Page 1783 of 2056 < 1 2 1781 1782 1783 1784 1785 2055 2056 >
#4044368 - 01/22/20 08:08 AM Re: What did you do to your panther today? [Re: Spartan]
Old_Guy_Stu Offline
I'm probably over-thinking it. I know if you use RTV where it stays in sunlight, it breaks down in a couple years. I think Home Depot stuff meant for windows will work best, and that comes in white which will brighten up the lenses. They take a lot of color from the surface underneath.
Ordered a big pile of LEDs, including switchbacks, and some Bosch relays to upgrade the headlight harness. The lighting project will happen in spring when I can blow it all apart and work without freezing my butt off.
EDIT: 3M Marine UV-resistant silicone seems to be the way to go.
Edited by Old_Guy_Stu (01/22/20 08:51 AM)
#4044476 - 01/22/20 11:46 PM Re: What did you do to your panther today? [Re: Spartan]
Becker34 Offline
Loc: Milwaukee, WI
Went out to the sticks to pick up taillight assemblies. It cost me a case of beer and about 2 hours total on the road. Guy I got them from gave me the hardest hit I ever took in a demolition derby back in my first run, so it's always fun to catch up. Looks like I'm doing a 3 to 4 bulb conversion. Any input is appreciated and can go here so I don't threadjack: https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=4044474&#Post4044474
Present Panther: 2000 Grand Marquis LS
Previous Panthers: '92 Crown Vic LX, '89 Town Car
#4044480 - 01/23/20 01:28 AM Re: What did you do to your panther today? [Re: Spartan]
lmrogp Offline
Pulled all the injectors from the '02 GM. They are getting an ultrasonic cleaning, and I'm going to replace several broken connectors while everything is apart.
2009 Ford Crown Victoria Police Interceptor
Silver Birch Metallic, SAP, 138k, 889+4h, 3.27, Dual Exhaust, Mustang Wheels, LTC Jump Seat, OEM RKE Retrofit, BH1976 Headlight Relay Harness, Engine Compartment Light, Message Center Cluster, Ford Audiophile Sound System w/Subwoofer
2002 Mercury Grand Marquis GS - POTM December 2023
Spruce Green Metallic, 216k, 3.73, ETE Reman Transmission, DRP Tune, Dual Exhaust, HPP Wheels, LTC Jump Seat, Bilstein Shocks, VDO Tach, Compass Mirror, Ford Audiophile Sound System w/Subwoofer
#4044548 - 01/23/20 05:17 PM Re: What did you do to your panther today? [Re: Spartan]
Lundy05 Offline
Loc: Los Angeles, California
Ordered the ADTR Ridetech coilover system.
'05 Crown Vic P71 SAP POTM Sept.'19 | Nov.'20 - Kenne Bell 2.1 Twin-Screw Supercharger @5PSI, Circle-D 265mm 2800-3000 stall converter, BCA built 4R75E, stock maf in 3.5 in tube, 36 lb Kenne Bell injectors, Aeromotive 340LPH fuel pump, EGR delete, ATI Super Damper, NGK BR7EF plugs gapped at .030, 170 t-stat, ADTR Coil Over System, ADTR Heinous Billet control arms, Ford Performance 3.73 Trac-Lok with carbon clutches, 17x9 widened steelies (rear) on Nitto NT555s 285/40/17, front stock steelies on NT555 245/45/17, StopTech rotors and Hawk HPS pads, braided steel brake lines, Stainless Works catback system with chambered mufflers and Marauder tips, GCC Special Edition trim.
'03 Grand Marquis LS (daily) - Katzkin leather seats
#4044578 - 01/23/20 09:18 PM Re: What did you do to your panther today? [Re: Spartan]
bluejay_32 Offline
Loc: wny
Filled the tank.
Originally Posted By BigNSlow
Stop watching Scotty Kilmer, he reverses evolution.
#4044712 - 01/24/20 07:04 PM Re: What did you do to your panther today? [Re: bluejay_32]
bluejay_32 Offline
Loc: wny
I fiddled with the front lights today. Maybe I shouldn't have.
They both did this when I uninstalled them.
The right one did this on the way home.
So a little upset about that.
I also found the source of my noise. It's the right rear wheel bearing. I was planning on changing the fluid in the rear end by the time I got to 100k, so that's not a big deal. I went to NAPA and priced it all out, checked on the axles just in case the bearing's munched it. It seems that the brand that they have is probably Dorman. It's NAPA ProFormer, but that's just rebranded. I'm not really a fan of Dorman, but are their axles any good, or should I source some elsewhere?
#4044764 - 01/25/20 12:38 AM Re: What did you do to your panther today? [Re: Spartan]
Bellwestern80 Offline
CVN Discord: Edsel
Loc: Evans, Georgia
Parked the '97 in the garage. Got the wagon out until I can inspect the front end of the '97. Clunks going over bumps seemed worse, but certainly remind me of how things sounded/felt when the ball joints were worn out.
All things considered, its been about 70-80K since those were done, but I've never been the nicest over bumps and other rough surfaces, so its possible its just worn out again. The upper ball joint boots already gave up. I swapped on some generic ones, but they're not amazing for grease retention. The passenger side lower ball joint has a pinhole leak in its boot, so it oozes a good bit too.
My Cars:
#4044774 - 01/25/20 07:49 AM Re: What did you do to your panther today? [Re: bluejay_32]
GrumpMarky Offline
I ♥ big cars!
Loc: Lake County snow belt
What was the noise like? a growl? It seems kind of premature to be having wheel bearings wearing out. Do you have play in that wheel when jacked up?
2003 Mercury Grand Marquis LSE (SOLD after 20 yrs ownership)
"The last of the un-decontented"
Tires: Hankook Kinergy PT H737, Mercury OEM Trunk Organizer
Maintenance Log
Currently: 2003 Grand Marquis LSE SOLD, 1969 Marquis convertible
#4044776 - 01/25/20 08:12 AM Re: What did you do to your panther today? [Re: Spartan]
ClayBelt Offline
Loc: Leon County
Getting ready to put the big boys on, I should have photos later today
#4044784 - 01/25/20 09:08 AM Re: What did you do to your panther today? [Re: Spartan]
Old_Guy_Stu Offline
Drove it, filled it, cursed the aftermarket headlight harness again. That thing is getting a full re-do once it's warm enough to dick with it.
#4044854 - 01/25/20 04:06 PM Re: What did you do to your panther today? [Re: GrumpMarky]
bluejay_32 Offline
Loc: wny
Kind of a humming/growling noise that gets a little louder when I go left/a little quieter when I go right. No play in the wheel, but I can feel it now when I grab the shock and spin it.
#4044860 - 01/25/20 04:29 PM Re: What did you do to your panther today? [Re: bluejay_32]
bluejay_32 Offline
Loc: wny
Left it in the driveway and drove me ma's Encore.
Took some pics of it with the new phone.
#4044872 - 01/25/20 05:38 PM Re: What did you do to your panther today? [Re: Spartan]
Lundy05 Offline
#4044892 - 01/25/20 07:17 PM Re: What did you do to your panther today? [Re: Spartan]
ClayBelt Offline
Loc: Leon County
Finally put some stainless lines and big brakes on it. Should have photos for y’all later tonight, but I will say I was pleasantly surprised that I could eliminate the spacer the 2013-14 Mustang GT 19” wheels require on our cars.
#4044896 - 01/25/20 07:21 PM Re: What did you do to your panther today? [Re: Spartan]
hot__box Offline
Loc: Gulf South
Trim rings removed, honeycomb grille on. Drove it around, put gas in.
Moderator:  Chaplian, jmlock, Ryan, The_Punisher
2 registered (webestang, Bangster), 122 Guests and 8 Spiders online.
