#3891866 - 03/01/18 09:31 AM Cleveland - Check Air Suspension
JoeSapien Offline
Loc: Solon, OH
2009 Mercury Grand Marquis with 40k miles
Check Air Suspension warning light came on. I also noticed that the sound that I heard when I started the car (probably air compressor?) has stopped.
The rear of the car seems to be sitting low but I am not sure about it.
Can someone recommend a reliable mechanic for helping solve this problem?
Thanks for your advice.
#3892210 - 03/01/18 01:40 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Welcome from Painesville.
Not sure what your mechanical ability is, but if you can jack the car up and look underneath, sometimes the little arm that acts as an air ride sensor comes unhooked. It looks like this:
Happened on my Marauder and has happened to others as well.
I was thinking of moving this to Suspension but, if what I suggested above doesn't pan out and you just wanna pay to have it fixed...Regional would work.
#3892602 - 03/01/18 06:22 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
Thank you from Solon.
Unfortunately, my mechanical ability is poor. I will see if there is someone who can help me with jacking up the car and taking a peek.
What do you mean by, Regional? I don't understand.
Edited by JoeSapien (03/01/18 06:27 PM)
#3893066 - 03/02/18 07:42 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Ignore what I said...I didn't notice you'd posted the same question in the Suspension forum.
#3893082 - 03/02/18 08:13 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
JoeSapien Offline
Loc: Solon, OH
Good morning,
The mechanic says that it may require replacing the air bag suspension with a coil suspension. He suspects that the air compressor may have gone bad.
Total repair estimate is $534 with Monroe coil suspension. Is the estimate fair? Is Monroe coil suspension good? If not, which coil suspension would you recommend.
#3893098 - 03/02/18 08:45 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
I assume he ruled out the ride height sensor? Your compressor won't make a peep if it is disconnected.
Either way, you do not need to replace the air suspension system entirely. If it truly is the compressor, Arnott makes a replacement for $222.80.
Overall, the ride height system is rather dependable.
#3893130 - 03/02/18 08:54 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
PJC Offline
Loc: Nottingham, PA
Good morning,
$534 is a lot of money to take out the air bags and put coils in. If you're mechanically inclined google your model and "check air suspension" there are many helpful threads on the subject. Not sure about the 2009 but there should be a relay under the hood that could be bad.
2002 MGM LSE 107k Arizona Beige Metallic, HPP, 3.27 rear, Floor shifter and console, basically stock
1998 Dodge Dakota 5.2L 4x4 164k
#3893138 - 03/02/18 08:57 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Chaplian Offline
Insert witty title here
Loc: Chicago, IL
Good morning,
If he can't diagnose the air bag system, I wouldn't want him working on it.
These systems are actually fairly simple and incredibly reliable. My Crown Vic has 225k on its air suspension, and the only 2 things replaced so far are the rear air bags, and a compressor (which I suspect wasn't needed, just replaced it because it was getting noisy.)
Do NOT convert it to coils. The car will give you an error message on your dash saying the air suspension is faulty. Plus, to fix your issue, it will be cheaper than converting to coils, and you'll maintain your great ride. Converting to coils does worsen the ride.
Might be time to find someone else to work on your car who is familiar with the rear air suspension, or find a local CVNer who is willing to help.
Also, that price is a complete and total ripoff.
#3893402 - 03/02/18 12:41 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
JoeSapien Offline
Loc: Solon, OH
Thank you for the responses.
How do I go about finding a local CVNer who might be willing to help troubleshoot and/or fix this problem for a price?
#3893418 - 03/02/18 12:43 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
No, he has not inspected the MGM yet, therefore has not ruled out the ride height system.
My usual mechanic told me that he is not interested in this job because of the complexity. One other mechanic told me something along the same line. So, its been a bit discouraging. Fortunately, I have an old backup car to use, therefore I am not pressed for time.
Edited by JoeSapien (03/02/18 12:47 PM)
#3893458 - 03/02/18 12:48 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
I can't believe I missed this but...
Did you check the switch in your trunk to make sure it is turned to the 'ON' position?
#3893482 - 03/02/18 12:56 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
Yes, it is turned to the ON position.
#3893514 - 03/02/18 01:08 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Are you (and a friend/family member) able to jack up the ass end of the car at all? Not sure what your situation or abilities are and definitely not trying to ask super-personal questions.
Anyway, if you can, I can try to explain how to check the sensor. It's...painfully easy once the car is up.
Edited by a_d_a_m (03/02/18 01:09 PM)
#3893586 - 03/02/18 01:26 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
I will jack up the car! No, I won't get offended if you ask super personal questions.
I have a hydraulic jack. I used it about 15 years back! I just have to make sure that I place the jack properly. Hope I don't have to crawl underneath the car, never done that.
Edited by JoeSapien (03/02/18 01:28 PM)
#3893594 - 03/02/18 01:31 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Please, USE JACK STANDS when lifting a car! If you don't have some, head over to a Harbor Freight and spend $30-40 on a pair. laugh
You do not have to crawl under the car to jack it up, but you do have to crawl under the car to check the sensor.
There are jack points marked on your rocker panel covers (the plastic bits underneath your doors on each side). Look for the little arrow marks...those are jack points.
Really surprises me that you're experiencing resistance on this job from mechanics. If it was truly the compressor, it's not a hard fix:
#3894114 - 03/02/18 08:43 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
I have a tendency to get my shoulder dislocated, so I do not want to take a chance by crawling under the car.
The two mechanics who refused to take Mercury Grand Marquis work have been in the business for more than a decade. In my opinion, they are skilled and trustworthy but they refused to touch my Mercury Grand Marquis.
The installation of the air compressor, as shown in the video, does require multiple but uncomplicated repair work. I don't understand their reaction. Maybe they just want to work easier work.
The mechanic who quoted $534 for installation of the coil system is charging for 3.5 hours of labor.
#3894138 - 03/02/18 08:58 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
I have no idea what my schedule, or the weather, will be like on Monday.
However, if you're free during the day (like, before 2pm) on Monday and my schedule works out and it's DRY AND NOT CRAPPY...I might be willing to drive down to Solon and throw it up in the air.
Unfortunately, I won't probably know much about my schedule until Sunday evening, so there's that.
#3894562 - 03/03/18 10:21 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
PJC Offline
Loc: Nottingham, PA
3.5 hrs must include a 2 hr lunch break. lol
#3894938 - 03/03/18 07:59 PM Re: Cleveland - Check Air Suspension [Re: PJC]
JoeSapien Offline
Loc: Solon, OH
What is a reasonable labor time for this job?
#3894946 - 03/03/18 08:08 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
I would be very grateful to have you look at my car. My schedule is flexible and am available on most days.
According to weather dot com, high temperature is 39 degrees, mostly sunny, zero percent chance of precipitation, wind at 5 mph.
I have messaged you my phone number and address.
Edited by JoeSapien (03/03/18 08:17 PM)
#3895306 - 03/04/18 03:50 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
I'll drop you a PM here shortly...
#3896114 - 03/05/18 12:01 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
road_pizza Offline
R.I.P.
Loc: somewhere east of Laramie...
IMHO your regular mechanic is a chickensh!t. RAS is a very simple system to diag and repair as opposed to the 4 wheel systems. If it needs a comp. Ford MSRP is $698.08 but I cut CVN'ers a break, I can sell you one for $523.56, I'll get back to you with labor when service gets back to me. I work in parts at Ganley Lincoln over here in Middleburg Hts.
2018 F150 XLT
2005 P71, the Beast gone but not forgotten
1978 Fairmont, the Ugly Box
1985 Marquis LTS, the Unicorn
2011 Road Glide Ultra, the Winnebago
#3896306 - 03/05/18 02:59 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
It doesn’t need anything.
Working fine upon arrival.
Think it was just a fluke. Car is clean and bags are mint.
#3896402 - 03/05/18 04:37 PM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
Thank you very much a_d_a_m. You are very kind. It was a honor to meet you today. Very happy to hear the good comments about the RAS of my MGM.
#3896466 - 03/05/18 06:09 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Should be good for many more miles. mercury
#3896826 - 03/05/18 10:15 PM Re: Cleveland - Check Air Suspension [Re: road_pizza]
Apologies for my brevity earlier; was posting from my phone.
Joe, if you ever need a Ford-specific part, this is an incredibly solid lead:
I also trusted their service department with a lighting control module recall.
Couple other thoughts per our earlier discussion:
1. Synthetic blend oil is currently on sale at Federated through April 30th. 6 quarts of 5w-20 runs $14.47 plus tax (buy a big 5qt jug + 1 loose quart). Federated doesn't sell Motorcraft or Purolator filters, but I've had good luck with the Hastings brand, which they DO sell.
2. Long's Oil Spray
808 S. Diamond St.
Ravenna, OH 44266
(330) 839-8604
#3897906 - 03/07/18 07:02 AM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
2. Long's Oil Spray
808 S. Diamond St.
Ravenna, OH 44266
(330) 839-8604
I don't think I am going to take my cars to Lube Stop for oil changes anymore. If you had not told me that they had installed oil filter that's not the standard for my MGM, I wouldn't have known about it.
Thanks very much for recommending the oil spray, I have a friend who does this for his cars but I didnt want to impose on him because of his age. So, I am happy to know about Long's Oil Spray. Much obliged.
#3902082 - 03/11/18 09:46 PM Re: Cleveland - Check Air Suspension [Re: Chaplian]
JoeSapien Offline
Loc: Solon, OH
Good morning,
Liberty Ford in Solon quoted a rate of $129/hour to to diagnose the air bag system.
#3935074 - 04/22/18 10:19 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
JoeSapien Offline
Loc: Solon, OH
Today, the check air suspension light came on, again. The compressor is not kicking on. So, the suspension worked well for about 100 miles.
I also noted that the sound from the compressor (when it was working) was a little off. Any ideas or suggestions?
#3935090 - 04/22/18 10:45 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
TenTwelve Offline
Loc: Lyndhurst,Ohio
Just replace it all with coils and new shocks. I just did yesterday. Although I used springs that lowered it the ride really hasn't degraded.
2001 LX Sport T-45 with Pier's pedals, Ford Racing Intake Manifold, Marauder MAF and airbox, MO's tune, Thrush glasspacks, Marauder seats, Marauder cluster, Mustang 19" wheels. Sitting lower on cut P71 springs up front and GT500 performance pack springs in the rear.
#3935754 - 04/23/18 07:42 AM Re: Cleveland - Check Air Suspension [Re: TenTwelve]
JoeSapien Offline
Loc: Solon, OH
Which brand coils and shocks did you use?
#3936018 - 04/23/18 02:03 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
I'm not a fan of coil conversions. That is not to say I haven't done them, but the air suspension setup is just better in several ways. If you do convert it to coils, please, do not just chop up the lines and wiring like whoever converted my Town Car did, made putting the air ride back in it more of an journey than it should have been. Whenever I do them, I simply unplug things and disconnect the lines and zip tie them up out of the way, takes maybe an extra 10 minutes, but would save a ton of time if you ever decide to put it back.
My preference is to use OEM springs from a coil sprung car. The ones that come with the "conversion kits" are too $$ and the 2 I've experienced have been too harsh. Before I put the air ride back in my Town Car, I swapped out the coil conversion springs for a set of factory coils from a CV, those rode 100x better, tho they did sag with the extra weight of a Town Car so it sat a bit low.
#3936042 - 04/23/18 02:18 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
2kGM Offline
Loc: NW Virginia, USA
My opinion: If you really want the minimum-cost solution, coils will get you there. If you ever plan to do anything like put lots of heavy stuff in the trunk or tow, fix the air suspension.
I got rid of a GS and replaced it with an LS HPP because I wanted the stiffer suspension and RAS. Wouldn't ever go back.
1999 Grand Marquis LS HPP with PI intake manifold, mild J-mod, Class III hitch, KYB PI shocks.
2000 Grand Marquis GS with no options and mild J-mod - Sold to Father-in-law
#3936610 - 04/24/18 07:15 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
JoeSapien Offline
Loc: Solon, OH
If anyone knows a skilled forum member, within 200 miles of Cleveland, who is willing to do the conversion for me, please let me know. I would be happy to pay for this favor.
I have a severe problem with my shoulder so I can't do this work myself. Further, i just don't have the knowledge or skills.
Edited by JoeSapien (04/24/18 07:45 AM)
#3937282 - 04/25/18 07:59 AM Re: Cleveland - Check Air Suspension [Re: 2kGM]
JoeSapien Offline
Loc: Solon, OH
The sixth mechanic I contacted, after five refusals, took the job. Going forward with the conversion, could not deal with the unreliability of the air suspension.
#3937418 - 04/25/18 11:43 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
mdnos Offline
Loc: not here any longer
Cancel that appt...tell them something came up and go see/call John Grimm at the Alinement Shop in Tallmadge/Akron, OH Family run business, been going to them for ovr 30 years.. All they do is alignment, suspension and brake work., He'll fix the air suspension. does sit all the time, caddys, linconlns etc/ 5
star google rating
330-633-4696
Edited by mdnos (04/25/18 11:46 AM)
#3937546 - 04/25/18 05:10 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Just seeing this now...sorry you're having issues again. System looked really good from what I could tell, so I have to believe it's a fixable thing. But hey, do what ya feel and switch to coils if you want.
#3938050 - 04/26/18 07:52 AM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
You are absolutely right Adam. My situation has also changed a bit and I had no choice since several mechanics refused to troubleshoot the air suspension.
#3944994 - 05/04/18 04:48 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
JoeSapien Offline
Loc: Solon, OH
Wanted to share my experience with the conversion. Is there a difference? Yes there is. Air suspension was better than coil and springs. I would guesstimate that the difference is about 15%. I am okay with the loss of air suspension but in my case, I gained reliability.
One silly question, I want to check the coolant in my 2009 MGM, where is the radiator coolant tank located?
#3993042 - 09/06/18 09:38 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
stalag Offline
Loc: Columbus, OH
This system is easy to fix.
Go to Arnot for the parts. I would get a pair of air springs, the solenoids should be replaced as PM as well. Your compressor is also bad from having been overworked. Get that as well. Replacement of air ride springs is very easy. Also the air compressor lives under the air filter box. Remove the air tube and air box to get to the compressor underneath. your biggest issue would be corroded bolts. you may need to cut out the old rusted bolts and replace with new. make sure you get an air drier with the compressor. There are writeups here on this site that have step by step instructions. with a couple of jacks, hand tools, and some patience one can do this job easily.
#3993046 - 09/06/18 10:32 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
He hasn't logged in since making his last post and already converted. I doubt he'll be back, or change back to air.
5 registered (dixiebandit69, TheShadow, lance54r, Dmblanch, derekghs), 85 Guests and 111 Spiders online.
bluejay_32 102
Armada Master 92
JeffBoudah 86
Old_Guy_Stu 80
Moby_Vic 57
Dmblanch 55
SocalSam 50
a_d_a_m 50
jmlock 48
DudeAbides 43
