Page 121 of 122 < 1 2 119 120 121 122 >
#4055354 - 03/30/20 12:34 PM Re: let the 5.4 breathe [Re: 2004_p71]
Drac Offline
Cpt. Smug
Loc: Cali
banana banana banana
#4055536 - 03/31/20 10:49 AM Re: let the 5.4 breathe [Re: 2004_p71]
Mr. 427
Do yourself a favor and grab a Ram clutch alignment tool!
The one that came with the clutch was trash and I couldn't get the input shaft of the transmission in properly because of it.
Being twin disc makes it more of a challenge.
Here's the 26-spline one I used (are you 10-spline?)
https://www.americanmuscle.com/ram-26-spline-clutch-alignment-tool.html
1964 Ford Galaxie 500 R-Code
1972 Ford Galaxie 500
2008 Ford CVPI
#4055932 - 04/02/20 08:32 AM Re: let the 5.4 breathe [Re: CNGInterceptor]
Thanks for the tip smile
My tr3650 was up graded with a 26 spline imput shaft smile
I have a universal clutch alignment tool that I used for all of the other manual swap I have done, I will see if it works smile
#4060082 - 04/23/20 10:27 PM Re: let the 5.4 breathe [Re: 2004_p71]
some more up dates smile
Got the diff out. Gonna ditch the ford's track lok in favor of an Eaton detroit truetrac .
I am keeping the 4.10 gears in there for now .
Diff is dusty so I an going to clean it and probably repaint it again to it,s former glory
Control arms seen better days too !
lots of overspray for the previous 2 paint job.
Bushings on the upper arms need to be replace as they are shot but it's a no brainer everything will be replaced and arms stripped from over spray.
when they were new against the stock control arms
I dropped the fuel tank to be able to paint the frame and I need to change the pump from a 255 to 340 lph .
By the time I receive these parts it will have enough time to clean the floor and repaint the whole thing .
#4079622 - 10/03/20 08:33 AM Re: let the 5.4 breathe [Re: 2004_p71]
I wont lie it's been on the back burner for a long time . Family time being a priority and dealing with other issues set me a few month back on this project .
Diff is a complete rebuilt with moser axles , eaton true track and diff 4,10 gears
floor pan and frame has been stripped from the flaky p51 jobI did few years ago and re coated in black .
new mcleod twin disc clutch and pressure plate plus new flywheel with ARP hardware .
That alone costed me a few grand righ away except the axle that were generously donated by a good friend of mine MR John smile cnginterceptor
lots of details and parts to buy along the way as everything is pretty much being replaced along the way so it,s a costly and lenghty process but Iwill get there !
#4079720 - 10/03/20 11:31 PM Re: let the 5.4 breathe [Re: 2004_p71]
Loc: Iwakuni, Japan.
woot
1990 Mazda Miata
2000 Toyota Crown Estate Athlete V
1994 Autozam (Mazda) AZ-1 (Kei Car legend)
#4124388 - 10/14/21 09:05 PM Re: let the 5.4 breathe [Re: 2004_p71]
holy thread revival !
The 5.4 car lives again !!!!!
after 5 freaking years it,s alive !!!!
#4124402 - 10/14/21 11:13 PM Re: let the 5.4 breathe [Re: 2004_p71]
88grandmarq Offline
4R70W rebuilder
This thread is so old... gasoline engines will be obsolete by the time you finish.
#4124406 - 10/14/21 11:44 PM Re: let the 5.4 breathe [Re: 88grandmarq]
better late than never laugh
#4124508 - 10/15/21 08:03 PM Re: let the 5.4 breathe [Re: 88grandmarq]
dixiebandit69 Offline
5.4 Club
Loc: Texas
Silly rabbit, project cars are never "finished."
Way to go, Peir. What's in the motor this time?
#4124570 - 10/16/21 12:09 PM Re: let the 5.4 breathe [Re: dixiebandit69]
Well beside the fact that this is my second 5.4 block , it uses the same internals than the first one but with new rings off course.
The main difference is the cams that are now specefic to the trickflow heads (cant remember the cam profile tho it's been 5 years already ) and I am back with an HPS intake.
Having a more suitable intake and the correct cam will certainly help in the overall performance of the engine . We will see when I hit the dyno and track burt considering the car has been away for 5 years I still have to stretch and warm up the old lady before starting to see the full potential of this new set-up .
My ultimate goal is to hit 11.9 N/A . Fast enought to be brag about but not fast enough to get my ass kicked from the track lmao.
#4124572 - 10/16/21 12:28 PM Re: let the 5.4 breathe [Re: 2004_p71]
Congrats, friend. Long time in the making. laugh
#4124582 - 10/16/21 01:31 PM Re: let the 5.4 breathe [Re: 2004_p71]
Big_Pimpin Offline
Loc: NC
Dedicated you are. Very cool.
#4124616 - 10/16/21 04:49 PM Re: let the 5.4 breathe [Re: a_d_a_m]
thanks man
long time you said !
been wrenching on this car since I bought it in 2006 lol
#4124618 - 10/16/21 04:50 PM Re: let the 5.4 breathe [Re: Big_Pimpin]
thank you smile
Traffic22 15
