#4068184 - 06/20/20 10:18 PM 09 cvpi stalls immediately after startup
imit8n_bcn Offline
Loc: SW Ontario
I unhooked my battery today to erase an engine code. When I reconnected it, the car would not run longer than 2-5 seconds.
I'm assuming it's a fuel issue.
What is going on?
'09 P71 -05 mustang rims. -dorman intake manifold. -hand made ram air intake.
#4068188 - 06/21/20 12:49 AM Re: 09 cvpi stalls immediately after startup [Re: imit8n_bcn]
My former work van (a non-Ford) would do the same thing after the battery was unhooked...it would start up fine but I had to keep feathering the gas for a few minutes before it would stay running at idle. Never did figure it out because the battery wasn't disconnected very often.
#4068190 - 06/21/20 02:20 AM Re: 09 cvpi stalls immediately after startup [Re: imit8n_bcn]
2008interceptor Offline
Loc: Pennsylvania
After a disconnect the vehicle will run in closed loop. Then it will start to use the input from sensors one by one as it runs. So many things could cause it you'd almost need to have a live data scan going. In order to see what is out of spec. Other than making sure there's no buildup or a damaged wire/connection on the maf and iat, sensors idle air control as well if you have one. No iac if it's on your 09 p71 DBW eliminated that. Beyond that check the plugs and boots for evidence of not running right . Also carbon strikes on the porcelain indicating something is leaking past the boot. After it has run awhile it should compensate for whatever is off and run as before. Have you had the codes checked you may have active or history even without a light illuminated.
Here is a link to a post on here for relearning the drive by wire. https://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2856177
Edited by 2008interceptor (06/21/20 02:23 AM)
#4068210 - 06/21/20 08:23 AM Re: 09 cvpi stalls immediately after startup [Re: imit8n_bcn]
imit8n_bcn Offline
Loc: SW Ontario
I should also add that there was a pretty good spark on the negative battery terminal when I hooked her back up..
#4068230 - 06/21/20 11:36 AM Re: 09 cvpi stalls immediately after startup [Re: imit8n_bcn]
metro21 Offline
Loc: CA
What was the engine code you were trying to erase?
Current Panther: White 2007 CVPI SAP, 165k, Former State DOJ Admin Car
Formerly Owned Panthers: Gold 00 CVPI SAP and Black 05 CVPI SAP.
#4068244 - 06/21/20 03:32 PM Re: 09 cvpi stalls immediately after startup [Re: imit8n_bcn]
imit8n_bcn Offline
Loc: SW Ontario
My other post a week or so ago explains the situation. 3 spark plugs were melted out. Engine is trash. I'm putting a 2000 mustang gt engine and 5 speed transmission in it.
I discovered the issue is maf sensor related. Unplugging it solved my issue.
1 registered (magic), 91 Guests and 248 Spiders online.
bluejay_32 196
BigMerc96 86
Old_Guy_Stu 83
a_d_a_m 73
Ponyguy 60
Moby_Vic 59
Psxmoe 49
Bangster 42
124neta 42
ClayBelt 41
