#4043190 - 01/12/20 07:08 PM Shafts & Gears
punkroqgearhead Offline
Loc: West Coast
Been a while since I've posted. I sold my previous '98 P71 back in '08. Now, I'm trying to find another P71. My target years are 2001-2004, it be nice if I could find a unicorn with the 3.55 and limited slip.
Questions are,
What years were the MMC shafts used?
I've read just '99 and '00, however I found an '01 with an MMC at a JY years ago with an MMC shaft? I tried searching and couldn't get a definite answer..
Also, from what I've gathered not all years had the 3.55 limited slip option, if that's the case, what years did for sure? I wouldn't mind a 3.27 car with limited slip either.
Last, did all years have the X5 code on the door for limited slip with 3.27 and C6 for 3.55 with limited slip?
#4043194 - 01/12/20 07:35 PM Re: Shafts & Gears [Re: punkroqgearhead]
In short
1-99 00 in most case as you already stated.
2-there are no defenite answers
3-yup
Your best bet is trying to find an 04 p71 and rebuilt the diff and call it a day .
The mmc drive shaft is pretty much useless and going from 3.27 to 3.55 is also useless, rule of thumb is minimum two gear step and even tho most people who did it wish they went with more gears.
#4043198 - 01/12/20 08:35 PM Re: Shafts & Gears [Re: punkroqgearhead]
ClayBelt Offline
Loc: Leon County
99-00, but iirc they were retroactively applied to some 01's under a service bulletin that permitted a user here to justify having Ford install an MMX in his Marauder
1966 Ford Thunderbird “Fordy McFordface” - 11/2016-?
2005 Buick LaCrosse CXS “Jumba” - 2/2017-2/2018 - 2010 Camaro V6, Flowmaster Super 44’s - SOLD
2010 Mercury Grand Marquis LS “Fat Man” - 4/2018-? - lotta mods
1990 Mazda Miata “Little Boy” - 5/2019-10/2019 - pile of [censored] - SOLD
#4043204 - 01/12/20 08:57 PM Re: Shafts & Gears [Re: punkroqgearhead]
TheCableGuy Offline
Loc: Far Northwest AZ
Oddball question but wasn’t the 04 plagued with transmission issues? Or is that just rumors/wrong info lol.
2010 CVPI 146K. 11,400 idle hours. 3.27 gears. Cheap RKE
Not much of a Ford guy but I sure love this Crown Vic.
#4043236 - 01/13/20 02:25 AM Re: Shafts & Gears [Re: 2004_p71]
Loc: West Coast
Originally Posted By 2004_p71
In short
3-yup
Thanks for your response.
I will respectfully disagree about the MMC being useless. Put one in place of a steel driveshaft in an O/T Impala SS and I was pleasantly surprised in the power it freed up from having less rotational mass. It would spin the tires much easier, the ole butt dyno confirmed it to.
BTW, an '04 is #1 on my list, however, they're getting harder to find..
#4043238 - 01/13/20 02:26 AM Re: Shafts & Gears [Re: ClayBelt]
Loc: West Coast
Interesting.
#4043240 - 01/13/20 02:27 AM Re: Shafts & Gears [Re: TheCableGuy]
Loc: West Coast
I can't answer that, however, from my research they're a one year only trans..
Edited by punkroqgearhead (01/13/20 02:40 AM)
#4043254 - 01/13/20 07:05 AM Re: Shafts & Gears [Re: TheCableGuy]
never heard of that .
what I can tel you is that the 01,02,03 model al suffered from bad timing chain guides and they need to be replaced. Lots of them have been done under warranty but if not you would be on borrowed time .
#4043256 - 01/13/20 07:18 AM Re: Shafts & Gears [Re: punkroqgearhead]
no
it,s the same standard 4R70W, 4R75W came in 05+
#4043258 - 01/13/20 07:20 AM Re: Shafts & Gears [Re: punkroqgearhead]
In short
3-yup
well you went from a steel to an aluminum drive shaft so that explain why.
Now if you get a p71 it comes with an aluminum drive shaft so going to an mmx is pointless.
#4043282 - 01/13/20 01:13 PM Re: Shafts & Gears [Re: ClayBelt]
gDMJoe Offline
Loc: Timbuk3, MI
ClayBelt 99-00, but iirc they were retroactively applied to some 01's under a service bulletin that permitted a user here to justify having Ford install an MMX in his Marauder
-click the Vic-
#4043286 - 01/13/20 01:19 PM Re: Shafts & Gears [Re: punkroqgearhead]
gDMJoe Offline
Loc: Timbuk3, MI
Possible other consideration when installing the (A)MMC driveshaft ...
  • *METCO part # MDL2300 ««« -click-
-click the Vic-
#4043320 - 01/13/20 07:00 PM Re: Shafts & Gears [Re: gDMJoe]
ClayBelt Offline
Loc: Leon County
My bad, maybe it was some 98's then. I know it was one of those bracketing years.
#4043350 - 01/13/20 08:00 PM Re: Shafts & Gears [Re: 2004_p71]
Loc: West Coast
In short
3-yup
That was my point, those driveshafts are not "pretty much useless" to everyone.
I agree that it wouldn't be worth going to MMC from aluminum if the car is already equipped with one.
3 registered (skeletonman, RABOttawa, GrumpMarky), 49 Guests and 68 Spiders online.
bluejay_32 223
av8or1 122
a_d_a_m 116
BigMerc96 111
ClayBelt 97
TheCableGuy 65
Old_Guy_Stu 56
KYF350 53
2004_p71 48
hot__box 47
