Page 2 of 2 < 1 2
#4091548 - 01/13/21 03:56 PM Re: Will a 2003 Marauder exhaust fit a 2000 Civi CV [Re: CrystalPistol]
PickledVic Offline
Loc: NYC
Originally Posted By CrystalPistol
Originally Posted By PickledVic
Called a shop below the Bronx and got a quote for 1200 for 409 SS exuast which didn't include install.
You have a stock Y pipe, all they need do is split it, run a pair of pipes to mufflers, then two simple tail pipes. Only SS you need is the new extensions ahead of the mufflers where temps are higher, and regular aluminized steel will last years even there. Tail pipes will be fine in the same aluminized steel.
When I did mine in 2001, I used a complete system from a '01 CV HPP but I cut the tail pipes right after the axle, removed and replaced both tail after that with aluminized steel, it show NO rust. I just painted it black. I still have the resonators in the basement. My old '77 F-150 gets new pipes every 10-15 years, but it sees snow, salt, mud, etc. $1200 is CRAZY ... plus this way you can easily go after the look you desire.
Yoooo, yours looks really clean!
Yeah for 1200 I might as well order it from Summit racing and that's with an H pipe and catback.
Btw, how many hangers are needed for each side?
https://www.ebay.com/itm/New-Exhaust-Han...4.m46890.l49292
Edited by PickledVic (01/13/21 03:57 PM)
2000 Crown Victoria Silver Gray
Current mods:
ROH rims (came with the car)
Tints
Spectre air filter
Throttle body spacer
KYB Gas Adjust Shocks
#4091612 - 01/13/21 09:12 PM Re: Will a 2003 Marauder exhaust fit a 2000 Civi CV [Re: PickledVic]
CrystalPistol Offline
Loc: Shenandoah Valley
Thank You. Car spends most days under a car cover under a carport, but it has been cross country, far south west a few times, down through the south a few, even Ohio, Pa too, but not in but maybe one snow.
Pretty standard is behind each muffler to support muffler weight and near each tip to support the tail pipe. It's very rare to need more.
My Mercury has factory hanger right behind each muffler (that's 2) and then I have one each side at the very rear, just ahead of my tips (2 more) so that's 4 total. That's all you should need. The ones at the rear of the mufflers have 2 rubbers each (rubbers) so I have 6 rubbers. Walker has some nice muffler end ones with two rubber straps each as I recall.
In your link, looks like a frame hook & rubber for one side tail pipe and the two rubbers that fit a factory muffle bracket that's bolted to the car and a extra rubber.
I'd wait until I saw what my system needs or comes with.
If you go to a muffler shop, they'll have their own universal hangers too, I've had them too on other cars & trucks, have them on my '77 F-150 now, they work. They support the weight and the shop guy will put them so pipes don't rattle against car parts like frame, axle, suspension ... or he should. He may bend some pipe, swell some pipe, may use pre-bent store bought pipe to.
Edited by CrystalPistol (01/13/21 09:29 PM)
2001 MGM, Addco, Bilstein, 17", RS-As, J-mod, Reese, AirLift, XM too.
#4091654 - 01/14/21 02:01 AM Re: Will a 2003 Marauder exhaust fit a 2000 Civi CV [Re: ClayBelt]
PickledVic Offline
Loc: NYC
Originally Posted By ClayBelt
Just go get one off a junkyard car. The marauder one is no doubt overpriced and will require midofication, junkyard is maybe $50 and a direct fit
I've called multiple junkyards here and they all tell me they either don't keep the exhausts or they're too damaged.
Current mods:
Tints
Spectre air filter
#4091738 - 01/14/21 01:07 PM Re: Will a 2003 Marauder exhaust fit a 2000 Civi CV [Re: PickledVic]
Was a time I went to a yard and there were several worn out or mildly wrecked PIs there being stripped.
I was gonna have a local muffler shop owner do my system on our then new 2001 MGM, but one day during spring break '02 out on I-81 was a light rain, crowded traffic, and ooodles of college kids heading home. Girl in new VW headed to NJ pitted a new 2001 CV HPP from SC with elderly gent and his wife, as she tried to change lanes at speed to get a few feet closer to NJ, she spun him and the CV hit the guard rail with all 4 corners as it spun. I worked the wreck, the CV was also toreador red, had just a few thousand miles, and had a wheel chair lift in the trunk for the lady's wheel chair.
No damage to the running gear or chassis, but the 4 corners and air bags were enough the insurance totaled the car. A buddy who did the towing told me after the salvage yard came to get it, or I would have paid the salvage $ and parked it here under a roof ... maybe? I drove my '77 PU to the salvage yard, got the exhaust from behind cats (cut) to rear, every bolt, hanger, etc, 4 lacy spoke alloys, 20 new lugs, 4 center caps, 4 like new GoodYear LSA tires, the spare steel wheel with that new LSA, the jack, and a few other little things for $300 ... and they set the whole exhaust in my truck as one piece after they used a heat wrench to cut CAs & shaft to remove the rear axle. They used a yard crane to lift the car up, they had it out in minutes. They even saved the hanger rubbers for me.
I was offered the rear axle whole for $75 more but I had no need for 3.55s. I should have took it too I guess, rotors and brakes worth that, maybe I'd have used it all. Was track lock too as I recall.
Edited by CrystalPistol (01/14/21 01:17 PM)
#4091762 - 01/14/21 03:18 PM Re: Will a 2003 Marauder exhaust fit a 2000 Civi CV [Re: PickledVic]
@ CrystalPistol: Man, I hate you guys from the South...more correctly I'm wicked jealous. What you got at the JY for $300 would have been at least double that up here in MA.
...and a whole rear axle for $75? In my dreams...try over $300.
#4091778 - 01/14/21 06:45 PM Re: Will a 2003 Marauder exhaust fit a 2000 Civi CV [Re: RF_Overlord]
Well, was in Spring of 2002, I haven't priced them lately. I also paid $125 for a 12 bolt with posi out of a '67 Chevelle in mid '70s, I put 4.10s in it and put under a '65 GTO. Lasted awhile. It broke bad enough to rip the cover open one night going from 2nd to 3rd, I put the OEM Pontiac 3.23 open rear back under it for awhile.
Page 2 of 2 < 1 2
1 registered (bluejay_32), 32 Guests and 220 Spiders online.
bluejay_32 184
CrystalPistol 152
a_d_a_m 131
DudeAbides 128
Old_Guy_Stu 120
Moby_Vic 90
ford05 65
Warped9 62
RF_Overlord 59
Ponyguy 59
