#4075634 - 08/26/20 04:55 PM need to replace fuel pump
fts1966 Offline
Loc: Missouri
new here. 2000 Mercury Gand Marquis. just bought it after 1,800 miles it died on the highway had it towed and they said the fuel pump is dead. They want $1,200.00 for pump and Labor the will not use after market parts. I'm having towed to my house this afternoon. So okay what pump are the people in the group using and any issues. I'm sure there are better priced ones out there.
Frank S.
#4075710 - 08/27/20 11:37 AM Re: need to replace fuel pump [Re: fts1966]
Delphi, Bosch are usually good...the Ford one that I found at Autozone is only $358 and that is the pump with the whole sender assembly.
#4075724 - 08/27/20 11:48 AM Re: need to replace fuel pump [Re: fts1966]
Bangster Offline
Unless it is a rusty mess should take about an hour, I got a Bosch generic one that required me to splice it in, it at least survived another 100,000 miles, I am sure it would still be going but I junked the car.
97 Cougar 4.6 Sport (RIP)
89 Cougar LS (RIP)
63 Falcon 302
82 F-150
97 Mark VIII LSC (RIP)
2017 Escape SE (RIP)
2012 Fusion Sport AWD
#4075772 - 08/27/20 06:37 PM Re: need to replace fuel pump [Re: fts1966]
I put a Delphi "universal" pump in the OEM assembly in the Town Car, it came with an adapter connector that plugged right into the stock sending unit and works just fine. The '98 came to me with a complete Delphi assembly, again, no issues.
Don't let the horror stories about needing to drop the tank scare you. It is not required if you're prepared to fight a little bit getting the pump out of the tank with it in-place. I had to unbolt the passenger side rear shock and lower the axle down to gain clearance, if the Townie had the drivers side tail pipe on it at the time, that probably would have been in the way too (it rotted off a week before the pump died and got reinstalled once the car was running again), but I'm sure at most you would need to unbolt the exhaust hangers so you could push it out of the way. I would MUCH rather deal with loosening a shock and a couple exhaust hangers over dropping a tank out of one of these cars.
#4075774 - 08/27/20 06:45 PM Re: need to replace fuel pump [Re: fts1966]
RipWixomAssembly Offline
Loc: Michigan
These cars came OE with a Bosch Fuel Pump according to RockAuto. You can get a complete Bosch pump with the housing, the sender and the fuel sock and all the wires. Now you can get just the pump and a universal connector for around $53.89. Both these prices are without shipping. The $53.89 non complete housing does not come with a fuel strainer or fuel sock as it's called also. You have to buy a fuel sock separately.
Edited by 95TownCar (08/27/20 06:54 PM)
My Rides:
#4075778 - 08/27/20 06:49 PM Re: need to replace fuel pump [Re: fts1966]
Psxmoe Offline
Another vote for Delphi or Bosch.
Stay away from Airtex. Ive also had bad luck with precision brand fuel pumps from Oriellys.
2006 CVPI SAP 79,000 Miles
2004 Jeep Grand Cherokee WJ Laredo 4.0l 2wd 188K
2015 Jeep Cherokee KL Sport 2.4l 2wd 52k
#4075786 - 08/27/20 07:33 PM Re: need to replace fuel pump [Re: fts1966]
Freddy12189 Offline
Loc: NY
on a site called partsgeek.com I got the tank, sender, pump, and tank straps for 204.00 shipped. I dont know what brand they are but they work good. My tank was rusted and leaking and sender was rotted making gas gauge not work. Everything works now.
#4075792 - 08/27/20 08:00 PM Re: need to replace fuel pump [Re: fts1966]
Got a package deal from Rock Auto for a pump (with hat), tank, and new straps for $243 incl tax and shipping. Spectra brand. Installed in Dec of '19...so far, so good.
#4075824 - 08/28/20 12:17 AM Re: need to replace fuel pump [Re: fts1966]
Lance01 Offline
Loc: Pa
Make sure you replace the fuel filter as well. Use a Motorcraft filter.
#4075858 - 08/28/20 01:36 PM Re: need to replace fuel pump [Re: RF_Overlord]
Loc: Michigan
That's a good deal. Unfortunately it has been out of stock for a decent amount of time on RockAuto
My Rides:
#4075862 - 08/28/20 01:38 PM Re: need to replace fuel pump [Re: Lance01]
Loc: Michigan
Yep, For most fuel pump assemblies for the warranty they make you install a new fuel filter.
My Rides:
#4075868 - 08/28/20 05:57 PM Re: need to replace fuel pump [Re: fts1966]
I use NAPA Gold air and fuel filters (made by WIX). Oil filter is Motorcraft-only.
#4075892 - 08/28/20 10:29 PM Re: need to replace fuel pump [Re: fts1966]
TheCableGuy Online   content
Loc: Far Northwest AZ
+1 on Napa Gold
2010 P7B 162K. 12K hours. 3.27, RKE, Cruise, Ported stock plenum, JMod, ADTR sway bar, KYB rear shocks. DIY Headlight harness upgrade, with projector retrofit: Mini H1’s. Thrush Glasspacks.
2005 Pontiac Bonneville GXP- 90K- Work in progress
Previous rides:
#4075904 - 08/28/20 11:11 PM Re: need to replace fuel pump [Re: RF_Overlord]
Lance01 Offline
Loc: Pa
Yea, NAPA stuff is good.
