#4047046 - 02/11/20 08:50 AM Rear axle and motor questions
Vellu Offline
Loc: Finland
I live in Europe and parts are way harder to come by. That's why I have to order almost everything from Usa. And because of that, everything costs me about twice as much for what you could buy it. So that's why I need to try buy my parts in bigger "groups".
So, that's why I'm here to ask some dummy questions. Just that I'm not buying a wrong car for my projects.
I'm looking for replace my rear axle in my -69 Mustang. I'm making about 700 whp. 9" surely would be most popular choice, but I'm thinking to do Crown Vic front end swap also to my truck. Because of that easiest thing to me is buying complete CW and ship it to Finland.
- All CW have 8.8 axle? I know that axle is way too wide but I assume that I can narrow it down just like any other 8.8 axles?
-Is there any c-clip eliminator kits for CW axle or is it better to use 9" ends?
- Is front end same design in all years (2005-2011)? (wrong forum section but maybe this goes with all other questions)
- Is there any differences in engines in years 2005-2011? I'm thinking to use engine as well when doing CW front end swap so maybe some aftermarket ecu is easiest way to go?
I have read that 2005+ cars have better rear axle (31 spline?) and earlier models had some problems with soft materials in axle? That's why I'm looking CW 2005-2011. Is there any year that I should look or are they all same?
Thanks!
Vellu
#4047056 - 02/11/20 11:21 AM Re: Rear axle and motor questions [Re: Vellu]
AlleyG Offline
Loc: Raleigh, NC
Your 69 Mustang doesn't already have a 9" rear?
They used them in T-Birds of the day.
I would buy something pre-made to fit the Mustang - not buy a Crown Vic rear and cut it. A 9" is mandatory for 700 WHP anyway, IMO.
Al
2004 CVPI - 76k miles
1997 T-Bird LX - 80k miles
1994 Supra Turbo - 107k miles
Previous Fords:
#4047060 - 02/11/20 11:44 AM Re: Rear axle and motor questions [Re: Vellu]
2011LX Offline
Loc: Oak Creek, WI
I don't think 9" was common in Mustang.
Mustang was made to be a small/light car, and most didn't come with much HP under the hood. A 9" would be unnecessarily big and heavy.
A typical V8 car probably would have come with a 8". 6 cyl maybe 7.25.
currently @ 92k miles
Medium Light Stone interior
#4047070 - 02/11/20 01:45 PM Re: Rear axle and motor questions [Re: Vellu]
Old_Guy_Stu Offline
If you're going to swap the engine and front suspension into your truck, you might think about using the whole CV chassis. Apparently it's pretty common.
The CV's 8.8 axle might take 700 HP, but a 9-inch would for sure. If you're going to do all the work needed to change it, start with the right axle.
1988 CVLX (Love Boat) POTM July 2019 50K
E-code lights w/ relays, LEDs w/ switchbacks, Kenwood stereo, various hacks.
#4047086 - 02/11/20 05:53 PM Re: Rear axle and motor questions [Re: Vellu]
The 8.8 is fairly stout, depending what the car weighs, it could probably take 700hp without breaking, but I'd be more confident with aftermarket axle shafts in it, probably need those anyway if you're narrowing it. I don't no if they make c-clip eliminators for the 8.8, but given how common they are I would almost be surprised if they don't. Afterall, using a Explorer rear axle in Jeeps is fairly common, gives them rear disk brakes and apparently they're nearly the same width.
As far as differences between '05-'11, there are a few but nothing too major after '06. '05s are a weird mix with many mid-year changes and one-year-only parts. The switch to 31-spline axles happened mid '05, I want to say the changeover was in December 2004. However, early '05s had aluminum front control arms vs. stamped steel on the later ones. The change in control arms shouldn't matter as far as using the front end for a swap because they still mount to the same points and the main aluminum crossmember didn't change.
#4047094 - 02/11/20 06:54 PM Re: Rear axle and motor questions [Re: AlleyG]
ClayBelt Offline
Loc: Leon County
Al
Tbirds did not, they used this weird ass like 10” rear diff that’s tbird unique and impossible to find aftermarket rear gears for
1966 Ford Thunderbird “Fordy McFordface” - 11/2016-2/2020 - SOLD
2005 Buick LaCrosse CXS “Jumba” - 2/2017-2/2018 - 2010 Camaro V6, Flowmaster Super 44’s - SOLD
2010 Mercury Grand Marquis LS “Fat Man” - 4/2018-? - lotta mods
1990 Mazda Miata “Little Boy” - 5/2019-10/2019 - pile of [censored] - SOLD
1986 Ford Mustang SVO “Touge Fox” - 2/2020-?
#4047096 - 02/11/20 07:51 PM Re: Rear axle and motor questions [Re: Vellu]
My 1994 Thunderbird SuperCoupe had IRS in the back.
#4047098 - 02/11/20 07:57 PM Re: Rear axle and motor questions [Re: Vellu]
Davidzq Online   happy
Loc: Seattle, WA
1. Yes, all crown vics, grand Marquis, and towncars had 8.8" rear ends. Available ratios were 2.73, 3.08, 3.27 and 3.55
02 and older are 3" narrower than 03 and newer, but you're limited to 28 spline (unless you get custom shafts made).
2. Don't know.
3. 03-11 are the same, rack and pinion steering. The variable assist power steering electrical changed in 08 though.
4. 05-11 engines are identical, except 09+ p71s have a different oil cooler adapter, which holds a smaller fl910 filter (vs the fl820)
03-04 are also identical, except for having a cable throttle body (05+ is electronic).
01-02 have different oil pan, exhaust manifolds, and valve covers.
5. Switched from 28 spline to 31 spline in the middle of the 05 model year (12/14/04).
There was a recall for a bad batch of axle shafts, in 03 I believe. But those should be long gone by now.
David Hensley
2007 P71, Norsea Blue SAP
-Jmod
-Full dynamat install
-Headlight relay mod
#4047172 - 02/12/20 05:04 PM Re: Rear axle and motor questions [Re: Vellu]
Vellu Offline
Loc: Finland
Sadly that's illegal here. We have yearly car inspections so that's not an opinion.
I have read that 8.8" can take some serious power. Another choice for me would buy that Explorer axle, because that have right width. But on the other hand we don't have that many spare Explorer rear ends here so I would have to buy the whole car and just take the rear.
2. Don't know.
Thanks for these infos. I'm pretty sure that I'll buy a car from Copart. I think that I can get car little cheaper from there.
#4047194 - 02/12/20 09:31 PM Re: Rear axle and motor questions [Re: Vellu]
Shame. I thought the Finns were more progressive than we here in the US.
#4047220 - 02/13/20 12:07 AM Re: Rear axle and motor questions [Re: RF_Overlord]
Rjay Offline
Loc: Atlanta, Georgia, United State...
Oh, for sure not. They are way more controlling when it comes to vehicles over there than in the U.S., depending on where you are from.
2011 Ford Crown Victoria P7B 4.6 -- 217,509 mi
2001 Ford Expedition XLT 5.4 -- 291,417 mi
2000 Ford F-350 EXT 7.3 (sold) -- was aprox. 109,900 mi
1993 Ford Taurus (inoperable) -- 187,041 mi
#4047278 - 02/13/20 12:35 PM Re: Rear axle and motor questions [Re: Vellu]
CrystalPistol Offline
a base '69 Mustang had a 8" rear, if it was a 351Cleveland 4 spd car … it had a 9".
8.8s weren't in the mix in 1969.
3 registered (Lance01, CountryMile, Korvus_Korax), 76 Guests and 208 Spiders online.
bluejay_32 182
Old_Guy_Stu 128
av8or1 123
a_d_a_m 110
BigMerc96 98
ClayBelt 82
TheCableGuy 66
Davidzq 66
Freddy12189 50
2011LX 43
