#4063992 - 05/20/20 07:43 PM Throttle by Wire Question
alumarine Offline
Loc: Manitoba, Canada
I've got throttle by wire on my 2007 TC.
Is there a way to rev the motor from the engine bay?
Or, can a program like Forscan make the motor rev?
One reason I would like to do that is so I could watch my A/C pressures easier at 1500 rpm.
thanks
#4064062 - 05/21/20 12:45 PM Re: Throttle by Wire Question [Re: alumarine]
2008interceptor Offline
Loc: Pennsylvania
There's no real way under the hood other than manually moving the throttle plate. That would be risky with the car on as you risk damaging the motor and gearing on the tbw. It would definitely be possible to operate the throttle by computer. The thing is whether forscan could or something more along the lines of a dealer level scanner was needed.
#4064234 - 05/22/20 10:10 AM Re: Throttle by Wire Question [Re: alumarine]
alumarine Offline
Thanks. I didn't think there would be an easy way.
I found a Forscan ACP_PRESS PID.
I'm going to see how that corresponds to my high pressure a/c gauge.
If it does match then at least I can easily tell high pressure from inside the car.
#4064242 - 05/22/20 11:21 AM Re: Throttle by Wire Question [Re: alumarine]
Lance01 Offline
Loc: Pa
Like the other poster said don't manually move the throttle position as that can cause damage to the motor.
Also, you don't want your fingers near any of that throttle body because it can move on it's own at no warning and has enough power to severely damage your fingers. From what I understand drive by wire has ice breaking strategies so sometimes it just moves on it's own.
4 registered (Warped9, SpitShine_PL, JSW07VIC, Derek_L), 95 Guests and 104 Spiders online.
bluejay_32 252
Blu 113
av8or1 89
Old_Guy_Stu 86
Moby_Vic 77
2004_p71 75
a_d_a_m 74
BigMerc96 72
BigJon 69
DudeAbides 61
