#4072584 - 08/01/20 10:31 AM Air Bag Questions
Lizzies Offline
Loc: Kentucky
Hello everyone.
Im new to this forum so if this isn't the place to post this, please correct me.
Anyway, I have a 2000 Crown Victoria P71, and few days ago the tumbler connected to my ignition cylinder in my steering column broke, so I had to replace the entire steering column. Unfortunately the only parts I could find in any local junkyard was a 2000 Mercury Grand Marquis. It fit properly and everything works, except my airbag light will blink a few times, then stay on. It seemed to blink 1 time, pause, then 3 blinks. I believe this means the airbag is shorted straight to ground. It seems the connector on my new steering column aren't the same as the original Ford airbag so I can't place the Ford airbag back into the new wheel. Do you think the airbag will still work or should I disconnect it so it doesn't blow up on me randomly?
Thank you for your thoughts,
Lizzies
#4072812 - 08/03/20 10:18 AM Re: Air Bag Questions [Re: Lizzies]
Lizzies Offline
Loc: Kentucky
Originally Posted By Lizzies
Hello everyone.
Lizzies
After taking a closer look, it seems the airbag Blinks 3 times, then twice. It repeats this several times then the light stays on. I looked up that code and it says the airbag has high resistance. Do you think it will still work?
3 registered (Jacques, LTC_Dave, Darkant), 53 Guests and 101 Spiders online.
bluejay_32 97
Armada Master 86
Old_Guy_Stu 74
Moby_Vic 59
Dmblanch 57
DudeAbides 50
a_d_a_m 47
SocalSam 44
Ponyguy 40
