#4072110 - 07/27/20 11:36 PM 4r75e transmission help
allanworks Offline
Loc: MI
I am rebuilding a 4r75e transmission for my 08 crown vic. the direct drum went together easily with minimal air loss during the air pressure test and the reverse drum leaks a little more than the direct drum but still engages fine. my issue is when air testing the forward drum after rebuild a lot of air is flowing from the center shaft area the clutch is engaging but it has a leak somewhere I can't figure out. when assembling the pump, reverse and forward clutch for testing I feel the forward gear slide threw all three of the reverse friction plates so as far as I can tell it is fully seated. also, all the seals and rings are new. please, somebody, help me this is driving me up a wall.
#4072150 - 07/28/20 02:09 PM Re: 4r75e transmission help [Re: allanworks]
Lance01 Offline
Loc: Pa
Not the transmission expert but did you use the special tools to install the seals? Also, you need to use transmission assembly lube liberally. As far as actual help go on YouTube there are some good videos online now showing the entire rebuild process. A new 4r70w video by a guy named Gary over in NY just uploaded a good one.
https://www.lubegard.com/products/goo/
https://transmissioncenter.net/shop/set-...s-in-the-drums/
#4072164 - 07/28/20 04:33 PM Re: 4r75e transmission help [Re: allanworks]
allanworks Offline
Loc: MI
i'm doing the install watching transmission bench on youtube. i'm using transmission fluid like the guy in the video. no i didnt buy the seal guards their not realy required if you take your time plus i cant afford it after buying everything.im pretty sure the drum piston seals are fine i checked the shaft seals and they look good. the only thing i can think of is something isnt seated completly. i dont know its driving me up the wall.
#4072168 - 07/28/20 05:11 PM Re: 4r75e transmission help [Re: allanworks]
Lance01 Offline
Loc: Pa
4r70w Assembly video:
https://youtu.be/bGzCEpkU9OA
Edited by Lance01 (07/28/20 05:16 PM)
#4072174 - 07/28/20 06:03 PM Re: 4r75e transmission help [Re: Lance01]
allanworks Offline
Loc: MI
yea i checked him out after you mentioned him. he is not as thourough as the guy i'm watching.
#4072176 - 07/28/20 06:11 PM Re: 4r75e transmission help [Re: allanworks]
allanworks Offline
Loc: MI
#4072184 - 07/28/20 07:25 PM Re: 4r75e transmission help [Re: allanworks]
88grandmarq Offline
4R70W rebuilder
Inspect the front pump stator sealing rings, the lower ones seal to stator to the inside of the forward clutch drum. Make sure you are using the latest style nylon butt cut rings and gaps are staggered on each ring.. Meaning turn the rings gaps 180 degree opposite of each other. also inspect the stator ring lands for any debris or burrs/nicks. I use a small nail file and clean up the machined surface so its not so sharp and makes it more smooth. Any nicks in the ring land will cause the ring to hang up and not expand fully, which leads to sealing issues.
https://www.facebook.com/silverfoxtrans/videos/1735932070047852/?t=8
#4072192 - 07/28/20 08:19 PM Re: 4r75e transmission help [Re: 88grandmarq]
allanworks Offline
Loc: MI
i have the black butt rings not sure what their made of. the gaps are spaced on oposite sides and she still leaks.ill try to find the blue nylon one from the video but so far not having any luck.
Edited by allanworks (07/28/20 08:44 PM)
#4072202 - 07/28/20 10:25 PM Re: 4r75e transmission help [Re: allanworks]
88grandmarq Offline
4R70W rebuilder
blue rings from the video are pre-production. still in development. Video was to demonstrate how effective they are.
As I mentioned, make sure the pump stator ring lands are in good shape, they need to smooth and no nicks.
#4072218 - 07/28/20 11:00 PM Re: 4r75e transmission help [Re: 88grandmarq]
allanworks Offline
Loc: MI
yea, everything is new and in good shape from what i can tell no cuts scratches or nicks.
#4072266 - 07/29/20 02:09 PM Re: 4r75e transmission help [Re: allanworks]
sr53 Offline
Loc: Ga
Make sure you have the right rings for your pump stator, they changed in 2004
5 registered (vin48, magic, LTC_Dave, 3fords1, 1 invisible), 56 Guests and 263 Spiders online.
bluejay_32 192
BigMerc96 78
ClayBelt 75
Old_Guy_Stu 66
Ponyguy 61
TheCableGuy 58
Moby_Vic 57
a_d_a_m 57
Psxmoe 43
RF_Overlord 36
