#4068686 - 06/25/20 06:01 PM
Fred's 1999 MGM
Loc: NY
This introduction to my car is long over due. But to be honest when I got the car I did not know if it would last long enough to justify a topic on here. Story is I got the car august 1 2019 with 110k miles on it. My previous vehicle died and I was having to bum rides to work as I desperately searched craigslist 1000 times a day refreshing every 30 seconds for days in all my spare time. Just as my rides were going to run out I refreshed and this 1999 MGM appeared for 800 dollars. I emailed him in an instant because it was the first car that said it was road worthy for under 1000 dollars which was all the money I had. I was scared because the guy did not mail me back for hours. He said he got about a dozen mails but I was the first one so he granted me to first look at the car. I went to look at the car and I could see it needed work but was solid and had low miles and ran great. The power steering was messed up he said it needed a pump it was hard to steer. Turned out the pump was fine it just needed the entire front end rebuilt. I paid 800 cash money for the car. I have always been kind of handy with cars but so far this car is the most ive worked on and I learned many things already doing jobs I never tried before. So far I did the following work Starter Coils plugs ball joints front wheel bearings alternator Idler arm inner and outer tie rods rear springs All 4 shocks all brake pads All rotors Front sway bar end links Down stream O2 sensors Other stuff is I changed oil twice now, Cleaned MAF sensor, put on crappy cold air intake from ebay because the stock air box was rusted and the clips were broken so it would not seal, Front end alignment, did a rear end oil change with new gasket, Port and polish plenum, 70mm throttle, install 18 inch steel wheels with 1.5 inch spacers and mountaineer hub caps, Im sure im forget something but thats the most of it. I am also painstakingly wire wheel/ wire brushing the whole frame/underside and painting it with eastwood rust encapsulator platinum then top coating with regular rust encapsulator. I am probably 1/2 done with this. after that I am going to buy the stuff you spray into the frame with a long tube on the can. THIS to me is most important because regardless of how crappy the car looks it is very clean as far as rust. The only rot on the car is the front fenders. I lost too many vehicles to the upstate NY rust and this is the first time I am going on full attack mode to try and save it from the rust death. After I get new fenders on it I am going to try and save up to have it painted maybe. The guy who owned it before me spray painted most of the chrome black. I just touched it up because it was flaking. Car has a lot of random small dents and scrapes because the guy I bought it from said the first owner was old and couldnt drive good so banged it up a lot. Future plans are dual exhaust, Jmod, rear gears and a tune. It has 120k miles on it now. Last 3 pictures are the oldest ones I have. That was right after I put the new springs on the back and shocks all around. Before that the back was sagging way low but otherwise looks just for it did when I bought the car.
#4068770 - 06/26/20 03:37 PM
Re: Fred's 1999 MGM
[Re: Freddy12189]
Was the car black from the factory or was it repainted at some point? Don't see too many black '98-'02 GMQs. I dig the way the 18s look on it, would look really slick with some chrome trim rings. Not sold on the total black-out though. These things need at least a little chrome trim IMO, again I think trim rings would look good for that reason. The good thing is its easy to swap things around and completely change the look. Fender rust is just about unavoidable. Its like they designed them to rust. My '98 is originally a southern car and the only real rust on it is the front fenders. It always starts in the center above the wheel, must be a pinch weld or something there that collects moisture. Lastly, its always good to see anyone willing to preserve these cars. Especially the older ones. Surely this car has been saved from an unfortunate, painful, slow death. Or the derby, where so many neglected but solid and salvageable Panthers have died.
#4068774 - 06/26/20 03:44 PM
Re: Fred's 1999 MGM
[Re: BigMerc96]
And in a salt state, too. But preservation is a lot easier than putting new floors in.
 1988 CVLX Formal Roof (Love Boat) POTM July 2019 & Aug 2020, 54K E-code lights w/ relays, LEDs w/ switchbacks, 15x8 Ansen slots w/ 255/60 BFG's, Kenwood stereo, various hacks. 1988 CVLX (Destroyer) 1998-2001 driven to death 202K 1988 Squire (Chris Craft) 1996-1998 junkyard rescue driven to death 199K
#4068782 - 06/26/20 05:34 PM
Re: Fred's 1999 MGM
[Re: BigMerc96]
don't get riled, sugar!
Loc: Il
A lot of livery services bought them in black, but yeah its not very common. To be fair, there weren't many Non police vics in black either. Ditto on the chrome, if it were me, I'd be keeping an eye out for a 03-05 merc front end if I was gonna replace those fenders. But I'm biased. I've always thought of the 98-02's like the ugly middle child of the best aero(95-97) and the best whale(03-05).
#4068784 - 06/26/20 05:43 PM
Re: Fred's 1999 MGM
[Re: BigMerc96]
Loc: NY
Was the car black from the factory or was it repainted at some point? Don't see too many black '98-'02 GMQs. I dig the way the 18s look on it, would look really slick with some chrome trim rings. Not sold on the total black-out though. These things need at least a little chrome trim IMO, again I think trim rings would look good for that reason. The good thing is its easy to swap things around and completely change the look. Fender rust is just about unavoidable. Its like they designed them to rust. My '98 is originally a southern car and the only real rust on it is the front fenders. It always starts in the center above the wheel, must be a pinch weld or something there that collects moisture. Lastly, its always good to see anyone willing to preserve these cars. Especially the older ones. Surely this car has been saved from an unfortunate, painful, slow death. Or the derby, where so many neglected but solid and salvageable Panthers have died.  I am not sure if it was originally black. Is there a way to tell for sure? If it was repainted then they did a good job because I dont see any signs of it being another color like you can sometimes in the door jams etc. I agree with the chrome issue. I actually have an NOS grill on its way to me now so I can see what it will look like on the car. The rings on the wheels is a great idea I didnt think of. About the rust I think the car spending most of its life in Vermont is what saved it. Floor pans and trunk are almost perfect still. Frame had some light scale in spots but nothing that failed the hammer test. My first "nice" vehicle was a 97 explorer that I got from a dealership and took such good care of it and after 10 years up here everything behind the rear end could smash through with a hammer and the rockers were gone all the way to the door seals among other rust issues. That explorer was 110% great mechanically thats why it made me so mad and curse road salt and swore to never buy a "nice" car again. Paying a lot for a car up here is like throwing money away. This car is going to put that rust encapsulator to a real world test.
#4068890 - 06/27/20 02:43 PM
Re: Fred's 1999 MGM
[Re: Freddy12189]
Loc: Broad Brook, CT
You would have to check for the exterior paint color code on the driver's door sticker to verify if it was black originally or not. It would be a two letter code also.
2000 Ford Crown Victoria LX "HPP" - Harvest Gold - Medium Parchment Leather
#4068894 - 06/27/20 03:23 PM
Re: Fred's 1999 MGM
[Re: Freddy12189]
Loc: NY
Here is the inside door sticker  Does it say here?
#4068908 - 06/27/20 07:48 PM
Re: Fred's 1999 MGM
[Re: Freddy12189]
Loc: Il
EXT PNT is the paint. UA appears to be black. As you said before, Unless its resprayed the same color, its almost always going to be riddled with tell tale signs of original color, even if the jamb/underhood is painted. Anyone who can afford a color swap that can go undetected isn't driving a panther.
#4068910 - 06/27/20 07:49 PM
Re: Fred's 1999 MGM
[Re: Freddy12189]
Yes, where it says EXT PNT: UA, in the lower left hand corner. That UA stands for Black for the exterior paint color.
#4068974 - 06/28/20 07:45 AM
Re: Fred's 1999 MGM
[Re: Freddy12189]
Nice resurrection, Fred.
Black is definitely uncommon for the '98-02 civ cars, but they're definitely out there. I passed on a black 1998 MGM HPP/LS before buying the 2010.
'91 LTD Country Squire (POTM Mar. '19) | '03 Marauder (POTM Nov. '10, Jul. '20) | 2010 P7Bformerly: '02 MGM, '04 MGM, '04 MGM v2.0, '04 MM, '07 P71 (POTM Feb. '18), '04 CVLX (POTM Jun. '19 and the best car ever), '03 SAP P71
#4069026 - 06/28/20 06:30 PM
Re: Fred's 1999 MGM
[Re: Freddy12189]
Nice car! Keep up the good work with maintenance. She will last you a long time still.
-Current: 2001 Crown Victoria P74  -Gone, but not forgotten: 1988 Mercury Grand Marquis 1994 Ford Crown Victoria 2000 Ford Crown Victoria HPP 2004 Ford Crown Victoria LX Sport 2004 Mercury Grand Marquis
#4069316 - 07/01/20 06:58 PM
Re: Fred's 1999 MGM
[Re: Freddy12189]
#4069658 - 07/04/20 07:02 PM
Re: Fred's 1999 MGM
[Re: Freddy12189]
Loc: NY
I am gathering parts to put on when im on vacation next week. Got a dorman trans pan with drain plug and a filter for trans, steel braid brake hoses, LED bulbs for inside and cluster, better rear shocks, parking brake hardware and shoes... Gotta figure out what to do about a radio because it has none and someone cut all the wires so no plug anymore.
2 registered (Prospect62, ClayBelt),
35
262
