#4075476 - 08/25/20 01:57 PM 2005 P71 - 4R70W shifter cable bracket
shipracer Offline
Loc: California
Hello! for the trans experts.
When i parked and started to get out of the car it was still in reverse some how. I put it in neutral, ebrake on, turned the car off.
looked at the shifter cable bracket and one bolt was on the ground, another was loose. two 10MM small bolts
Neither would tighten at all (but they screw in real nice, just never get tight).
I screwed them back in few days later the same thing. Im looking at adding some loctite...
am i missing washers there? or wrong bolts maybe?
05-P71-300k+ Chassis - Vortech V3 intercooled, Rebuilt Level 4 Transmission from Darrin, edge racing 2800 high stall torque convertor, Heinous Billet rear upper/lower control arms, Spice ujoints, new watts linkage, new rear shocks, new control arms(up/low), New Rack&Pinion, Reinhart(87), BOC(87), MPT(91), Mo'sSpeedShop(91) Tunes, JMOD - (1/2, 2/3 spring removed, all holes drilled) redone by BCA now with a 1/2 spring, New front lights(side/head), Staggered PICO widen 17inch tires 285/40/17, Steeda pulleys(no alt pulley, 1 size smaller gates belt)., New Rotors, calipers and pads. 4.10 gears (carbon), forced lube mod, balanced driveshaft, Moog front/rear sway bar control arms. Ford racing intake, AUX transmission cooler.
#4075500 - 08/25/20 05:32 PM Re: 2005 P71 - 4R70W shifter cable bracket [Re: shipracer]
Hey, ship!
Could be the wrong bolts, or could be they were stripped on installation. Unfortunately, the FSM doesn't call out the bolt specs, other than torque.
#4075502 - 08/25/20 05:52 PM Re: 2005 P71 - 4R70W shifter cable bracket [Re: shipracer]
shipracer Offline
Loc: California
RF Where the F have you been and thanks!
Looks like it might be stripped, metal in the bolt itself.
Picture: https://drive.google.com/file/d/1jcjLtUFvJfxrF_yDewaoUYXMro8RtBQK/view?usp=sharing
#4075508 - 08/25/20 08:11 PM Re: 2005 P71 - 4R70W shifter cable bracket [Re: shipracer]
Google Drive is telling me "access denied"
#4075602 - 08/26/20 11:31 AM Re: 2005 P71 - 4R70W shifter cable bracket [Re: shipracer]
shipracer Offline
Loc: California
I opened up the share link permissions.
I ended up getting new bolts from home depot. They were slightly longer (with the hopes there were some threads not stripped or messed up at the end.).
It seemed to work. they torqued/got tight. I used a little blue loctite.
Time will tell if it actually worked.
#4075612 - 08/26/20 01:39 PM Re: 2005 P71 - 4R70W shifter cable bracket [Re: shipracer]
I can see the pic, now. Looks like they may have been loose for a while since there's aluminium material only in the upper few threads. Glad you got it sorted!
3 registered (bluejay_32, TheShadow, PatrickBateman), 64 Guests and 182 Spiders online.
bluejay_32 194
a_d_a_m 142
Old_Guy_Stu 125
DudeAbides 90
Ponyguy 64
Davidzq 47
Moby_Vic 45
LTC_Dave 39
ClayBelt 37
