#3887450 - 02/24/18 01:24 AM
PI black trunk panel on a CVLX
Would the PI (any year) black trunk panels be a bolt on replacement on an 04 LX?
05 Crown Victoria ADTR Coil overs, ADTR sway bars, Ford Racing 3.55s + Yukon Duragrip Posi.
#3887458 - 02/24/18 01:30 AM
Re: PI black trunk panel on a CVLX
[Re: SMVic__]
Loc: Timbuk3, MI
#3889018 - 02/26/18 10:45 AM
[Re: SMVic__]
Loc: Erie, PA
100% direct replacement, however often times the studs will tend to want to stay on the trunk and unscrew from the panel, rather than the nuts coming off. This is fine.....you just have to remove the stud from the replacement panel in that location.
******Need your heater core replaced? Click Here****** -'99 Crown Vic Police Interceptor (SAP), 3.55 Trac-Loc(DK), Cloth Interior, Black Honeycomb Grill, Black PI Trunk Bezel, Silverstars, 183K-'00 Crown Vic Police Interceptor (SAP), 3.55 (R2), Cloth Interior, Black PI Trunk Bezel, 03+ Full Wheel Covers, Silverstars, 115K-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior, Smokestone Metallic, 96K / 249 Hrs-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior, Black, 133K / 1643 Hrs-'08 Crown Vic Police Interceptor (SAP), 3.27, Cloth Interior w/ Carpet, Norsea Blue, 157K / 597 Hrs-'07 F-150 4x4 - Extended Cab, 3.55's, White w/ Grey interior, 167K-'14 Fusion S - 160K
#3889034 - 02/26/18 11:23 AM
[Re: SMVic__]
Loc: Broken Arrow, OK
You might seek out a 2011 LX rear panel. They are hi-gloss black with the chrome strip on the bottom. I have that on my car.
'06 P71. Fake S.A.P. '15 F250 FX4 ‘14 Mustang GT '07 Charger Work car '97 P71 SOLD
#3889194 - 02/26/18 01:47 PM
[Re: juzza]
You might seek out a 2011 LX rear panel. They are hi-gloss black with the chrome strip on the bottom. I have that on my car. Also found on 1998 Police Interceptors. '98 P71s also had a chrome grille and chrome bumper inserts, it wasn't until '99 that they lost the chrome, makes them easy to spot. Not sure why they reverted to the black panel on the '11s, probably cheaper than painting them for the final run of what was by then a mostly fleet-only vehicle.
#3889322 - 02/26/18 03:20 PM
[Re: BigMerc96]
Loc: Erie, PA
You might seek out a 2011 LX rear panel. They are hi-gloss black with the chrome strip on the bottom. I have that on my car. Also found on 1998 Police Interceptors. '98 P71s also had a chrome grille and chrome bumper inserts, it wasn't until '99 that they lost the chrome, makes them easy to spot. Not sure why they reverted to the black panel on the '11s, probably cheaper than painting them for the final run of what was by then a mostly fleet-only vehicle. The reason for this is a lack of availability on the painted panels from their vendor. It is mentioned in the 2011 ordering guide. The "ICE BLUE" color was the first to have issues.
#3889722 - 02/26/18 07:10 PM
[Re: SMVic__]
Modern Day Pirate Fighter
Loc: Virginia Beach, VA, USA
Anyone have the part number for the PI version?
 2003 Crown Vic Sport.
#3890186 - 02/27/18 08:27 AM
[Re: SMVic__]
Loc: Minnesota
I swapped one onto a 04 MGM, it'll fit yours
2004 MGM - Ice Blue - Tastefully Modded Former Panther: 2006 Interceptor - POTM - March 2013 - Mods: Drivetrain: 2nd CAT delete, Summit Racing mufflers, ported/polished plenum and TB, Transmission J-Mod and upgraded internals, Summit Racing underdrives, Ford Racing 3.73s, BOC 87 Octane Tune, 170 degree T-Stat, Brake Motive drilled and slotted rotors, PowerStop ceramic pads. Best ET: 15.05 @ 91.15 MPH, not bad for bolt-on's  Exterior: Tinted windows, Mustang GT Premium wheels - black w/ aluminum caps and Nitto NT450's (255 front, 275 rear), Lowered 1.25" all four corners, S55 black tail lights, blacked out headlights and corners, fog lights, Mach 1 chin spoiler. Other Rides: 2008 F350 King Ranch CCLB DRW - 6.4L Diesel, Deleted, Tuned, Exhaust 1984 Olds Cutlass - 468 Big Block Olds 1984 Ford Bronco II - trail and camping rig!
