#4080824 - 10/15/20 10:14 PM Torque converter question
fenster Offline
Loc: Georgia
This week I've been working on a transmission swap. My car is a 2005 Crown Vic, and the transmission was removed from a 2005 Grand Marquis. The tag on the original transmission indicates a 10/2004 production and the tag on the replacement transmission indicates 04/2004 production.
My dilemma - The replacement has a larger torque converter. Assuming that both converters are in good condition, is it important that I use the larger or smaller?
#4080882 - 10/16/20 12:12 PM Re: Torque converter question [Re: fenster]
TheShadow Offline
Loc: SoCal High Desert
Considering what you found fluid-wise in the original tranny, I would stick with the 'new' TC that came with the replacement. The difference between the two will probably never be felt, or needed, by 95% of the people who drive these cars.
You'll never get all of the debris out of the old TC, and that's likely what did damage to the internals of the old tranny's internals.
#4080888 - 10/16/20 01:15 PM Re: Torque converter question [Re: fenster]
^^What he said. If it has a larger torque converter than what you had, then your car must be a P71. If that is the case, then you'll find the Grand Marquis transmission is actually shorter. You'll either need to use the steel GMQ driveshaft, or get a spacer for the pinion flange to use the aluminum driveshaft. You can use the aluminum driveshaft without a spacer but it doesn't leave very much spline contact at the transmission end so its not ideal. P71s and Town Cars (because they have a 3" longer wheelbase) use the longer output shaft so that they can use a shorter/lighter driveshaft while the rest used the shorter version. A lot of trucks also used both versions depending on wheelbase.
#4080942 - 10/16/20 08:19 PM Re: Torque converter question [Re: BigMerc96]
fenster Offline
Loc: Georgia
Good info, thanks to both of you. My car is actually an LX and the donor car a Grand Marquis, so I'm not sure why mine would have the smaller converter. Regardless, the fluid in both transmissions is clean enough that I don't have a fear of using either converter. I'll take some measurements on everything tomorrow and see what I have.
#4080944 - 10/16/20 08:28 PM Re: Torque converter question [Re: fenster]
Originally Posted By fenster
My car is actually an LX so I'm not sure why mine would have the smaller converter.
Maybe your car is a police impersonator... biggrin
#4080950 - 10/16/20 09:26 PM Re: Torque converter question [Re: RF_Overlord]
fenster Offline
Loc: Georgia
Just doing some reading, here's what I see:
- P74, so LX.
- Dual exhaust
- 3.27 axle code (Z5)
- Smaller (11.25" I guess) torque converter
This would seem to indicate the HPP model, though if I'm reading correctly HPP wasn't offered as a package in 2005, only as an LX Sport. This car doesn't have the rest of the LX Sport stuff like the floor shifter/console.
I'll upload some pics after I figure out how it works on this site.
Edited by fenster (10/16/20 09:41 PM)
#4080998 - 10/17/20 01:18 PM Re: Torque converter question [Re: fenster]
fenster Offline
Loc: Georgia
Both transmissions measured the same, so no issues so far. I just finished the dance of lining up the bellhousing and converter and got a few bolts in to lock everything in place. I'll get back at it after a lunch break.
2 registered (bobb, JackCrawford), 70 Guests and 104 Spiders online.
bluejay_32 102
Old_Guy_Stu 99
Dmblanch 73
a_d_a_m 59
GM_Guy 45
RF_Overlord 45
Moby_Vic 37
SocalSam 33
Ponyguy 33
Tenevic_P71 33
