Page 2 of 3 < 1 2 3 >
#4016614 - 06/02/19 05:47 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Knight_Stalker Offline
Loc: Florida
ok, thanks. still trying to find the right one.
2007 Norcea Blue Police Interceptor
Various mods
#4016616 - 06/02/19 05:50 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Loc: Florida
so I am also assuming that you didn't use the spacer gasket with the air turbulence deal in the center with this setup...you just used a regular tb gasket and that's it. mine has a thick spacer gasket that has like fingers or something in the middle to affect the air going in.
Various mods
#4016688 - 06/03/19 01:43 AM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
ClayBelt Offline
Loc: Leon County
You have to use the thick plastic space gasket with this basically. I just used a regular gasket as a template, if I ever pull the throttle body off to port it I’ll take photos.
#4016726 - 06/03/19 01:35 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Loc: Florida
gotcha. thanks! now to try to find the right one. you don't have a part number on yours do you?
Various mods
#4016728 - 06/03/19 01:35 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Loc: Florida
Various mods
#4016798 - 06/03/19 11:57 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
ClayBelt Offline
Loc: Leon County
I do not
#4016808 - 06/04/19 01:04 AM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Loc: Florida
ok, thanks.
Various mods
#4016924 - 06/04/19 10:50 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Loc: Florida
anybody else possibly have a part number? thanks.
Various mods
#4016992 - 06/05/19 03:25 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
ClayBelt Offline
Loc: Leon County
Knight stalker, now that I think about it I’m 95% sure rock Auto has the factory part number in their listings
#4017032 - 06/05/19 10:09 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Loc: Florida
will check it out.thanks!!!
Various mods
#4017064 - 06/06/19 12:24 AM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Loc: Florida
so, per Rock Auto, for the 2003-2006 lincoln ls 3.9l v8 or the thunderbird, these are the oem numbers:
3W4Z9E926AC, 3W4Z9E926AD
assume these are the ones to look for unless I am looking at the wrong years.
Various mods
#4017086 - 06/06/19 07:24 AM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
ClayBelt Offline
Loc: Leon County
Those numbers look about right if I’m recalling what was faded on the sticker on mine.
#4017142 - 06/06/19 04:38 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Loc: Florida
from rock auto, here are some pics. looks like yours.
Various mods
#4030452 - 09/13/19 03:06 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
Prospect62 Offline
CVN 10 Year
Loc: Central New York
I'm in the middle of this right now. Seems like the OEM gasket/spacer thingy with the weird "teeth" in it would create a restriction - not from the "teeth" but more of a port mismatch. You can upgrade the size of your TB all day but if the gasket hole is still 65mm you're gonna have a port mismatch.
Took me getting halfway through this job to realize that any gains from an increased size TB will be negated by the stock size of the gasket everyone is reusing.
I think I may try to use the gasket for the Lincoln, provided I can make new holes in it without butchering it.
Edited by Prospect62 (09/13/19 03:59 PM)
2008 CVPI Nevada Highway Patrol Unit 08-271
ADTR Ported Plenum, 618Jerrys ported & polished TB, 4.10 gears (w/Trac-Lok)
21mm Rear Sway Bar, Thrush Welded Mufflers, Marty Ochs/SCT Tune
#4030478 - 09/13/19 07:17 PM Re: LS Swap 2009 Crown Vic... [Re: ClayBelt]
You could also just get the gasket made for a '96-'04 Panther, or even Ford Truck for that matter... Its just the old style paper gasket, but the center bore is the same not-quite-70mm-but-close-enough as the stock plenum and the 70mm truck TB us non-DBW guys use. That gasket should be easily found at most parts stores because it was used on many different Ford models from the late '80s-'00s.
1 registered (John396), 74 Guests and 227 Spiders online.
CrystalPistol 334
bluejay_32 319
a_d_a_m 221
Rainbowpizza 156
DudeAbides 143
JeffBoudah 116
Moby_Vic 99
Old_Guy_Stu 81
BigNSlow 67
Ponyguy 64
