#4069974 - 07/07/20 04:27 AM Engine swap
wt205 Offline
Loc: Alabama
my 2000 p71 engine took its last run I have a replacement out of a 09 p71 is it possible to swap motor and trans if so what is needed to make it work?
#4070110 - 07/08/20 08:29 PM Re: Engine swap [Re: wt205]
dixiebandit69 Offline
Loc: Texas
Just swap the '09 engine in, but use all the sensors from the '00.
Also, transfer the throttle body from the '00, because it's a cable throttle.
Transmission is a different story; don't try it.
#4070176 - 07/09/20 08:23 AM Re: Engine swap [Re: wt205]
wt205 Offline
Loc: Alabama
OK thanks that was my biggest concern👍👍
6 registered (2004_p71, ford05, 124neta, Bellwestern80, AnthoP71, 1 invisible), 59 Guests and 368 Spiders online.
bluejay_32 196
BigMerc96 79
ClayBelt 77
Old_Guy_Stu 66
a_d_a_m 65
Moby_Vic 62
Ponyguy 59
TheCableGuy 56
Psxmoe 47
RF_Overlord 33
