#4068234 - 06/21/20 12:15 PM Ignition Coil Relay Feed Fuse popping
Gnargoyle84 Offline
Loc: Redding California
09 CVp71 with over 150k(not exactly sure cause I have the old lights out on the odometer).
The 15A Ignition Coil Relay Feed(number 5 on a fuse diagram) pops just when turning the key. It use to pop every so often, like once a year. Then it went to every few months, now its every few mins. I Suspected a exposed wire so I started the hunt. I believe I found it. Ill post two pix. One shows the exposed wire and another shows the cluster its apart of. The exposed wire loops back on itself, which is odd and could be a result of them ripping the "cop gear" out. I suspect its this wire because I got it started after messing with wires, but when I wiggled this cluster the fuse popped and the car shut off.
Its strange because I've tried taping the wire away from the others, twisting it on itself and having it touch the other covered wires. Anyway here's the pix to better explain. any help on what this is or why and how to make this damn fuse stop popping would save me from frustration that may lead to the next apocalypse.
#4068250 - 06/21/20 03:40 PM Re: Ignition Coil Relay Feed Fuse popping [Re: Gnargoyle84]
You can't attach images here...the new owners broke that feature a couple of years ago and won't fix it. Get you an imgur account or similar.
0 registered (), 62 Guests and 228 Spiders online.
bluejay_32 196
BigMerc96 86
Old_Guy_Stu 82
a_d_a_m 71
Ponyguy 60
Moby_Vic 58
Psxmoe 49
124neta 42
Bangster 42
ClayBelt 41
