Page 121 of 121 < 1 2 119 120 121
#4055354 - 03/30/20 12:34 PM Re: let the 5.4 breathe [Re: 2004_p71]
Drac Offline
Cpt. Smug
Loc: Cali
banana banana banana
#4055536 - 03/31/20 10:49 AM Re: let the 5.4 breathe [Re: 2004_p71]
Do yourself a favor and grab a Ram clutch alignment tool!
The one that came with the clutch was trash and I couldn't get the input shaft of the transmission in properly because of it.
Being twin disc makes it more of a challenge.
Here's the 26-spline one I used (are you 10-spline?)
https://www.americanmuscle.com/ram-26-spline-clutch-alignment-tool.html
Pantherless since September 2019
1978 Ford Fairmont | soon to be 5.0L (Coyote)
2017 Ford Fusion SE | 2.5L
#4055932 - 04/02/20 08:32 AM Re: let the 5.4 breathe [Re: CNGInterceptor]
Thanks for the tip smile
My tr3650 was up graded with a 26 spline imput shaft smile
I have a universal clutch alignment tool that I used for all of the other manual swap I have done, I will see if it works smile
#4060082 - 04/23/20 10:27 PM Re: let the 5.4 breathe [Re: 2004_p71]
some more up dates smile
Got the diff out. Gonna ditch the ford's track lok in favor of an Eaton detroit truetrac .
I am keeping the 4.10 gears in there for now .
Diff is dusty so I an going to clean it and probably repaint it again to it,s former glory
Control arms seen better days too !
lots of overspray for the previous 2 paint job.
Bushings on the upper arms need to be replace as they are shot but it's a no brainer everything will be replaced and arms stripped from over spray.
when they were new against the stock control arms
I dropped the fuel tank to be able to paint the frame and I need to change the pump from a 255 to 340 lph .
By the time I receive these parts it will have enough time to clean the floor and repaint the whole thing .
#4079622 - 10/03/20 08:33 AM Re: let the 5.4 breathe [Re: 2004_p71]
I wont lie it's been on the back burner for a long time . Family time being a priority and dealing with other issues set me a few month back on this project .
Diff is a complete rebuilt with moser axles , eaton true track and diff 4,10 gears
floor pan and frame has been stripped from the flaky p51 jobI did few years ago and re coated in black .
new mcleod twin disc clutch and pressure plate plus new flywheel with ARP hardware .
That alone costed me a few grand righ away except the axle that were generously donated by a good friend of mine MR John smile cnginterceptor
lots of details and parts to buy along the way as everything is pretty much being replaced along the way so it,s a costly and lenghty process but Iwill get there !
#4079720 - 10/03/20 11:31 PM Re: let the 5.4 breathe [Re: 2004_p71]
Loc: Ventura County, CA.
woot
6 registered (Rainbowpizza, bluejay_32, Rootintootin, ismann, Davidzq, 1 invisible), 74 Guests and 286 Spiders online.
bluejay_32 161
a_d_a_m 106
Rainbowpizza 36
