#4044944 - 01/26/20 05:40 AM Door locks not working.
yourself Offline
Loc: British Columbia
Seems that when i hit the power door lock button on the drivers door switch panel, only my rear doors lock and unlock. The front doors do nothing. I also cannot lock or unlock the car with my key. The key goes in but will not turn. Any ideas?
1989 Crown Victoria LTD: Men in Black Replica, 5.0 HO swap, Powerdyne BD-10 Supercharger with 8 lb pulley, 3.73 Gears,Trac Lok ,P71 Aluminum Driveshaft
#4044946 - 01/26/20 06:26 AM Re: Door locks not working. [Re: yourself]
Old_Guy_Stu Offline
Lube the latches real good. Pull the door panels off to really get the lube in there. Start with Blaster or Liquid Wrench, follow with lithium grease. If you work the key back & forth while you're doing this, it should free up.
#4044950 - 01/26/20 10:06 AM Re: Door locks not working. [Re: yourself]
Chances are, the door lock actuators are frozen/seized up. Really common on a box. The way the linkages are set up, a seized power lock actuator will prevent any of the lock linkages from moving, including the lock cylinder. My buddy's '91 wagon had this problem on both front doors and the tailgate. Due to no budget at the time, the lock actuators were just disconnected from the latch, that way the doors could be locked/unlocked manually and the rear window on the tailgate could be rolled up/down with the key .
#4044964 - 01/26/20 02:37 PM Re: Door locks not working. [Re: yourself]
yourself Offline
Thanks!
#4047340 - 02/14/20 08:12 AM Re: Door locks not working. [Re: yourself]
minux Offline
Loc: Baltimore, MD
I wound up replacing everything, but +1 to lithium grease. WD40 makes their speciality line and just make sure you buy something that lubricates.
3 registered (124neta, 05BigCat, VoodooChild), 57 Guests and 262 Spiders online.
bluejay_32 233
av8or1 83
a_d_a_m 78
DudeAbides 65
Old_Guy_Stu 64
ClayBelt 45
Ponyguy 39
Moby_Vic 36
RF_Overlord 35
JeffBoudah 34
