#3717346 - 08/23/17 01:01 PM AC System totaled
Rainyp71 Offline
Loc: North Carolina, USA
Hey guys, need some input.
My AC system is totaled and is circulating giant black chunks through the system which are clogging the orfice tube. Thoughts on me replacing the entire system myself? I've looked around and its going to be 2 grand to get someone to do it for me.
Any input would be great!
Thanks
2000 P71 Crown Vic former Gordonsville, VA Police Wrecked @ 200,199 Miles - All fixed! Currently 250,000 Miles
GMAX As-05 tires, 3.55 gears, Ford 28 spline limited slip w/ carbon clutches, upgraded trans cooler, custom trunk false floor, autometer tach, Sony Double DIN Head Unit, KYBs all around.
#3717362 - 08/23/17 01:35 PM Re: AC System totaled [Re: Rainyp71]
Rootintootin Offline
Loc: North Carolina
I'd say find an HVAC course at your local community college, and enroll yourself in one of their adult continuing education courses. You could use your car as a class project. Get to learn what to do under close supervision, use their tools without having to lay out a bunch of cash and have your car rehabbed for next year. Also, you could get a certificate to do this for pay, if you like it and get good at it.
Or lay out the bucks for your own tools, spend a lot of time learning what to do on your own. It's not too difficult. Do your studying up front, determine what tools you need, and do the job at your own schedule when you are ready. Sell the expensive stuff after the job is done and the final cost is not very much at all.
Not that it matters at this stage, but since a lot of this comes down to what year (or era) your car is. It would be a good idea to put your year and model in your signature. It helps narrow down the advice you get.
97 CVPI, 145K miles
#3717386 - 08/23/17 03:10 PM Re: AC System totaled [Re: Rainyp71]
Replacing the parts isn't complicated. Just make sure you flush whatever isn't replaced thoroughly, especially parts that might trap debris and be cost/time prohibitive to replace like the evaporator core. What I would do is replace what needs replaced, flush what needs flushed, and take it to an AC shop for the evac and recharge. The last step is critical and difficult to do without expensive AC tools, so its worth it (to me anyway) to pay it done.
#3717498 - 08/23/17 05:02 PM Re: AC System totaled [Re: BigMerc96]
Rainyp71 Offline
Thanks for the input. Unfortunately I'm not going to go maybe a semester without AC. It's hot out here! And all my info is in my sig, just press click to reveal wink
Thanks for the input. My fathers thought was to let someone do the system so maybe I get a warranty, but I doubt anyone is going to warranty their work. I could do the whole thing myself for 700 for the parts. It be 2,000 anywhere else. All I have to do is get someplace to empty and recharge it. I can flush the evaporator core myself I believe, it's 30 bucks for the tool and 16 for the solvent so I don see why I wouldn't do it myself.
Edited by Rainyp71 (08/23/17 05:03 PM)
#3718546 - 08/25/17 08:04 AM Re: AC System totaled [Re: Rainyp71]
Rainyp71 Offline
Update: Did plenty of research. Doing it myself. Going to get it evacuated in a week or so as parts come in. I ordered:
1. Ford Racing AC Compressor delete (So I can still drive it with the entire system removed to allow exact matching of parts)
2. 8oz of PAG46 spec oil
3. 6 12oz cans of DuPont Suva r134a (need 38oz)
4. Kitchen scale to weigh r134a and measuring glass for oil
5. r134a gauge set
6. r134a can tap
7. Ford and GM A/C, trans, and fuel line disconnect kit
The plan as of now is to get the system evacuated then remove the compressor and install the delete bracket. At that point, I'll then remove the entire system - the evap core and reassemble it in the shop to understand how everything is put together for the new part install. I then plan on ordering:
Motorcraft compressor and clutch kit
Motorcraft condensor
Motorcraft evap Core
Motorcraft orfice tube
Motorcraft Drier/accumulator
All 3 Motorcraft lines
Motorcraft compressor manifold lines
Motorcraft pressure sensors
Four Seasons blend door actuator
GPD seal kit
Once I'm sure I have everything ready to go I'll pull the dash and yank the evap core, replace it, then remove the compressor delete bracket and install everything with 7oz of oil. Then pull a vacuum and add r134a.
I will do my best to document this.
Edited by Rainyp71 (08/25/17 08:05 AM)
#3718554 - 08/25/17 08:11 AM Re: AC System totaled [Re: Rainyp71]
If you are changing the blend door actuator, get the Motorcraft part. Not a job you want to do twice. My experience with aftermarket BDA is that it'll fail in a few months and you'll be changing it again.
#3718570 - 08/25/17 08:30 AM Re: AC System totaled [Re: BigMerc96]
Rainyp71 Offline
Great, thanks for the info! Do you have a part number for a 2000 crown vic with manual A/c? Also, before I make another thread, is there anything else I need besides the BDA to make it a full repair? I'm seeing two types of actuators on Rockauto.
#3718586 - 08/25/17 08:47 AM Re: AC System totaled [Re: Rainyp71]
The actuators for EATC and manual look almost identical, but they are not interchangeable.
#3719226 - 08/25/17 08:39 PM Re: AC System totaled [Re: RF_Overlord]
Rainyp71 Offline
I am aware of that, but I am seeing something that looks amis to an internal turbo wastegate. Is the only part I need the BDA?
Sorry for the confusion!
#3719594 - 08/26/17 08:59 AM Re: AC System totaled [Re: Rainyp71]
That's what the vacuum motors look like. You want this one.
Unfortunately it looks like Rock doesn't have the Motorcraft one for manual control, only the EATC version.
#3719826 - 08/26/17 03:43 PM Re: AC System totaled [Re: RF_Overlord]
Rainyp71 Offline
GREAT! Thanks man! I'm sure I can find a Motorcraft part number through the fordparts site. And sorry for all the questions, but what does the vacuum motor do?
#3719866 - 08/26/17 04:27 PM Re: AC System totaled [Re: Rainyp71]
The vacuum motors are exactly what their name implies, well, the other name they go by anyway, vacuum solenoid. When vacuum is applied/removed they push/pull a linkage. The mode doors (vent/floor/defrost and recirc) all operate by vacuum motors. You rarely hear of them failing unless the car is very old because a vacuum motor is about the simplest mechanism there is.
#3719962 - 08/26/17 09:42 PM Re: AC System totaled [Re: BigMerc96]
Rainyp71 Offline
Thanks man! Now I've just got to decide if I wanna mess with it or not.
#3720274 - 08/27/17 09:44 AM Re: AC System totaled [Re: Rainyp71]
PJC Offline
Loc: Nottingham, PA
I have gotten OEM Ford Blend Door Actuators from Amazon
2002 MGM LSE 107k Arizona Beige Metallic, HPP, 3.27 rear, Floor shifter and console, basically stock
1998 Dodge Dakota 5.2L 4x4 164k
#3720306 - 08/27/17 10:02 AM Re: AC System totaled [Re: Rainyp71]
Rainyp71 Offline
Anyone got a part number? Having difficulty finding the manual version.
5 registered (derekghs, 01boatman, tc092, Dmblanch, Becker34), 64 Guests and 102 Spiders online.
JeffBoudah 81
Armada Master 74
Old_Guy_Stu 72
Moby_Vic 65
Dmblanch 56
a_d_a_m 44
SocalSam 43
Ponyguy 42
