#4076456 - 09/03/20 09:42 AM 10 Crown Vic cranking issue
CrownVic10DE Offline
Loc: DE
Hello,
Model: Crown Victoria
Manufacturer: Ford
Manufacturing year: 2010
Problem: starting system
Problem repetition: once a week
Problem discerption:
I face the problem when I start the car, I notice that the electricity disconnected for a couple of seconds while I am holding the ignition switch, then it continue cranking and the car started.
I made several repairs mentioned below but without success
Repair done so far:
- battery terminals were cleaned and tightened well
- Starter motor was disassembled and clean from sand.
- Starter solenoid replaced.
I am seeking your help if someone face same problem or any ideas that could fix the issue.
Attached is the video for the problem discerption:
https://youtu.be/D-wCneKdXIM
Edited by CrownVic10DE (09/03/20 10:07 AM)
#4076478 - 09/03/20 02:50 PM Re: 10 Crown Vic cranking issue [Re: CrownVic10DE]
Davidzq Offline
Loc: Seattle, WA
I would try removing and replacing the starter relay and fuse (pulling them out and back in will scrape off any corrosion on the terminals).
Also check the braided ground strap between the motor block and firewall, as this could be failing or have corroded terminals.
Otherwise, your starter motor may be getting weak and need replacement.
David Hensley
2008 P71, Norsea Blue SAP
-Long overhead console
5 registered (jmlock, slowlane, LTC_Dave, TheCableGuy, DudeAbides), 55 Guests and 101 Spiders online.
bluejay_32 97
Armada Master 86
Old_Guy_Stu 74
Moby_Vic 59
Dmblanch 57
DudeAbides 50
a_d_a_m 47
SocalSam 44
Ponyguy 40
