Page 4 of 4 < 1 2 3 4
#4042198 - 01/04/20 10:54 PM Re: Back in the Classic Car hobby! [Re: GrumpMarky]
The pressure switch can be removed at any time, doesn't seal anything. If the O rings were leaking, fluid would be flowing from switch...
There are seal repair kits for the pressure differential valve (Torino, Mustang etc) but I have no idea if same kit fits full size.
Now with P/S & PDB
#4042252 - 01/05/20 12:37 PM Re: Back in the Classic Car hobby! [Re: GrandMarq9807]
GrumpMarky Offline
I ♥ big cars!
Loc: Lake County snow belt
OK, that's encouraging. smile I will first try to soften the rubber using 1. the interweb method: soaking in silicone and sealing in airtight bag for a week. 2. modifying the switch connector. After looking into that "rubber renue" it appears to be geared toward rubber plattens used on printers to make them soft and "tacky" again. I want just the opposite, soft and slippery. As for the kits: yes, I have seen them. I have the old pressure diff. valve out of my car, and think it probably can be rebuilt. The switch is available no problem, but the pigtail connector is nowhere to be found. I doubt if I am the only one having this problem. Or else no one else goes to the trouble of redoing everything in their brake system like I have done. But to be fair, the pr. diff. valve from the X-100 was still fine. So maybe the switch to DOT 5 in my car back in '95 was a bad idea. Erik said he has seen old DOT 3 brake systems ruined by DOT 5 in the past. I guess it just depends.
Just took the Marquis out for a drive today, since the roads are clean and dry although it is almost freezing. I wanted to see how the car acted with the new fuel filter. Much improved! It was badly hesitating before, now it is virtually gone! banana The brakes are good and confidence inspiring. Makes me wish Spring would hurry up and arrive. joy
2003 Mercury Grand Marquis LSE
"The last of the un-decontented"
Tires: Bridgestone Turanza LS-H, Mercury OEM Trunk Organizer
Maintenance Log
Currently: 2003 Grand Marquis LSE, 1969 Marquis convertible
Moderator:  BigNSlow, RF_Overlord
2 registered (a_d_a_m, SVTarHeel), 90 Guests and 217 Spiders online.
bluejay_32 190
BigMerc96 75
ClayBelt 67
a_d_a_m 66
Old_Guy_Stu 63
Ponyguy 62
TheCableGuy 56
Moby_Vic 54
RF_Overlord 37
Psxmoe 36
