#4068196 - 06/21/20 04:31 AM Swapping '07 4.6 from Town Car into 99 Town Car
99SigTownie Offline
Loc: Oregon
As the title say's I am looking to swap my old and busted 1999 npi for a 2007 PI 4.6 and looking for information about the swap since the years are significantly different.
Is there any links to a similar project? what should I look out for? Oh and mine is a Romeo V8 4.6
Thanks.
Edited by 99SigTownie (06/21/20 05:46 AM)
#4068228 - 06/21/20 11:31 AM Re: Swapping '07 4.6 from Town Car into 99 Town Car [Re: 99SigTownie]
Pretty straightforward. You are going to use most of the external stuff from the '99, oil pan, exhaust manifolds, fuel rails and injectors, all of the '99 wiring and computer, and the '99 TB and plenum. Basically you will be using the '07 long block and intake. The '99 computer and harness will run the '07 engine just fine, but there would be some power to be gained by getting it tuned to take advantage of the PI engine's extra airflow. Its been done many times, but I am struggling to find a link at the moment. The closest one I can think of would be ChevyGuy, he put a '04 GMQ engine in his '96 Town Car, it ran off the stock computer but he did use a '01-'02 MAF. That was several years ago now.
#4068284 - 06/21/20 10:27 PM Re: Swapping '07 4.6 from Town Car into 99 Town Car [Re: 99SigTownie]
99SigTownie Offline
Loc: Oregon
I remember that one! Is there some sort of hand held tuner or would I need to do it some other way? All the ones I've found were for 05+..And I'll go out and start soaking down those exhaust bolts, those are notorious on everything for breaking.
#4073714 - 08/10/20 08:36 PM Re: Swapping '07 4.6 from Town Car into 99 Town Car [Re: 99SigTownie]
99SigTownie Offline
Loc: Oregon
I am finally getting my new engine tomorrow it is from a 2007 Lincoln Town car, Vin W, 103k on it, 180 compression all around...
#4073816 - 08/11/20 11:01 PM Re: Swapping '07 4.6 from Town Car into 99 Town Car [Re: BigMerc96]
99SigTownie Offline
Loc: Oregon
Can I use my cam covers off my 1999?
There is a crack in the passenger side cam cover. (And they are just plain Ugly)
Edit...Yeah found out I can't...
So far I got the wiring off it, and now I'm working the exhaust studs loose, I got all but one on passenger side popped loose, I sprayed em down with pb blaster and tightened em back up...definitely don't just pull each one out thats how they break!
Edited by 99SigTownie (08/12/20 01:41 AM)
#4074044 - 08/13/20 06:25 PM Re: Swapping '07 4.6 from Town Car into 99 Town Car [Re: 99SigTownie]
99SigTownie Offline
Loc: Oregon
https://flic.kr/s/aHsmQ1iX1g
Here is some photos of it, I will be adding more later today.
#4074910 - 08/20/20 05:11 PM Re: Swapping '07 4.6 from Town Car into 99 Town Car [Re: 99SigTownie]
Charlie_Mercury Offline
Loc: Hammond, LA
Very Nice.
#4074912 - 08/20/20 05:12 PM Re: Swapping '07 4.6 from Town Car into 99 Town Car [Re: 99SigTownie]
Loc: Hammond, LA
Very Nice.
#4075002 - 08/21/20 10:45 AM Re: Swapping '07 4.6 from Town Car into 99 Town Car [Re: 99SigTownie]
MIHAYLA Offline
Loc: UA
Use the best exhaust manifold gaskets. Subsequently replaced it will be very difficult.
MGM92
LTC05
#4082862 - 11/02/20 01:08 AM Re: Swapping '07 4.6 from Town Car into 99 Town Car [Re: MIHAYLA]
99SigTownie Offline
Loc: Oregon
I'm using new gaskets and new studs...Which will be temporary anyways since I might get a used SW exhaust headers back next summer. My town had to evacuate due to a wild fire which set the build back a few months...But I'm using the time over the winter to stock up on parts...Mostly replacement parts as the car was never maintained mechanically. I need to look into getting at least a hand held tuner so I can use my 24# injectors and make the most of the PI engine and upgrades.
0 registered (), 20 Guests and 253 Spiders online.
bluejay_32 223
Old_Guy_Stu 120
a_d_a_m 99
DudeAbides 91
Ponyguy 71
CrystalPistol 45
Moby_Vic 44
ClayBelt 43
Davidzq 43
Bangster 37
