#4015220 - 05/24/19 10:11 AM Inspect your shift cable under the car!
Former85Owner Offline
Loc: Albany, NY
Mine snapped in the drive position. Lucky I have a good parking brake! Can't start it either unless you move the linkage, and it take a bit of oomph from under the car, since it is behind the cat.
It was hanging on by a thread, all rusted out. A new one is $50 and i replaced the column bushings too.
The maintenance schedule DOES say to lube this part every oil change or so. There is an exposed brass shackle. So it is best to coat it in axle grease.
I don't care to lube the new one, the old one lasted 20years and the car will be gone by then.
The nut had to be ground down with with those Dremel sanding drums.
Edited by Former85Owner (05/24/19 10:12 AM)
98 MGM LS, Tan, Fully loaded but Non HPP (Original Owner didn't like the ride frown ). 177K miles. Dorman Intake, KYB Gas Adjust. Added: Heated Seats, Heated Mirrors, voice visor Homelink, 02B02 fuel tank shield
Former: 85 White Box, 205K miles, Jumped time. RIP 8/8/2000.
Allergic to Car Payments
#4015222 - 05/24/19 10:29 AM Re: Inspect your shift cable under the car! [Re: Former85Owner]
2007CrownVic Offline
I had this happen on my Yukon last year. I was checking the transmission fluid and bam the shifter started free styling back and forth without shifting anything. The end at the transmission disentegrated into white powder. Luckily it was in park.
#4015226 - 05/24/19 11:46 AM Re: Inspect your shift cable under the car! [Re: Former85Owner]
AlexPanther Offline
Isn't the shift cable protected by some kind of plastic/rubber sheath? How would you be able to lubricate it?
My car:
2000 Mercury Grand Marquis GS - 121,000 Miles. Dual Exhaust, MSD COP's [Pre-Chinese ones, made in El Paso Texas], PI Intake Manifold and Brian's Headlight Relay Kit.
#4015234 - 05/24/19 12:57 PM Re: Inspect your shift cable under the car! [Re: Former85Owner]
My 2000 was on the lift getting a parking brake cable replaced. The actuator lever had seized so the cable snapped. Anyway, when the mechanic went to back the car off the lift, the shift cable snapped, right where it attaches to the shift arm on the transmission. It basically rusted in half. Fortunately, the shop was able to get a new one that day and put it all back together.
#4015284 - 05/24/19 05:34 PM Re: Inspect your shift cable under the car! [Re: RF_Overlord]
Loc: Albany, NY
Yep, same problem on mine.
#4015286 - 05/24/19 05:34 PM Re: Inspect your shift cable under the car! [Re: AlexPanther]
Loc: Albany, NY
Just the metal eyelet and bolt. That is what rusted. Nothing moves but just protection from the elements.
#4015306 - 05/24/19 08:22 PM Re: Inspect your shift cable under the car! [Re: Former85Owner]
bluejay_32 Offline
Loc: wny
I've had a couple in the shop for that.
CVN POTM - February 2019 joy
#4070298 - 07/10/20 12:34 PM Re: Inspect your shift cable under the car! [Re: Former85Owner]
Pnasty Offline
Loc: Warren, Ohio
I know it's an old thread, but could anyone point me in the right direction to find a new shift cable for an 03 Marquis? Not having any luck locating one. Thanks in advance
"Stranger Things Have Happened"
#4070308 - 07/10/20 02:39 PM Re: Inspect your shift cable under the car! [Re: Former85Owner]
#4070350 - 07/10/20 10:55 PM Re: Inspect your shift cable under the car! [Re: Former85Owner]
Pnasty Offline
Loc: Warren, Ohio
Thank you
2 registered (Danger2manifold, Bobert2647), 82 Guests and 115 Spiders online.
bluejay_32 103
Old_Guy_Stu 99
Dmblanch 73
a_d_a_m 59
RF_Overlord 46
GM_Guy 45
Moby_Vic 37
Ponyguy 34
SocalSam 33
Tenevic_P71 33
