#392514 - 03/06/04 07:29 PM H4 Headlight Conversion Install- DUW
Cowman Offline
The allmighty Cow
Loc: Cheese Land
Finally getting something that can light up the road, and more importantly help me avoid getting blinded by oncoming traffic with newer brighter lights!
To do this, I popped the emergency release valve open to keep the headlight doors open. Here are a couple shots of the old lights on and off.
Note the water I found in the old "sealed" beam light
Here's one of the new lenses
Installation of the low beams are simple as could be. Old bulbs are held in by metal rings, remove 3 screws and the ring/old light comes out. The rubber seal pops off the lense, you unlatch a latch, pop in the H4 bulb, then latch it and reinstall the seal. The connectors for the low-beam sealed beams and the H4 are identical so they plug right in. Installation of the new lense is kinda harder because the rubber seal is very big and doesn't fit easily into the old housings however with a little pushing it all goes together with little trouble.
Here's a pic of the new low-beam and the old high beam side by side.
The high beam install is a bit harder since the connectors don't match up. Also, the high beam lenses take an H1 bulb. This isn't too difficult either though. All I had to do was pop the spade connector/wires out of the plastic harness and hook them up to the new high beam. Same issue with the big rubber seals..
Here's what it looks like installed
And I hook the headlight door valve up and give the car a quick wash and here she is.
More pics will come tonight when I try them out after dark.
The pessimist looks at government and says "This is awful, we can't possibly do any worse", the optimist replies "Yes, we can".
They don't make 'em like they used to..
Interested in a REAL Full-Size car? Try The Classics Forum
#392515 - 03/06/04 09:10 PM Re: H4 Headlight Conversion Install- DUW
Cowman Offline
The allmighty Cow
Loc: Cheese Land
Looks like I may need a relay kit now. Seems that the new lights draw a lot more power than the old ones did and with the hi-beams on the circuit breaker trips and I become a classic police impersonator with neat blinking headlights.
#392516 - 03/06/04 09:29 PM Re: H4 Headlight Conversion Install- DUW
Dextrovic Offline
Loc:
Looks nice!
Upgrading the headlight wiring with larger gauge wiring and relays is a very good idea...the headlights will work more reliably (esp. with the headlight switch only working the relays themselves--not the bulbs) and the lights will be brighter to boot w/ less circuit resistance.
#392517 - 03/08/04 02:59 PM Re: H4 Headlight Conversion Install- DUW
Dondo Offline
Loc: Clearwater, Florida
uh-huh,, yup,, guess your right,,, need relays to make dim headlights work right !! Wish I had of known that a while ago,, ah huh !!
1997CV-P71,3:27rear gears,Scanguage,hella 2020 model fog/driving lights, Lincoln Town Car seats front and rear,Crossed drilled and slotted rotors all round.
Moderator:  RF_Overlord
3 registered (TheNarrator, Armada Master, RF_Overlord), 50 Guests and 86 Spiders online.
bluejay_32 117
Moby_Vic 82
JeffBoudah 76
Old_Guy_Stu 72
Armada Master 50
Dmblanch 45
a_d_a_m 44
DudeAbides 42
Ponyguy 42
SocalSam 34
