#4085502 - 11/24/20 06:34 PM Cornering light
KeslerS Offline
Loc: Lexington, Kentucky
Thanks for reading this post.
My query is of a 1986 LTD CrownVic LX.
I have inherited this vehicle from my father & wish to maintain it as he would. It is near perfect.
The left cornering light is inoperative & I can’t find a replacement. Does anyone have information? Bulb suppliers & car parts shops are no help.
Also , should I use synthetic oil in my next oil change? 53000 miles! It is perfect!
Anything else to watch out for in this historic vehicle?
Thank you
Kesler
#4085530 - 11/24/20 08:48 PM Re: Cornering light [Re: KeslerS]
Bellwestern80 Offline
CVN Discord: Edsel
Loc: Evans, Georgia
Corner light is probably just a burnt out bulb. It should use a 1156 bulb.
Regarding oil, synthetic is fine. If it leaks any though, you may not want your money just dripping on the ground, but that's preference. 10W-30 is recommended as it goes.
My Cars:
#4085568 - 11/25/20 05:49 AM Re: Cornering light [Re: KeslerS]
Old_Guy_Stu Offline
Cornering light is an 1156, and it's the easiest bulb on the whole car. Socket is on top, twist it out, replace bulb, twist back in. Takes two minutes. I put LED's in mine for more light:
If a new bulb doesn't fix it, you could have a bad cornering lamp relay, and good luck finding one. Junkyard is your best bet (they're buried up under the dash). Same part for '79-91, all Panthers.
Use 5W-30 in winter, full synth for better flow at freezing temps. If you've got a leak, try adding a little brake fluid to the oil, it'll swell the seals maybe just enough.
Edited by Old_Guy_Stu (11/25/20 05:54 AM)
0 registered (), 38 Guests and 75 Spiders online.
bluejay_32 97
Armada Master 86
Old_Guy_Stu 74
Moby_Vic 59
Dmblanch 57
DudeAbides 48
a_d_a_m 47
SocalSam 43
Ponyguy 40
