#4025700 - 08/02/19 08:24 PM Instrument Cluster Wiring
Candi0830 Offline
Loc: Nebraska
My husband was removing the dash's instrument cluster from his 2008 Police Interceptor in an attempt to diagnose the flickering and shutting off gauges/cluster lights. He was hoping to find a bad solder or loose wire, neither of which he found. He then began to try cleaning all the connections and he managed to pull a wire from the 32 pin connector and doesn't know where it came from. Here are a couple pictures of the remaining wires along with the black and yellow one next to it that is needing its proper placement. Anyone have a wiring diagram or a picture of their own cluster wires to help us out? [img]https://scontent-den4-1.xx.fbcdn.net/v/t...amp;oe=5DA0E49D[/img] [img]https://scontent-den4-1.xx.fbcdn.net/v/t...amp;oe=5DD45032[/img]
#4025702 - 08/02/19 08:30 PM Re: Instrument Cluster Wiring [Re: Candi0830]
bluejay_32 Online   content
Loc: wny
Black/Yellow is Pin 12. Green is Pin 1. Same side, fifth slot from the other end.
CVN POTM - February 2019 joy
Originally Posted By JeffBoudah
That's about as savage as buttered white bread.
#4025706 - 08/02/19 08:36 PM Re: Instrument Cluster Wiring [Re: bluejay_32]
Candi0830 Offline
Loc: Nebraska
Fantastic. Happen to know which light that wire controls?
#4025708 - 08/02/19 08:43 PM Re: Instrument Cluster Wiring [Re: Candi0830]
Bangster Online   content
Check out the article pined here for the odometer issue! oops reading comprehension issue, it isn't the odometer it is the backlighting
Spent too long adding points and text:
2008 CV INSTR by dabangsta, on Flickr
This one shows what the wire/pin is for:
2010 Crown Victoria Instrument Cluster 2 by dabangsta, on Flickr
And just to help make sure, this is another one with other wires to that connector:
2010 Crown Victoria Instrument Cluster 1 by dabangsta, on Flickr
Edited by Bangster (08/02/19 08:51 PM)
#4025710 - 08/02/19 08:49 PM Re: Instrument Cluster Wiring [Re: Candi0830]
Candi0830 Offline
Loc: Nebraska
Thank you so much!
#4025716 - 08/02/19 09:20 PM Re: Instrument Cluster Wiring [Re: Candi0830]
Candi0830 Offline
Loc: Nebraska
Now all the lights work when it does flicker on. Think he is going to send it in for repair. Can't seem to pinpoint the loose connection. Thanks for your help. He bet me a night out with a fancy dinner if I could get him the answer! Lol
#4025724 - 08/02/19 11:04 PM Re: Instrument Cluster Wiring [Re: Candi0830]
Loc: wny
The dim/flickering odometer is a common problem. Bad solder joints on the circuitboard.
https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=3052074#Post3052074
4 registered (bluejay_32, xohnnyraddox, 2004_p71, Bangster), 81 Guests and 290 Spiders online.
CrystalPistol 343
bluejay_32 314
a_d_a_m 230
Rainbowpizza 165
DudeAbides 149
JeffBoudah 117
Moby_Vic 108
Old_Guy_Stu 80
BigNSlow 71
Bangster 62
