Page 2 of 2 < 1 2
#4042406 - 01/06/20 09:42 PM Re: On-jackstands transmission removal [Re: Charlie_Mercury]
Originally Posted By Charlie_Mercury
Well 10 years later, I have a question. Attempted to pull a trans out of the you-pull-it yard yesterday. Jacks and jack stands are not allowed. No way to jack the transmission up and the trans cross-member bolt on the passenger side hits the bottom of the car and cannot be removed.
Any suggestions? Thanks
**UPDATE-someone from the GrandMarq board mentioned body mount on the car sagging is keeping the bolt from coming out. Makes a lot of sense. Normally jack the body up but I dont have that option. Seems like I am just going to have to do a mass amount of prying with a large crow-bar. Dropping it on a tire thing I read in here is super smart too. Will be doing that.
what is the year of the car ?
#4042576 - 01/07/20 06:45 PM Re: On-jackstands transmission removal [Re: Charlie_Mercury]
88grandmarq Offline
4R70W rebuilder
The drivers side bolts is a royal pain, It comes out.. push harder. use a hammer, if needed. angle the bolt towards the rear of the car.
#4043176 - 01/12/20 03:02 PM Re: On-jackstands transmission removal [Re: Lugnut]
Lance01 Offline
Loc: Pa
Wondering I have a 2004 crown Victoria that needs a new transmission mount. I tried taking the mount out and don't have enough clearance to get to the top bolts.
Do I need to drop the crossmember to remove the transmission mount??
#4043244 - 01/13/20 03:51 AM Re: On-jackstands transmission removal [Re: Lugnut]
TheShadow Offline
Loc: SoCal High Desert
You should be able to get to the two upper outside bolts, that hold the mating flange of the mount to the tranny extension housing, from straight up from below them. At least on '02's and down. I believe they're the same with the '03+ crossmember change.
I've only pulled a couple or three '03+ trannies, but don't recall anything being different about the mount, just the crossmember-to-frame mounting.
The lower nuts are 14mm? and the flange bolts are 15mm?, IIRC. Or 15 and 16, one or the other.
#4043268 - 01/13/20 09:56 AM Re: On-jackstands transmission removal [Re: TheShadow]
Lance01 Offline
Loc: Pa
The problem I'm having is the crossmember is in the way. I got the two bottom bolts out and pushed up the transmission using a jack but I still don't have enough room with a breaker bar to crack the two top bolts that hold the mount to the transmission.
I can get a small ratchet on it but that does no good when I need the length of a breaker bar (I have 2 breaker bar sizes). Also even if I removed those bolts I still don't think I have enough clearance to remove the mount.
I noticed I need a left side motor mount now as well. I'm thinking if I remove the bolts holding the motor mounts, and the bottom transmission mount bolts, I will have more room to push up everything.
Every one says removing the crossmember is a pain and I'm trying to avoid this.
Edited by Lance01 (01/13/20 09:59 AM)
#4043272 - 01/13/20 11:15 AM Re: On-jackstands transmission removal [Re: Lugnut]
TheCableGuy Offline
Loc: Far Northwest AZ
My driver side motor mount is in bad shape as well, passenger side isn’t as bad but still ‘bad’. Trust me, I’m dreading this, whenever I get to it. I have searched far and wide on How-TOs and it does not look fun by any means.
2010 CVPI 146K. 11,400 idle hours. 3.27 gears. Cheap RKE
Not much of a Ford guy but I sure love this Crown Vic.
#4043288 - 01/13/20 01:23 PM Re: On-jackstands transmission removal [Re: TheCableGuy]
Lance01 Offline
Loc: Pa
And I'm having a problem finding the motor mounts for fleet/taxi by Motorcraft. I went on Rockauto and Anchor brand has em for 20 bucks. I'm ok with Anchor for transmission mount but Engine I prefer Motorcraft.
#4043290 - 01/13/20 02:29 PM Re: On-jackstands transmission removal [Re: Lance01]
TheCableGuy Offline
Either that but I have seen some on Jeggs that are “performance quality”. I have came to the conclusion that I will nail together 1 foot in length 2x4’s to use as a platform to use the jack under the oil pan. My only, again only concern is damaging the oil pan with all of that weight on it. So I’m kinda skeptic on doing it but it’s my only option. I also have been putting it off because I just changed the oil and I’m going to have to remove the oil filter to do this so it’s going to be on the back burner for a bit, or 6-7K miles from now at least. I only have slight vibrations when sitting at the light. Slight. My Sierra motor mount was completely wasted and the vibrations were God awful. It got to the point of throwing it in Neutral at a stop light.
#4043292 - 01/13/20 04:17 PM Re: On-jackstands transmission removal [Re: TheCableGuy]
Lance01 Offline
Loc: Pa
Wood under the oil pan you will be fine. Guys been doing that for years.
#4043344 - 01/13/20 07:31 PM Re: On-jackstands transmission removal [Re: Lance01]
TheShadow Offline
By "in the way", do you mean horizontally or vertically in the way?
Can you use a pry bar against the handle of the small ratchet? Maybe using the crossmember as a fulcrum?
Not for the back end...the main thing holding the tranny back is the tunnel top. And you'd want to leave the front mounts in place, to give you a little gain vertically at the rear, due to the angle of lift and the pivot point.
#4043428 - 01/14/20 11:23 AM Re: On-jackstands transmission removal [Re: TheShadow]
Lance01 Offline
Loc: Pa
With the transmission pushed up by a jack the crossmember is in the way horizontally. The small ratchet with I believe a 16mm socket is the only thing I was able to fit. No makeshift cheater pipe was able to fit over the ratchet in that area.
On a side note I asked my buddy who has a shop and he told me like everyone else here said the crossmember is pressed fit and that crossmember needs to come out.
Before I take it to him I have one other idea. When I was doing the jmod and had the transmission oil pan off I noticed I had clean access to the transmission mount bolts. With the transmission oil pan off if I come from the valve body area with my long breaker bar I might have enough room without having to move the crossmember.
#4043432 - 01/14/20 12:55 PM Re: On-jackstands transmission removal [Re: Lugnut]
TheShadow Offline
It's been a long time since I've seen or dealt with your situation close-up, sorry if I gave you any false hope on it being easier.
I can visualize some extra room with the pan off. BUT...I can also see hazards with jacking up all that weight on a sloped surface (bellhousing), and having it slip onto the valve body. If you try that, PLZ be very careful! Maybe even use a stabilizing jack under the engine pan rear?
Good luck.
Page 2 of 2 < 1 2
2 registered (saltykj, ClayBelt), 43 Guests and 189 Spiders online.
bluejay_32 220
av8or1 118
a_d_a_m 116
BigMerc96 104
ClayBelt 97
TheCableGuy 66
Old_Guy_Stu 56
KYF350 52
2004_p71 48
hot__box 47
