#4075360 - 08/24/20 11:54 AM Missing bolts on aluminum crossover?
VoodooChild Offline
Loc: Northeast
Had the intake manifold done twice to this car now. I noticed the aluminum crossover is missing a couple bolts? Should I throw some in there or could there be a reason my mechanic left them out?
2001 LX 144k -
Lincoln Chaffee's former protective car, RI State Police (sold)
2011 Interceptor 120K, 11k Idle hours -
Former Newton, MA patrol car
Alpine 6x9 rear speakers
Rockville 10" 800w powered subwoofer
Dash Cam w/ backup cam
3.55 Limited Slip, Moog Sway Bar end links and bushings, Mevotech Supreme control arms
Ported stock plenum, LED backup and dome lights, RKE
#4075388 - 08/24/20 06:19 PM Re: Missing bolts on aluminum crossover? [Re: VoodooChild]
Bangster Offline
Are you sure they are missing, is there a place to thread them in the crossover, or are they holes for the thermostat neck bolts? Would love to see a picture or which ones are missing, I have a lot of images of dissected intakes, OEM and aftermarket, maybe some that show the bolts, will have to see.
#4075390 - 08/24/20 06:27 PM Re: Missing bolts on aluminum crossover? [Re: VoodooChild]
Bangster Offline
This is an nPI Dorman but I am pretty sure the crossover is the same even for an OEM PI intake:
passenger side:
drivers side (only one bolt in mine and if I remember that makes sense with the mounting bolts/thermostat housing bolts):
#4075392 - 08/24/20 06:44 PM Re: Missing bolts on aluminum crossover? [Re: Bangster]
VoodooChild Offline
Loc: Northeast
I'm stumped.
2001 LX 144k -
#4075394 - 08/24/20 06:47 PM Re: Missing bolts on aluminum crossover? [Re: VoodooChild]
VoodooChild Offline
Loc: Northeast
Guess that won't show.
Maybe this will.
https://ibb.co/C5xvmBc
2001 LX 144k -
#4075400 - 08/24/20 08:08 PM Re: Missing bolts on aluminum crossover? [Re: VoodooChild]
Bangster Offline
The bolts come up from the bottom, so the heads are under it. You should be able to see the heads from the side or if there is the end of the bolt.
#4075404 - 08/24/20 08:39 PM Re: Missing bolts on aluminum crossover? [Re: Bangster]
VoodooChild Offline
Loc: Northeast
I see, thank you! That puts me much more at ease. The guy I had put it in always does great work, but I've never done an intake and that was really puzzling to me haha.
2001 LX 144k -
#4075406 - 08/24/20 08:43 PM Re: Missing bolts on aluminum crossover? [Re: VoodooChild]
CrystalPistol Offline
OK, I see your pic after I opened it, looks like you're just seeing the unused portion of the tapped holes, if there is a bolt in them, it comes from underneath … and try poking a small wire in them two holes, should hit the bolt's end … if you can't see the ends.
Edited by CrystalPistol (08/24/20 09:12 PM)
6 registered (dkswift, Quasar, YoungP71dude, BlackVic_P71, a_d_a_m, 1 invisible), 68 Guests and 172 Spiders online.
bluejay_32 194
a_d_a_m 141
Old_Guy_Stu 125
DudeAbides 90
Ponyguy 64
Davidzq 47
Moby_Vic 45
LTC_Dave 39
ClayBelt 37
