#4080098 - 10/08/20 12:10 PM P0135 - O2 Sensor Fault B1S1
YoungP71dude Offline
Loc: Charlotte, NC
Hey y'all,
CEL came on yesterday. Had the guys over at Advance Auto run it and P0135 came back. AFAIK, Bank 1 Sensor 1 is the first passenger side O2 sensor. I know recently I took out and put back in the O2 sensors while reseating the exhaust. The engine doesn't run rough in any way. For now I just reset the battery (disconnect negative, wait, reconnect. This may not seem like a fix, but one time my Vic was running on a very low idle, a battery reset fixed it) to reset the sensors (ABS codes also came back, but I know why that happened; they just needed to be reset). So far it hasn't come back, but if it does, would anyone know why?
Thanks.
I give up on rewriting my signature. Please stop removing it, forum gods, it ain't that long.
I have an '04 P71 as my daily, another '04 P71 as my parts car/future race car project, an '86 LTD 2-Door I'm restoring, and my non-panther weekend car is an LS1 Camaro. So that's that.
Your only limit to modifying Panthers are your imagination, DIY skills, and wallet.
#4080108 - 10/08/20 02:56 PM Re: P0135 - O2 Sensor Fault B1S1 [Re: YoungP71dude]
Bellwestern80 Offline
CVN Discord: Edsel
Loc: Evans, Georgia
So P0135 is Oxygen Sensor Heater Circuit Malfunction.
Either the heating element inside the sensor isn't working well/at all or there's an actual issue on the heater circuit itself; so you may want to check that the circuit has power at the connector, and there's no damage to the harness.
How far have you driven since you disconnected the battery? It may have not been through enough drive cycles to code out.
My Cars:
#4080110 - 10/08/20 03:04 PM Re: P0135 - O2 Sensor Fault B1S1 [Re: YoungP71dude]
Loc: Charlotte, NC
Car hasn't left the driveway since then. Will most likely take it out this weekend and will see if the code comes back.
#4080224 - 10/09/20 03:34 PM Re: P0135 - O2 Sensor Fault B1S1 [Re: YoungP71dude]
Loc: Charlotte, NC
Drove it today, CEL came back on, assuming O2 sensor. What should I do? Replace it? No rough idle or poor performance.
Edited by YoungP71dude (10/09/20 05:51 PM)
#4080276 - 10/09/20 11:39 PM Re: P0135 - O2 Sensor Fault B1S1 [Re: YoungP71dude]
CVN Discord: Edsel
Loc: Evans, Georgia
If the heater element in it has failed, replacement is the only option unless you enjoy looking at the check engine light.
My Cars:
#4080304 - 10/10/20 08:46 AM Re: P0135 - O2 Sensor Fault B1S1 [Re: YoungP71dude]
Loc: Charlotte, NC
Alright. Will check connections and try switching sensors around to narrow it down to replacement.
#4080316 - 10/10/20 11:09 AM Re: P0135 - O2 Sensor Fault B1S1 [Re: YoungP71dude]
Loc: Charlotte, NC
Actually I found out why I was having the issue: the O2 sensor wasn't even plugged in. I'm a certified idiot.
