#4067770 - 06/17/20 07:48 PM 2005 grand Marquis question
Dragonrider01826 Offline
Loc: Ma
Hello all
I got a 05 grand marquis with 157,000 miles on her she still runs good and strong. My question is it still worth putting mods on it or is the mileage of the car to high?
I did the J-Mod at 57K when I had the car and change the oil every 4K and transmission every 50K.
thanks
05 grand marquis ultimate edition LS Birch silver 157,295
#4067778 - 06/17/20 09:24 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
Bangster Offline
If normal maintenance is kept up with, rust isn't an issue, then there is no reason that it shouldn't go 300,000+ miles. There might be little issues along the way, and stuff does wear out and break down with age, but the amount of money you will likely need to put into it is likely very small compared to replacing it with something newer.
If it fits what you need in a vehicle then I say keep up with it, and modify it to make it meet what you want it to do that it currently doesn't.
I starting letting things slip on mine, and I think time was just as bad if not worse than miles, and in the end added up all the little things made it not worth the time and hassle for me, I got more than moneys worth out of it, and I was emotionally attached to it, but not so much that I wasn't able to eventually let it go. It took my daughter to her first day of school and it was her first car in college. It brought my son home from the hospital, it covered 3 countries and 15 states, it protected the family in 3 fairly intense accidents, it left me once (my fault trying to push a fuel pump that gave me plenty of warning).
#4067874 - 06/18/20 01:49 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
TinyTim Offline
Loc: Ohio
Mine had 222,000 when I got it,and it was getting close to 300,000 before I started doing any mods.Has about 320,000 now and still fine mechanically
Probably won't last more than a couple more years due to rust though.Thanks salt
2003 Interceptor with dual spotlights,cruise,4.56 trac-lok,J-mod with springs removed/hi-po overdrive spring,quantum 255 pump,hidden dry nitrous setup,[email protected]'s tune,a Rockford Fosgate Punch 15 (guess that makes me a...nerd joke coming up...wait for it...One Punch Man,har-har)
"Boy,everyone is stupid except me."
Homer Jay Simpson
https://supersexystudmuffin.tumblr.com/post/163909691712
#4067876 - 06/18/20 02:15 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
ford05 Offline
Loc: New Jersey
Start modding
#4067882 - 06/18/20 02:37 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
Loc: Ma
Thanks all for the input
Will start simple and move my way up the mod list
She got alittle bit of rust forming under the inside door part but going to take car of that this summer.
Guess first mod will be duel exhuast, then 3.27 and larger MAF with tune.
#4067886 - 06/18/20 03:28 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
Lt_Crazy Offline
After maintenance, you def need an exhaust!!!
#4067888 - 06/18/20 03:33 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
Lance01 Offline
Loc: Pa
I would knock down your transmission fluid change to at least a full fluid change every 20k. Get a U-haul transmission pan with the drain plug to make transmission fluid change easy.
Motorcraft or Wallmart fluid is just fine. Btw, I change my transmission fluid every 12k miles.
#4069596 - 07/04/20 05:22 AM Re: 2005 grand Marquis question [Re: Dragonrider01826]
Kulolo Offline
Loc: Hawaii
My 2005 GM Ultimate Edition just broke into 20,000.00 miles. Got her with about 9,000.00 on the odometer about a year ago.
Best upgrade mod was installing a in dash rear view camera system with blue tooth.
Hands free phone system and rocking to Pandora Kid Rock "I'm a Cowboy" is awesome.
Installed all new shocks... New slotted and drilled rotors with ceramic pads.
Dual exhaust with stainless tips.
18 inch black rims and wider tires....
Ceramic coated the exterior paint....
Dark tinted all glass
Ford dealer was amazed ....
Good luck with your mods.... these are amazing cars.
I came... I saw.... was not impressed
#4069598 - 07/04/20 05:26 AM Re: 2005 grand Marquis question [Re: Lance01]
Kulolo Offline
Loc: Hawaii
Please explain U-Haul drain pan with plug????????
U-Haul sells these upgraded pans with a drain plug????
#4069608 - 07/04/20 08:43 AM Re: 2005 grand Marquis question [Re: Dragonrider01826]
2008interceptor Offline
Loc: Pennsylvania
They're ones made for the uhaul trucks and has a higher capacity plus drain plug. Purchased like any other part, not sold by uhaul though.
#4069636 - 07/04/20 01:34 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
2007CrownVic Offline
Do a search for the U-haul drain pan, lots of info about it here. There are other makes who sell similar pan but some are better then others.
#4069642 - 07/04/20 01:49 PM Re: 2005 grand Marquis question [Re: Kulolo]
gDMJoe Offline
Loc: Timbuk3, MI
Kulolo - Please explain U-Haul drain pan with plug???????? ...
Part # F8UZ-7A194-AA
-click the Vic-
#4069644 - 07/04/20 03:00 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
alumarine Offline
Loc: Manitoba, Canada
I believe the Dorman 265-813 will also work and it has a drain plug.
#4069652 - 07/04/20 04:02 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
Just for reference, the "U-Haul" pan does not have increased fluid capacity...it's identical the the stock pan with the addition of the drain plug.
#4069664 - 07/04/20 07:15 PM Re: 2005 grand Marquis question [Re: RF_Overlord]
I was going to say that but I wasn't 100% sure. From what I remember, the reason the u-haul pan exists is because u-haul wanted to be able to easily service their vans. They have enough pull with Ford (and GM) thru their fleet accounts and large numbers of vehicles ordered that Ford complied with that request by simply modifying the standard pan and adding a drain plug. Probably costs Ford very little to do that and if it keeps a large national fleet company happy, it only makes sense for them to do so.
#4069910 - 07/06/20 03:00 PM Re: 2005 grand Marquis question [Re: BigMerc96]
Lance01 Offline
Loc: Pa
Should have been standard on all transmissions but they saved millions by deleting a drain plug. So many cars and trucks with 4r70w's ended up in the scrap yard due to early transmission falure that could have been prevented by having a drain plug to easily service the transmission fluid.
#4069942 - 07/06/20 08:57 PM Re: 2005 grand Marquis question [Re: Lance01]
The same people who don't bother changing the fluid still wouldn't bother changing the filter so they wouldn't be that far ahead.
It's all made even worse now when most new vehicles don't even come with a transmission dipstick anymore.
#4070664 - 07/14/20 02:22 AM Re: 2005 grand Marquis question [Re: gDMJoe]
Kulolo Offline
Loc: Hawaii
Thanks.....
Definitely what I will order
#4070676 - 07/14/20 11:40 AM Re: 2005 grand Marquis question [Re: 2007CrownVic]
gDMJoe Offline
Loc: Timbuk3, MI
2007CrownVic ... It's all made even worse now when most new vehicles don't even come with a transmission dipstick anymore.
Can't speak-for other brands or -all- Fords, but they do have a dipstick, it's just not convenient. Example ...
  • *In case the image is a no-show ... <PIC>
    *6R80 transmission
And even then ... The aftermarket makers provide convenient, traditional alternatives.
-click the Vic-
#4071210 - 07/19/20 09:10 PM Re: 2005 grand Marquis question [Re: Dragonrider01826]
Loc: Ma
Well all sense my last post I've done the following to my grandma
1 80maf
2 Moe tune for 87 and 89
3 dual exhaust
4 18 mustang rims
Well now that I have new rims and I replace 90% of the front end and rear the car sits way to high, so looking at coilsprings.com but not sure what a good drop for these cars and if I do drop it do I want to change "Ride/Rate being changed" and if so what should it be.
0 registered (), 59 Guests and 246 Spiders online.
bluejay_32 193
BigMerc96 79
ClayBelt 77
Old_Guy_Stu 66
a_d_a_m 65
Ponyguy 63
Moby_Vic 62
TheCableGuy 57
Psxmoe 46
RF_Overlord 33
