Page 4 of 7 < 1 2 3 4 5 6 7 >
#4033306 - 10/05/19 11:20 AM Re: 2004 CVLX [Re: a_d_a_m]
"Build" is being very generous with this car.
#4033326 - 10/05/19 03:15 PM Re: 2004 CVLX [Re: a_d_a_m]
AndyMarkV Offline
Loc: Upstate NY
Haha!! I hear you, but I stand by my statement. I love stuff like this!
My friends & I have had expensive cars and dirt cheap cars, but a lot of the FUN is similar to build either.
Dirt cheap budget builds make you think really hard how to get the maximum for zero-to-minimal dollars.
I'd have already had the buffer on the paint of this car to 1) improve my correction/scratch repair skills with zero concern of damage if I made a mistake 2) experiment if really damaged paint is even repairable (I've been very surprised what Presta Ultra Cutting Creme & wool pad on a rotary can do to completely dead paint)
I'd also be in the junkyard for a P71 intake & complete axle assembly with gears deeper than 2.73. (at my yard the cost would be $100 for both)
Ebay for a dirt cheap unlocked SCT X3 ($75-100) & then Marty tune ($150)
Of course all of this is not counting the value of your labor...
But if you were willing to fight with an exhaust manifold that rotted in half....obviously you ain't afraid of a little hard work!!!
Edited by AndyMarkV (10/05/19 04:41 PM)
#4038608 - 12/03/19 09:09 AM Re: 2004 CVLX [Re: a_d_a_m]
Got some free parts from a pal. Lipstick on a pig - engine cover edition:
Also tried my hand at smoking headlights and was surprised that they came out better than the picture indicates. Unfortunately, upon install, the cheapo housings have such terrible fit and finish that they look crooked AND won't aim properly. They're so bad that I might go back to the hazed over stockers.
#4038610 - 12/03/19 10:34 AM Re: 2004 CVLX [Re: a_d_a_m]
Old_Guy_Stu Offline
Fixing hazed headlights is pretty easy. Rubbing compound and elbow grease. Toothpaste works if you don't have compound.
Still nicer than the $1100 PI I saw at the Pick-a-Part lot.
#4038612 - 12/03/19 10:51 AM Re: 2004 CVLX [Re: a_d_a_m]
Oh, I've tried every trick in the book with the old housings. Gone so far as to sand them and try to polish them out with rubbing compound. They are atrocious.
#4038782 - 12/04/19 05:42 PM Re: 2004 CVLX [Re: a_d_a_m]
Can you swap the adjustment/mounting hardware over from the old housings? I've seen a few where that got them to fit properly. The smoked lights turned out good. Its relatively easy to do. But why no projector retrofit while you had em out? That's just another 10 minutes of work once they're already open. Can be done for less than half what you paid for the car, so no need to worry about increasing its value too much.
#4038996 - 12/06/19 07:13 PM Re: 2004 CVLX [Re: BigMerc96]
That's an idea. I hadn't even considered it.
That is entirely too much work and money to put into this car. The smoked headlights cost me maybe $15, since I had to buy a new X-acto Knife to replace the one I lost.
#4039052 - 12/06/19 11:47 PM Re: 2004 CVLX [Re: a_d_a_m]
x2 on re using the oem headlights hardware.
probably gonna give them a try too for my 04
comming back this fall
#4039072 - 12/07/19 07:01 AM Re: 2004 CVLX [Re: a_d_a_m]
Old_Guy_Stu Offline
I bet the original hardware is too rusty to adjust.
EDIT: Now I've got Johnnie Cochran yelling in my head: "They is too much rust, you can't adjust!" If I have to hear it, so do you.
Edited by Old_Guy_Stu (12/07/19 07:12 AM)
#4039078 - 12/07/19 07:52 AM Re: 2004 CVLX [Re: Old_Guy_Stu]
Me, putting gloves on before working on a filthy Panther.
#4039668 - 12/13/19 01:37 PM Re: 2004 CVLX [Re: a_d_a_m]
D’OH!
Time to buy some fiberglass!
#4039686 - 12/13/19 03:37 PM Re: 2004 CVLX [Re: a_d_a_m]
Old_Guy_Stu Offline
Well that looks like fun.
#4039698 - 12/13/19 05:11 PM Re: 2004 CVLX [Re: a_d_a_m]
Bah. Lemme know when you can see the full width of both rear tires from inside the trunk.
#4039740 - 12/14/19 07:57 AM Re: 2004 CVLX [Re: a_d_a_m]
I won't let it get that far.
Gonna 'glass it on Sunday if I have the energy after work. If I can make it last through this winter, I'll consider it a major win...and probably send it to pasture afterward.
#4039748 - 12/14/19 10:04 AM Re: 2004 CVLX [Re: a_d_a_m]
Old_Guy_Stu Offline
It'll last thru the winter as long as the fuel tank doesn't fall out. Looks like the anchor points are still semi-solid.
2 registered (TheShadow, 1 invisible), 56 Guests and 108 Spiders online.
bluejay_32 108
JeffBoudah 74
Moby_Vic 73
Old_Guy_Stu 70
Armada Master 54
DudeAbides 50
Dmblanch 47
Ponyguy 44
SocalSam 40
