#4075634 - 08/26/20 04:55 PM need to replace fuel pump
fts1966 Offline
Loc: Missouri
new here. 2000 Mercury Gand Marquis. just bought it after 1,800 miles it died on the highway had it towed and they said the fuel pump is dead. They want $1,200.00 for pump and Labor the will not use after market parts. I'm having towed to my house this afternoon. So okay what pump are the people in the group using and any issues. I'm sure there are better priced ones out there.
Frank S.
#4075710 - 08/27/20 11:37 AM Re: need to replace fuel pump [Re: fts1966]
BlackVic_P71 Online   11
Delphi, Bosch are usually good...the Ford one that I found at Autozone is only $358 and that is the pump with the whole sender assembly.
#4075724 - 08/27/20 11:48 AM Re: need to replace fuel pump [Re: fts1966]
Bangster Offline
Unless it is a rusty mess should take about an hour, I got a Bosch generic one that required me to splice it in, it at least survived another 100,000 miles, I am sure it would still be going but I junked the car.
#4075772 - 08/27/20 06:37 PM Re: need to replace fuel pump [Re: fts1966]
I put a Delphi "universal" pump in the OEM assembly in the Town Car, it came with an adapter connector that plugged right into the stock sending unit and works just fine. The '98 came to me with a complete Delphi assembly, again, no issues.
Don't let the horror stories about needing to drop the tank scare you. It is not required if you're prepared to fight a little bit getting the pump out of the tank with it in-place. I had to unbolt the passenger side rear shock and lower the axle down to gain clearance, if the Townie had the drivers side tail pipe on it at the time, that probably would have been in the way too (it rotted off a week before the pump died and got reinstalled once the car was running again), but I'm sure at most you would need to unbolt the exhaust hangers so you could push it out of the way. I would MUCH rather deal with loosening a shock and a couple exhaust hangers over dropping a tank out of one of these cars.
#4075774 - 08/27/20 06:45 PM Re: need to replace fuel pump [Re: fts1966]
95TownCar Offline
Loc: Michigan
These cars came OE with a Bosch Fuel Pump according to RockAuto. You can get a complete Bosch pump with the housing, the sender and the fuel sock and all the wires. Now you can get just the pump and a universal connector for around $53.89. Both these prices are without shipping. The $53.89 non complete housing does not come with a fuel strainer or fuel sock as it's called also. You have to buy a fuel sock separately.
Edited by 95TownCar (08/27/20 06:54 PM)
-Giovanni
My Rides:
1995 Lincoln Town Car 129K miles. Mostly Stock with a Pioneer Radio and Speakers
#4075778 - 08/27/20 06:49 PM Re: need to replace fuel pump [Re: fts1966]
Psxmoe Offline
Another vote for Delphi or Bosch.
Stay away from Airtex. Ive also had bad luck with precision brand fuel pumps from Oriellys.
2006 CVPI SAP 76,000 Miles, 520 Hours, BH1976 HD Light Harness, 3.27 Trac-Lok, BF Goodrich g-force COMP-2 235/55R17
Pima County, Arizona
#4075786 - 08/27/20 07:33 PM Re: need to replace fuel pump [Re: fts1966]
Freddy12189 Offline
Loc: NY
on a site called partsgeek.com I got the tank, sender, pump, and tank straps for 204.00 shipped. I dont know what brand they are but they work good. My tank was rusted and leaking and sender was rotted making gas gauge not work. Everything works now.
#4075792 - 08/27/20 08:00 PM Re: need to replace fuel pump [Re: fts1966]
Got a package deal from Rock Auto for a pump (with hat), tank, and new straps for $243 incl tax and shipping. Spectra brand. Installed in Dec of '19...so far, so good.
#4075824 - 08/28/20 12:17 AM Re: need to replace fuel pump [Re: fts1966]
Lance01 Offline
Loc: Pa
Make sure you replace the fuel filter as well. Use a Motorcraft filter.
#4075858 - 08/28/20 01:36 PM Re: need to replace fuel pump [Re: RF_Overlord]
95TownCar Offline
Loc: Michigan
That's a good deal. Unfortunately it has been out of stock for a decent amount of time on RockAuto
-Giovanni
My Rides:
#4075862 - 08/28/20 01:38 PM Re: need to replace fuel pump [Re: Lance01]
95TownCar Offline
Loc: Michigan
Yep, For most fuel pump assemblies for the warranty they make you install a new fuel filter.
-Giovanni
My Rides:
#4075868 - 08/28/20 05:57 PM Re: need to replace fuel pump [Re: fts1966]
I use NAPA Gold air and fuel filters (made by WIX). Oil filter is Motorcraft-only.
#4075892 - 08/28/20 10:29 PM Re: need to replace fuel pump [Re: fts1966]
TheCableGuy Offline
Loc: Far Northwest AZ
+1 on Napa Gold
2010 P7B 150K. 11K hours. 3.27, RKE, Cruise, Ported stock plenum, JMod
#4075904 - 08/28/20 11:11 PM Re: need to replace fuel pump [Re: RF_Overlord]
Lance01 Offline
Loc: Pa
Yea, NAPA stuff is good.
8 registered (bluejay_32, Danger2manifold, a_d_a_m, dkswift, BlackVic_P71, 1 invisible), 79 Guests and 186 Spiders online.
bluejay_32 194
a_d_a_m 141
Old_Guy_Stu 125
DudeAbides 90
Ponyguy 64
Davidzq 47
Moby_Vic 45
LTC_Dave 39
ClayBelt 37
