#4071884 - 07/25/20 02:21 PM Transmission Range Sensor Replacement Questions
05ric Offline
Loc: CA
I have a 2007 LTC
Im looking at the service manual for the trans range sensor replacement and it says to remove the selector cable. I dont understand why I have to do this if the trans range sensor is only held on by two bolts and the connector, is this step necessary?
Heres the diagrams
https://www.chiltonlibrary.com/content/images/Ford/S5A/S5A71041.pdf
Edited by 05ric (07/25/20 02:23 PM)
#4071964 - 07/26/20 08:19 AM Re: Transmission Range Sensor Replacement Questions [Re: 05ric]
TheShadow Offline
Loc: SoCal High Desert
Probably because it eliminates the column shifter and it's various locks. Makes it easier to locate the tranny-side shifter in the proper gear while under the car...neutral to align the sensor. I don't believe I've ever tightened the cable adjuster nut in anything other than neutral, though, so the shift from neutral to OD (D) is possibly to take out any potential cable slack.
#4072000 - 07/26/20 12:30 PM Re: Transmission Range Sensor Replacement Questions [Re: 05ric]
How are you going to replace the range sensor if you do not remove the shifter cable from it?
#4072048 - 07/27/20 05:53 AM Re: Transmission Range Sensor Replacement Questions [Re: GM_Guy]
TheShadow Offline
Don't forget, the range sensor just sits on the shaft end, and has no physical connection to the cable.
OP: Here's an acceptably decent video, although he doesn't mention that the sensor has slots for the mounting screws, to allow for rotation of the sensor for the actual alignment:
https://www.bing.com/videos/search?q=rep...l&FORM=VIRE
Edited by TheShadow (07/27/20 05:56 AM)
5 registered (vin48, magic, LTC_Dave, 3fords1, 1 invisible), 56 Guests and 263 Spiders online.
bluejay_32 192
BigMerc96 78
ClayBelt 75
Old_Guy_Stu 66
Ponyguy 61
TheCableGuy 58
Moby_Vic 57
a_d_a_m 57
Psxmoe 43
RF_Overlord 36
