#3781034 - 11/05/17 12:35 AM
ac only works after running for a while
Loc: Florida
I have a Crown Vic, 2003, LX. When I start up car, AC doesn't work - just regular air comes out. But after I drive a while and then sit at an intersection idling, the AC kicks on. Any ideas on what might be causing this issue or any suggestions on what can be done to fix it?
Thanks for any help.
#3781146 - 11/05/17 08:40 AM
Re: ac only works after running for a while
[Re: andrew55]
I would not bet it being low on refrigerant, once low the compressor continually cycles and won't cool very well...
I've had a flakey low pressure cause delayed start up, someone on here had issues with the compressor relay doing same... A inoperative cooling fan can do same but engine should be running hot...
1998 Grand Marquis LS. 96K mi. .. Stock 2007 Grand Marquis GS. 90K mi. .. Stock 1996 F-150 XLT 196K mi Beater, Stock ---------- My Toys--------- (links are up)1969 Fairlane Cobra 428CJ 4-Speed 1972 Comet GT Restomod 306, C4 1988 Turbo Coupe 331 AOD & 3.73 .. Pressurized ½ Motor is History *****************NEW TOY!!!*********************1969 Base Fairlane 302, C4, 45K mi(really!) Now with P/S & PDB Gonna wake it up with a Blue Print headed 347
#3781330 - 11/05/17 11:20 AM
[Re: andrew55]
Loc: Florida
I will check the refrigerant pressure.
It's strange though, once the engine is nice and hot, the AC blows cold air just fine.
2 registered (Svtmedic, DudeAbides),
96
281
