#4071962 - 07/26/20 08:19 AM Tire pressure sensor
Nexuz21 Offline
Loc: Queens, NY
Hello guys, quick question about the tire pressure sensor, i switched out my steel wheels that came with my crown vic with 19in gt wheels and the tire sensor light comes on. Now if i want to add the sensor i have to purchase new ones but here is where i need the help. What part number is that? If anyone knows it would be appreciated. I did search inline but there are different kind of sensors that it gives me. I just want the ones that go with my CV 2010. Thanks
2010 Crown Vic
Stock specs
Changes= Intake Manifold, HIDs 10000k, EBC Sport Rotors, Hawk HPS Pads, 20% tinted Windows... More upgrades soon...
#4072536 - 07/31/20 11:14 PM Re: Tire pressure sensor [Re: Nexuz21]
2007CrownVic Offline
You can move the sensors from your old wheels over if you still have them and avoid buying new sensors but you need new straps.
They use the sensor that is held on the rim with a band not the kind that goes in the valve. You should be able to get the part number off tasca parts.
#4090076 - 01/04/21 12:43 AM Re: Tire pressure sensor [Re: Nexuz21]
CrystalPistol Offline
Loc: Shenandoah Valley
It's crazy what some will pay for a new clamp band. The old fashion worm drive screw clamp band will work fine and is reusable, cheap at under $4 or $5 each, and if you're worried about it loosening, apply a zip tie at the screw end. You are gonna stick the TPMS in place with a spot of adhesive so it's not gonna move around the wheel. If you call it a TPMS band, it'll be $40 each.
#4090102 - 01/04/21 12:28 PM Re: Tire pressure sensor [Re: Nexuz21]
85GT Offline
Loc: NYC
If you want new sensors, I leave my steelies as is for winter, I use these on both the aluminum explorer wheels and mustang wheels. They're the solid stem version. The rubber stem ones have included a speed limit warning on some of them. Probably the weight of the sensor hanging off the end.
VDO SE10001HP REDI-Sensor 314.9 MHz/315 MHz TPMS Sensor
And you want to pick up the training tool for learning the new sensors:
Motorcraft TPMS19
Edited by 85GT (01/04/21 12:32 PM)
08 CVPI
85 Mustang GT w/4R70W
91 Caprice
95 Caprice
Moderator:  RF_Overlord
3 registered (KMBT, GM_Guy, RF_Overlord), 139 Guests and 15 Spiders online.
Traffic22 15
