#4067958 - 06/19/20 08:55 AM Engine Issues...
Inali Offline
Loc: VT
Hey everyone.
I recently scored a 1996 Crown Vic base model (single exhaust, no traction control, just ABS) for $500 from my bosses mother, and everyone who has seen it is surprised how rust free it is, yay!
Anyway, I have had issues with it from the start and now I am unsure what to do.
When I bought it, it overheated. I fixed this by replacing the cracked Ford intake manifold with a Dorman, as it was leaking coolant.
I've replaced the fuel injector caps and o-rings, air intake filter, MAF, air sensor inside the airbox (forgot the name of that, intake air temperature sensor?), engine and transmission oils, replaced idle air control valve, replaced fuel filter, replaced all spark plugs, and cleaned the throttle body.
Now the problem I have is that the car doesn't like to run with small amounts of throttle. I have noticed this is much worse in the summer than the winter. What happens is the car cold starts just fine, but after it warms up, it will stumble and sometimes stall if you feed it a tiny amount of throttle. More throttle is fine. I have stalled driving around 25MPH and lower, or when trying to pull away from a stop more than once, as well as stalling when transferring from Park to Drive or Reverse.
I have noticed the rubber pipe for the air intake to the throttle body has a crack on the back where one of the two lines connect to it (maybe vacuum lines?). I am unsure if this is causing my issue, but the part doesn't have a part number on it, and Ford's website doesn't list the part at all... or any other useful parts which is SUPER annoying. Anyone know the part number for this pipe?
Anytime I try to find parts for my 1996, I only find stuff for 1998+ which obviously doesn't work for my car.
As a side note, my fuel pump whines constantly. I can hear it just sitting in the drivers seat. Is it possible that is the problem where it can't supply the correct amount of fuel during tiny amounts of throttle?
Any advice would be appreciated. I recently ordered a smoke machine to test for vacuum leaks but I haven't gotten my air compressor functional yet to test with it.
If it helps anyone, my VIN is 2FALP73W3TX198618.
#4067960 - 06/19/20 09:20 AM Re: Engine Issues... [Re: Inali]
Bangster Offline
Hmm, I thought it was the earlier ones with the emission tee that split, it isn't this one is it? I guess you are talking about the air intake tube where the IAC and the crankcase vent attach? I picture might help. An unmetered air leak would cause issues, yes.
#4068016 - 06/19/20 06:09 PM Re: Engine Issues... [Re: Bangster]
Inali Offline
Loc: VT
Here are some pictures. Also I noticed there's a slotted gap under my MAF, is that normal?
Here's the link to the picture album: https://photos.app.goo.gl/3Uhd7THSZtAPxks68
Edited by Inali (06/19/20 06:12 PM)
Edit Reason: Broken picture uploads
#4068112 - 06/20/20 11:08 AM Re: Engine Issues... [Re: Inali]
You can't attach pix here. Vertical Scope broke that feature a couple of years ago and won't fix it. You need imgur or similar...
#4068120 - 06/20/20 12:50 PM Re: Engine Issues... [Re: Inali]
GoldPanther Offline
BOK contributor
Loc: Chitcagoland!
In my experience, I had issues with a coil pack, it would work ok when cold but one it's hot it will start, like, sending weak sparks making misfires.
Just a thought.
03 mgm ultimate edition.
#4068144 - 06/20/20 05:05 PM Re: Engine Issues... [Re: RF_Overlord]
Inali Offline
Loc: VT
Ah, well here they are then:
https://imgur.com/1bQu6j5
https://imgur.com/KUNcqSu
https://imgur.com/osoIyV6
#4068146 - 06/20/20 05:07 PM Re: Engine Issues... [Re: Inali]
Inali Offline
Loc: VT
I read that after someone else swapped intake manifolds, they accidentally got coolant in the cylinders.
Is there an easy way for me to know this, or do I have to find someone to pull the intake manifold and such off to look inside?
#4068172 - 06/20/20 08:50 PM Re: Engine Issues... [Re: Inali]
Inali Offline
Loc: VT
I found out today that my check engine light doesn't illuminate, But I bought a Bluetooth to OBD2 scanner and it says my MIL light should be on, and is throwing a code of p0102.
#4069000 - 06/28/20 01:09 PM Re: Engine Issues... [Re: Inali]
Inali Offline
Loc: VT
So I tried to do a smoke test via the intake pipe and also the evap port, but I didn't see any smoke going anywhere else or leaking anywhere. Is there a better place to do this? Also, my car will now accelerate by itself and runs worse thing before in park.
#4069004 - 06/28/20 02:57 PM Re: Engine Issues... [Re: Inali]
Inali Offline
Loc: VT
I noticed there is an obviously missing cap or hose as show red here. Anyone know what it is? I don't see any unplugged and loose hoses anywhere in the engine bay.
https://puu.sh/G1voF/dc59bf3a6f.jpg
Edited by Inali (06/28/20 03:07 PM)
Edit Reason: Fixed image.
#4069012 - 06/28/20 03:39 PM Re: Engine Issues... [Re: Inali]
bluejay_32 Online   content
Loc: wny
What is missing there is the cap for the low side A/C port.
CVN POTM - February 2019 joy
3 registered (GrumpMarky, bluejay_32, 1 invisible), 88 Guests and 179 Spiders online.
bluejay_32 245
av8or1 85
Old_Guy_Stu 79
DudeAbides 73
a_d_a_m 73
Ponyguy 47
ClayBelt 43
RF_Overlord 36
Moby_Vic 36
Davidzq 30
