#3891866 - 03/01/18 09:31 AM Cleveland - Check Air Suspension
JoeSapien Offline
Loc: Solon, OH
2009 Mercury Grand Marquis with 40k miles
Check Air Suspension warning light came on. I also noticed that the sound that I heard when I started the car (probably air compressor?) has stopped.
The rear of the car seems to be sitting low but I am not sure about it.
Can someone recommend a reliable mechanic for helping solve this problem?
Thanks for your advice.
#3892210 - 03/01/18 01:40 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Welcome from Painesville.
Not sure what your mechanical ability is, but if you can jack the car up and look underneath, sometimes the little arm that acts as an air ride sensor comes unhooked. It looks like this:
Happened on my Marauder and has happened to others as well.
I was thinking of moving this to Suspension but, if what I suggested above doesn't pan out and you just wanna pay to have it fixed...Regional would work.
#3892602 - 03/01/18 06:22 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
Thank you from Solon.
Unfortunately, my mechanical ability is poor. I will see if there is someone who can help me with jacking up the car and taking a peek.
What do you mean by, Regional? I don't understand.
Edited by JoeSapien (03/01/18 06:27 PM)
#3893066 - 03/02/18 07:42 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Ignore what I said...I didn't notice you'd posted the same question in the Suspension forum.
#3893082 - 03/02/18 08:13 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
JoeSapien Offline
Loc: Solon, OH
Good morning,
The mechanic says that it may require replacing the air bag suspension with a coil suspension. He suspects that the air compressor may have gone bad.
Total repair estimate is $534 with Monroe coil suspension. Is the estimate fair? Is Monroe coil suspension good? If not, which coil suspension would you recommend.
#3893098 - 03/02/18 08:45 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
I assume he ruled out the ride height sensor? Your compressor won't make a peep if it is disconnected.
Either way, you do not need to replace the air suspension system entirely. If it truly is the compressor, Arnott makes a replacement for $222.80.
Overall, the ride height system is rather dependable.
#3893130 - 03/02/18 08:54 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
PJC Offline
Loc: Nottingham, PA
Good morning,
$534 is a lot of money to take out the air bags and put coils in. If you're mechanically inclined google your model and "check air suspension" there are many helpful threads on the subject. Not sure about the 2009 but there should be a relay under the hood that could be bad.
2002 MGM LSE 107k Arizona Beige Metallic, HPP, 3.27 rear, Floor shifter and console, basically stock
1998 Dodge Dakota 5.2L 4x4 164k
#3893138 - 03/02/18 08:57 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Chaplian Offline
Insert witty title here
Loc: Chicago, IL
Good morning,
If he can't diagnose the air bag system, I wouldn't want him working on it.
These systems are actually fairly simple and incredibly reliable. My Crown Vic has 225k on its air suspension, and the only 2 things replaced so far are the rear air bags, and a compressor (which I suspect wasn't needed, just replaced it because it was getting noisy.)
Do NOT convert it to coils. The car will give you an error message on your dash saying the air suspension is faulty. Plus, to fix your issue, it will be cheaper than converting to coils, and you'll maintain your great ride. Converting to coils does worsen the ride.
Might be time to find someone else to work on your car who is familiar with the rear air suspension, or find a local CVNer who is willing to help.
Also, that price is a complete and total ripoff.
#3893402 - 03/02/18 12:41 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
JoeSapien Offline
Loc: Solon, OH
Thank you for the responses.
How do I go about finding a local CVNer who might be willing to help troubleshoot and/or fix this problem for a price?
#3893418 - 03/02/18 12:43 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
No, he has not inspected the MGM yet, therefore has not ruled out the ride height system.
My usual mechanic told me that he is not interested in this job because of the complexity. One other mechanic told me something along the same line. So, its been a bit discouraging. Fortunately, I have an old backup car to use, therefore I am not pressed for time.
Edited by JoeSapien (03/02/18 12:47 PM)
#3893458 - 03/02/18 12:48 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
I can't believe I missed this but...
Did you check the switch in your trunk to make sure it is turned to the 'ON' position?
#3893482 - 03/02/18 12:56 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
Yes, it is turned to the ON position.
#3893514 - 03/02/18 01:08 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Are you (and a friend/family member) able to jack up the ass end of the car at all? Not sure what your situation or abilities are and definitely not trying to ask super-personal questions.
Anyway, if you can, I can try to explain how to check the sensor. It's...painfully easy once the car is up.
Edited by a_d_a_m (03/02/18 01:09 PM)
#3893586 - 03/02/18 01:26 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
I will jack up the car! No, I won't get offended if you ask super personal questions.
I have a hydraulic jack. I used it about 15 years back! I just have to make sure that I place the jack properly. Hope I don't have to crawl underneath the car, never done that.
Edited by JoeSapien (03/02/18 01:28 PM)
#3893594 - 03/02/18 01:31 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Please, USE JACK STANDS when lifting a car! If you don't have some, head over to a Harbor Freight and spend $30-40 on a pair. laugh
You do not have to crawl under the car to jack it up, but you do have to crawl under the car to check the sensor.
There are jack points marked on your rocker panel covers (the plastic bits underneath your doors on each side). Look for the little arrow marks...those are jack points.
Really surprises me that you're experiencing resistance on this job from mechanics. If it was truly the compressor, it's not a hard fix:
2 registered (Armada Master, RF_Overlord), 42 Guests and 79 Spiders online.
bluejay_32 111
JeffBoudah 81
Moby_Vic 73
Old_Guy_Stu 71
Armada Master 67
Dmblanch 50
DudeAbides 50
a_d_a_m 47
SocalSam 42
