 01/13/04 02:33 AM Re: Progress...
Flavio Offline
nope, its a black hose
#343908 - 01/13/04 03:11 AM Re: Progress...
Flavio Offline
Hey people thanks for all the tips, Ill keep you posted on the progress of the Vic. Have a goodnight and take care
4 registered (professorP7B, hot__box, Old_Guy_Stu, 1 invisible), 48 Guests and 246 Spiders online.
bluejay_32 161
a_d_a_m 106
Rainbowpizza 36
