#4071902 - 07/25/20 05:01 PM 85 CV trunk help
black396 Offline
Loc: fl usa
My 85 CV has the "trunk release" button in the glove box, but, when pressed, nothing happens. It would be nice to transplant the auto pull down mechanism from mid 80s Lincolns. Anyone done that who will chat about the issues?
Charles
#4071956 - 07/26/20 06:37 AM Re: 85 CV trunk help [Re: black396]
Old_Guy_Stu Offline
Can't help much with the pulldown, but I know you'll need a constant-hot power line going back there to run it. For the release, grab a test light and see if the actuator is getting power when you push the button. That'll tell you what to look at next.
1988 CVLX Formal Roof (Love Boat) POTM July 2019 & Aug 2020, 53K
#4071988 - 07/26/20 10:51 AM Re: 85 CV trunk help [Re: black396]
The pull-down motors were basically the same from the '80s well into the '90s (at least thru '97, probably later, my '97 has one). Its a simple setup, the latch on the trunklid is pretty much the same as a normal one, except it has an extra switch on it that serves as a limit switch. The pull down motor replaces the striker assembly on the body, that also has a limit switch or 2 on it. When you pop the trunk the switch on the latch tells the pull down motor to move the striker up until it hits the switch in the motor assembly. When you close the trunk, it hits the switch on the latch which tells the motor to pull the striker down until it hits another limit switch when it gets to the "closed" position. The '97 FSM makes it sound more complicated than that, with it talking to the LCM, but I suspect that is simply for the trunk open warning on the dash and maybe the trunk light. I'm pretty sure it is simply just the switches and relay that actually do the "magic".
5 registered (vin48, magic, LTC_Dave, 3fords1, 1 invisible), 56 Guests and 263 Spiders online.
bluejay_32 192
BigMerc96 78
ClayBelt 75
Old_Guy_Stu 66
Ponyguy 61
TheCableGuy 58
Moby_Vic 57
a_d_a_m 57
Psxmoe 43
RF_Overlord 36
