#4054366 - 03/24/20 10:14 PM I hate Having OCD
Psxmoe Offline
So I got mostly everything I need to tackle my Intake Replacement, and some more. I honestly hate having the, Im in the neighborhood might as well mentality.
I got a new Ford OEM Intake Manifold #9W7Z9424A
Comes with Crossover and upper Intake O-ring BTW
New PCV valve OEM # 5L3Z6A666BA
Fel-Pro Manifold Gasket Set #MS96281
Fel-Pro Fuel Injector O-rings # ES70599 x4
Mahle Coolant Pipe O-ring Set # GS33800
WIX oil # 51372XP and Air Filter #46134.
I would of stopped but no I couldn't, also Purchased
Fel-Pro Oil Filter Adapter/Housing Gasket # 70801
Fel-Pro Valve Cover Gasket Set # VS50564R
Stant Super Stat # 45779
And new Spark Plug Boots
I was tempted to do the Timing chain cover as well. But the wife is also screaming at me.
Sadly The Mahle Coolant pipe Oring set that was supposed to contain 2 Orings only had 1 even though it said SET on the bag and was listed on rockauto as contains 2 seals.
And lastly is just baffling. The stant thermostat I ordered contained a Motorcraft thermostat, I was happy at first but its got either rust or coolant residue, looks used and has a date code from 2012. WTF?
2006 CVPI SAP 76,000 Miles, 520 Hours, BH1976 HD Light Harness, 3.27 Trac-Lok, BF Goodrich g-force COMP-2 235/55R17
Pima County, Arizona
#4054382 - 03/24/20 10:50 PM Re: I hate Having OCD [Re: Psxmoe]
Old_Guy_Stu Offline
Somebody else mentioned a Motorcraft stat in a Stant box this morning, and I thought "I bet somebody returned his old one." Looks like that actually happened there.
I have that OCD thing, too. Getting ready to replace valve cover gaskets. In my case that means buying a set of new used valve covers, so I can paint them beforehand and have 'em ready to go on when I finally get around to it.
1988 CVLX (Love Boat) POTM July 2019 50K
E-code lights w/ relays, LEDs w/ switchbacks, Kenwood stereo, various hacks.
#4054400 - 03/24/20 11:37 PM Re: I hate Having OCD [Re: Old_Guy_Stu]
hot__box Offline
Loc: Louisiana
Yep. That hardly looks like shipping and handling residue. Some asswipe pulled a fast one.
And, I don't think the OCD is such a bad mentality to have. If it gives you peace of mind and keeps the car running reliably, why not?
1985 Impala - Hot Box
1994 CVLX [POTM - March '20]
2005 CVPI (250,000+ miles, runs a'ight)
2005 E350 Cargo Extended
2011 Chevrolet Silverado 1500
2006 CVPI SAP (Sold!) [POTM - October '19]
And more...
#4054444 - 03/25/20 05:15 AM Re: I hate Having OCD [Re: Psxmoe]
Rootintootin Offline
Loc: North Carolina
Just so long as you don't forget what you were originally going in for.
97 CVPI(Ex. Tampa PD #715), 137K miles, performance Torque converter, J-modded valve body. Monroe Gas Magnum Severe Duty shocks, Ported Plenum and 70mm FRPP Throttle body
#4054458 - 03/25/20 08:13 AM Re: I hate Having OCD [Re: Rootintootin]
IDK how many times I've done that on a repair. Starts with an oil change, next thing I know I have the brakes torn apart because the pads looked thin, and then I start the car before realizing that I didn't change the oil filter. True story.
#4054462 - 03/25/20 08:45 AM Re: I hate Having OCD [Re: Psxmoe]
Loc: North Carolina
Yep, that's OTD (Old Timers Disease). Been there, done that. Got the T shirt to prove it. I know it's around here somewhere.
#4054490 - 03/25/20 10:15 AM Re: I hate Having OCD [Re: Rootintootin]
gDMJoe Offline
Loc: Timbuk3, MI
Rootintootin - Yep, that's OTD (Old Timers Disease). Been there, done that. Got the T shirt to prove it. I know it's around here somewhere.
Y'all just sufferin' from CRS ( Can't Rember Shit ) biggrin
-click the Vic-
#4054496 - 03/25/20 10:51 AM Re: I hate Having OCD [Re: Psxmoe]
Old_Guy_Stu Offline
What were we talking about?
#4054502 - 03/25/20 11:18 AM Re: I hate Having OCD [Re: Psxmoe]
Blu Offline
Loc: Milwaukee, WI
I hate posts like this! Now I have to build a cart...
00 06 09 PI
#4054572 - 03/25/20 06:15 PM Re: I hate Having OCD [Re: Psxmoe]
2007CrownVic Offline
yep that looks like a used thermostat.
Did it come from rock auto?
I gave up on getting parts from there because while they were new they were also super old stock, flood damaged, or some other problem, Not to mention I can get the parts I want local for not much more and I'd gladly pay that bit more for the convenience of being able to pickup or return stuff on the fly.
#4054574 - 03/25/20 06:24 PM Re: I hate Having OCD [Re: BigMerc96]
Hah- just before Christmas I had to do front brakes on my truck. Simple enough... nope. Got it apart and calipers were leaking, went to put the first one on and the seal was defective on it so I had to rush out to another store to get another pair since the first store was closed. Also noticed that a ball joint was so loose you could probably pull it apart by hand. When I pulled it inside to start this I heard a gushing noise and saw the lower rad hose had come off for no reason at all so that meant change the coolant and new thermostat too, which I wanted to do at some point anyway.
What were we talking about now LOL
#4054604 - 03/25/20 09:31 PM Re: I hate Having OCD [Re: 2007CrownVic]
Psxmoe Offline
Glad to Know Im not the only one with OCD!
All parts came from rockauto, exception Intake Manifold.
Rockauto is sending replacement parts for the Thermostat and Coolant Pipe o rings. Which was funny because I filed a return about 6pm MST and got an email the same day at around 10pm saying my parts have been shipped!
I remember I ordered a fram tough guard oil filter for a Honda accord I had in 2014, The Fram filter was from the Allied Signal Era! I kept the box. Filter was old but worked fine. And once I ordered a drum brake hardware kit for a buddys 97 Dakota, And I [censored] you not, The boxes had MONTGOMERY WARD sitckers on them!!
#4054650 - 03/26/20 12:35 AM Re: I hate Having OCD [Re: Old_Guy_Stu]
a_d_a_m Online   drunk
In my case, it was actually a brand-new stat. That, or someone did one hell of a job cleaning it and went to the trouble of including a new gasket. laugh
'91 LTD Country Squire (POTM Mar. '19) | '04 CVLX (POTM Jun. '19) | '03 Marauder (POTM Nov. '10)
formerly: '02 MGM, '04 MGM, '04 MGM v2.0, '04 MM, '07 P71 w/5-speed (POTM Feb. '18), '03 SAP P71
#4054876 - Yesterday at 12:41 PM Re: I hate Having OCD [Re: Psxmoe]
hot__box Offline
Loc: Louisiana
As far as Rockauto goes... Can't say I've never had an issue with RockAuto, but I will say that their return and replacement policy is pretty decent.
While back ago I ordered a case of Coolant, as well as some belts and other parts.
When it arrived, the box was completely destroyed and soaking wet. It had been raining that day so I thought maybe it had got rained on but no, turns out two of the jugs of coolant had bust and leaked out everywhere, soaking all the belts and other parts. I was so pissed, I immediately filed a claim with Rock Auto for two replacement jugs of coolant and new parts since I wasn't sure what kind of damage coolant would do to the belts and stuff.
Within two days they approved the shipment of new merchandise.
To my surprise, they replaced all the parts, and instead of two jugs the sent me a whole new case of coolant. So that was pretty good.
And more...
5 registered (IPreferDIY, Mechtech900, JordanA, LTC_Dave, 1 invisible), 75 Guests and 181 Spiders online.
av8or1 277
bluejay_32 270
a_d_a_m 234
BigMerc96 144
Old_Guy_Stu 144
Moby_Vic 101
DudeAbides 92
2011LX 76
hot__box 75
IPreferDIY 73
