#3953441 - 05/14/18 10:39 PM 1977 Lincoln Cont. Headlamp covers not working
ParkLane41 Offline
Loc: TN
Hello,
I have a 1977 Lincoln Continental Mark V and I am having issues with the headlamp covers. When I turn the lights on, the covers do not automatically flip up. I have to open the hood and swap the vacuum lines for them to open and flip them back for them to close. (the light themselves turn on and off with the switch)
I'm wondering if there is a module I need to replace that will allow the lids to open and close automatically.
Let me know your thoughts. Thank you!
2004 Grand Marquis GS Park Lane. 101K miles. Arizona Beige with maroon vinyl 1/2 top.
#3953473 - 05/14/18 10:53 PM Re: 1977 Lincoln Cont. Headlamp covers not working [Re: ParkLane41]
a_d_a_m Online   drunk
Since they work when you switch the lines, I have to believe the issues is merely with the vacuum lines that affect the closing of the doors. There's probably a leak. It may be time consuming, but finding vacuum leaks is at least easier than chasing electrical gremlins...so...count your blessings there.
'91 LTD Country Squire (POTM Mar. '19) | '03 Marauder (POTM Nov. '10, Jul. '20) | 2010 P7B
formerly: '02 MGM, '04 MGM, '04 MGM v2.0, '04 MM, '07 P71 (POTM Feb. '18), '04 CVLX (POTM Jun. '19), '03 SAP P71
#3953553 - 05/15/18 01:17 AM Re: 1977 Lincoln Cont. Headlamp covers not working [Re: ParkLane41]
ParkLane41 Offline
Loc: TN
I had figured since the vacuum trick works, then the problem must be in the module or whatever it is that electronically flips the switch that controls the vacuum lines to raise and lower the lids.
#3953585 - 05/15/18 03:14 AM Re: 1977 Lincoln Cont. Headlamp covers not working [Re: ParkLane41]
Ponyguy Offline
Loc: Oswego, IL
I once owned a 1968 and a 1969 LTD Brougham with those "Hideaway Headlights" and they were vacuum nightmare. The 1969 had a manual rotary "switch" to disengage the vacuum and leave the covers open.
Like Adam suggested, it's likely a cracked or split in the vacuum tubing somewhere... especially with tubing that is probably 40 years old. Hopefully, it's the tubing (which is replaceable) and not a vacuum diaphragm which might not.
Good luck!
Sig removed. Read the rules.
My transportation sources:
Moderator:  BigNSlow, RF_Overlord
2 registered (HavocMan, TinyTim), 92 Guests and 251 Spiders online.
bluejay_32 190
BigMerc96 75
ClayBelt 67
a_d_a_m 66
Old_Guy_Stu 63
Ponyguy 62
TheCableGuy 56
Moby_Vic 54
RF_Overlord 37
Psxmoe 36
