#4079996 - 10/07/20 08:27 AM Cranking but not starting
Wheezyalien Offline
Loc: Louisiana
Hey yall, first post here and I'm in need of some help. I've got a 2008 CVPI and a few days ago it was idling horribly and then stalled once put into gear. Since then it hasn't started. It'll crank and it sounds like it wants to start but no dice.
Things that I've tried:
Swapped fuel pump relay for known good one
Checked for engine codes (none)
Checked for spark
Plugs looked good
Tried removing intake and spraying starter fluid into intake
Power is getting to the injectors
Checked pump switch in trunk
I'm really stumped at this point. I have some images and videos that I'll post later on. Any help would appreciated.
White 2008 P71, 200k Miles (Bought in 2020 with 164k)
Former Louisiana State Trooper
Currently: 18" Mustang Rims, Sony XAV-AX3000 radio with backup camera, Lincoln Town Car center console, LED fog lights, Dynomax Race Bullets, 8" Skar 350W RMS subwoofer, 3.27 trac-lok
More to come (hopefully)
#4080008 - 10/07/20 12:30 PM Re: Cranking but not starting [Re: Wheezyalien]
Bellwestern80 Offline
CVN Discord: Edsel
Loc: Evans, Georgia
I'd check the fuel pressure at the rail and verify you've got something there.
Otherwise, maybe a failed crankshaft position sensor might be giving some grief. It's possible it hasn't set a code.
My Cars:
#4080026 - 10/07/20 03:36 PM Re: Cranking but not starting [Re: Wheezyalien]
professorP7B Offline
I agree with BellWestern. Since it was at least idling poorly to now not starting it almost sounds like it was struggling for fuel and now it can't get any. If the pressure is low it could be bad pump, clogged filter or clogged line. Or some power issue to the pump.
If you have spark the crank sensor isn't the issue. Also, it's good that the injectors have power, but is the ECU actually pulsing them on/off? You can use a noid light while cranking to check for this. The light should flash as the engine is cranked. If you've got spark and injector pulse it's definitely not a crank sensor.
Current vehicles:
The garage queen...
2011 GMC Sierra 1500 SLE
Purchased 2/23/17 w/57K
5.3L LC9 V8 4X4 Ext. Cab
The trusty steed...
2007 Toyota Matrix, AKA "Morpheus"
Purchased 12/11/21 w/187k
1.8L 1ZZ-FE I4, 5-speed manual
What if I told you...
#4080374 - 10/10/20 09:09 PM Re: Cranking but not starting [Re: Wheezyalien]
Wheezyalien Offline
Loc: Louisiana
Yall I feel really dumb. It was out of gas. I thought it was full but the fuel gauge is misreading/jumping around worse than i thought. I'm happy it isn't the pump but I guess my next move is to replace the fuel sending unit.
Thank yall for the help, I'm just slow.
#4080380 - 10/10/20 10:10 PM Re: Cranking but not starting [Re: Wheezyalien]
It was out of gas.
This is always my first thought, but I never mention it because people will often explode if you even suggest the possibility...
Still, glad it was an easy fix!
Current vehicles:
The garage queen...
The trusty steed...
#4080394 - 10/10/20 11:08 PM Re: Cranking but not starting [Re: Wheezyalien]
Wheezy, how many miles are on the car? If you're gonna remove the fuel pump assembly to get to the sender, might as well replace the whole thing and not get surprised later.
#4080420 - 10/11/20 12:03 AM Re: Cranking but not starting [Re: RF_Overlord]
Wheezyalien Offline
Loc: Louisiana
It currently has 167k on it. I'll probably hold off on it until I get the entire assembly, it's just a tough pill to swallow while still trying to save for other needed parts.
4 registered (akr619, cv83, webestang, Bangster), 119 Guests and 9 Spiders online.
