Page 3 of 3 < 1 2 3
#3935754 - 04/23/18 07:42 AM Re: Cleveland - Check Air Suspension [Re: TenTwelve]
JoeSapien Offline
Loc: Solon, OH
Originally Posted By TenTwelve
Just replace it all with coils and new shocks. I just did yesterday. Although I used springs that lowered it the ride really hasn't degraded.
Which brand coils and shocks did you use?
#3936018 - 04/23/18 02:03 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
I'm not a fan of coil conversions. That is not to say I haven't done them, but the air suspension setup is just better in several ways. If you do convert it to coils, please, do not just chop up the lines and wiring like whoever converted my Town Car did, made putting the air ride back in it more of an journey than it should have been. Whenever I do them, I simply unplug things and disconnect the lines and zip tie them up out of the way, takes maybe an extra 10 minutes, but would save a ton of time if you ever decide to put it back.
My preference is to use OEM springs from a coil sprung car. The ones that come with the "conversion kits" are too $$ and the 2 I've experienced have been too harsh. Before I put the air ride back in my Town Car, I swapped out the coil conversion springs for a set of factory coils from a CV, those rode 100x better, tho they did sag with the extra weight of a Town Car so it sat a bit low.
#3936042 - 04/23/18 02:18 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
2kGM Offline
Loc: NW Virginia, USA
My opinion: If you really want the minimum-cost solution, coils will get you there. If you ever plan to do anything like put lots of heavy stuff in the trunk or tow, fix the air suspension.
I got rid of a GS and replaced it with an LS HPP because I wanted the stiffer suspension and RAS. Wouldn't ever go back.
1999 Grand Marquis LS HPP with PI intake manifold, mild J-mod, Class III hitch, KYB PI shocks.
2000 Grand Marquis GS with no options and mild J-mod - Sold to Father-in-law
#3936610 - 04/24/18 07:15 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
JoeSapien Offline
Loc: Solon, OH
If anyone knows a skilled forum member, within 200 miles of Cleveland, who is willing to do the conversion for me, please let me know. I would be happy to pay for this favor.
I have a severe problem with my shoulder so I can't do this work myself. Further, i just don't have the knowledge or skills.
Edited by JoeSapien (04/24/18 07:45 AM)
#3937282 - 04/25/18 07:59 AM Re: Cleveland - Check Air Suspension [Re: 2kGM]
JoeSapien Offline
Loc: Solon, OH
The sixth mechanic I contacted, after five refusals, took the job. Going forward with the conversion, could not deal with the unreliability of the air suspension.
#3937418 - 04/25/18 11:43 AM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
mdnos Offline
Loc: not here any longer
Cancel that appt...tell them something came up and go see/call John Grimm at the Alinement Shop in Tallmadge/Akron, OH Family run business, been going to them for ovr 30 years.. All they do is alignment, suspension and brake work., He'll fix the air suspension. does sit all the time, caddys, linconlns etc/ 5
star google rating
330-633-4696
Edited by mdnos (04/25/18 11:46 AM)
#3937546 - 04/25/18 05:10 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
Just seeing this now...sorry you're having issues again. System looked really good from what I could tell, so I have to believe it's a fixable thing. But hey, do what ya feel and switch to coils if you want.
#3938050 - 04/26/18 07:52 AM Re: Cleveland - Check Air Suspension [Re: a_d_a_m]
JoeSapien Offline
Loc: Solon, OH
You are absolutely right Adam. My situation has also changed a bit and I had no choice since several mechanics refused to troubleshoot the air suspension.
#3944994 - 05/04/18 04:48 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
JoeSapien Offline
Loc: Solon, OH
Wanted to share my experience with the conversion. Is there a difference? Yes there is. Air suspension was better than coil and springs. I would guesstimate that the difference is about 15%. I am okay with the loss of air suspension but in my case, I gained reliability.
One silly question, I want to check the coolant in my 2009 MGM, where is the radiator coolant tank located?
#3993042 - 09/06/18 09:38 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
stalag Offline
Loc: Columbus, OH
This system is easy to fix.
Go to Arnot for the parts. I would get a pair of air springs, the solenoids should be replaced as PM as well. Your compressor is also bad from having been overworked. Get that as well. Replacement of air ride springs is very easy. Also the air compressor lives under the air filter box. Remove the air tube and air box to get to the compressor underneath. your biggest issue would be corroded bolts. you may need to cut out the old rusted bolts and replace with new. make sure you get an air drier with the compressor. There are writeups here on this site that have step by step instructions. with a couple of jacks, hand tools, and some patience one can do this job easily.
#3993046 - 09/06/18 10:32 PM Re: Cleveland - Check Air Suspension [Re: JoeSapien]
He hasn't logged in since making his last post and already converted. I doubt he'll be back, or change back to air.
Page 3 of 3 < 1 2 3
5 registered (bluejay_32, SocalSam, Armada Master, bobb, 1 invisible), 50 Guests and 100 Spiders online.
bluejay_32 112
JeffBoudah 82
Armada Master 73
Moby_Vic 73
Old_Guy_Stu 71
Dmblanch 50
DudeAbides 50
a_d_a_m 47
SocalSam 42
