#4092276 - 01/18/21 04:11 PM
Re: What did you do to your panther today?
[Re: Spartan]
Cleaned the inside of my hood for the first time ever,looking at the new engine and it looks so good but the nasty hood just didn’t set well with me,got some purple cleaner stuff and got it looking really good,may even try and buff it out.
98 Marquis ultimate edition - Forged 4.6 2v w/Vortech v2 @ 14 pounds Max boost. 458 Rwhp and 441 FPT Currently own: 1979 f250 Camper Special w/460 4 Barrel stock 2003 Silverado 2500hd w/ 6.0 LQ4 stock
#4092596 - 01/21/21 03:47 PM
[Re: Spartan]
Picked up some stuff at Eastwood, unexpectedly found Shadow Blue interior dye  So now I can properly paint my console. Well, not now, now. When it's warm.
 1988 CVLX Formal Roof (Love Boat) POTM July 2019 & Aug 2020, 55K E-code lights w/ relays, LEDs w/ switchbacks, 15x8 Ansen slots w/ 255/60 BFG's, Kenwood stereo, various hacks. 1988 CVLX (Destroyer) 1998-2001 driven to death 202K 1988 Squire (Chris Craft) 1996-1998 junkyard rescue driven to death 199K
#4092660 - 01/21/21 08:49 PM
[Re: Spartan]
Loc: Shenandoah Valley
Checked the tire pressures, adjusted the car cover, and added light weight wind straps.
Toreador Red 2001 Mercury Grand Marquis ... with some minor mods .__________________________________ _________________. Though I live up here, I'm a natural borne "neandertal" ... with shots
#4092686 - 01/21/21 09:51 PM
[Re: Ponyguy]
Loc: Los Angeles, California
9.4 @78mph. Car wasn't hooking off the line properly. Something I gotta sort out.
'05 Crown Vic P71 SAP POTM Sept.'19 | Nov.'20 - Kenne Bell 2.1 Twin-Screw Supercharger @5PSI, Circle-D 265mm 2800-3000 stall converter, BCA built 4R75E, stock maf in 3.5 in tube, 36 lb Kenne Bell injectors, Aeromotive 340LPH fuel pump, EGR delete, ATI Super Damper, NGK BR7EF plugs gapped at .030, 170 t-stat, ADTR Coil Over System, ADTR Heinous Billet control arms, Ford Performance 3.73 Trac-Lok with carbon clutches, 17x9 widened steelies (rear) on Nitto NT555s 285/40/17, front stock steelies on NT555 245/45/17, StopTech rotors and Hawk HPS pads, braided steel brake lines, Stainless Works catback system with chambered mufflers and Marauder tips, GCC Special Edition trim. '03 Grand Marquis LS (daily) - Katzkin leather seats
#4092740 - 01/22/21 08:54 AM
[Re: Lundy05]
Not bad man,was u able to launch it at all?? yeah those roots blowers love smoking tires I never had slicks on my old NPI build but I went 81mph I believe in the 1/8th and my traction control was on and street tires,next pass I blew a water hose off,not good and embarrassing and never tempted to run again. Keep at it!!
#4092898 - 01/23/21 10:05 AM
[Re: Spartan]
Grocery run. My AC compressor isn't running, but it might just be too cold.
Downgraded the weekly fluid/bulb check to monthly, since washer fluid is the only one that goes down anymore.
#4092984 - 01/23/21 02:22 PM
[Re: Spartan]
Loc: Kansas
Fueled up on the 4th, drove it 2.5hrs home, drove it normally since then, noticed it was sitting at 1/2 a tank yesterday, filled it up with 89 octane.
***06 LTC Signature Limited, Silver Birch, 15 Year Old Maps, Movie Theater Audio, Hole-N-Roof, Seat Toaster, TheSunIsMyEnemy Windows ***POTM 06/18 - 10/18***  P.I. zip tube and airbox, Mo's tune, Mach 1 chin spoiler, 4 tone horns, 18" Mustang Premium wheels, UltraGauge, 20% Tint, J-mod, 03 Fogs ***00 Ford Explorer Eddie Bauer, 5.0 HO, AWD, Highly Optioned, J-mod, GlassPacks and "high flow" cats, Kenwood radio, UltraGauge, Spruce Green, 199k. The "Spruce Caboose"
#4092990 - 01/23/21 02:51 PM
[Re: GrumpMarky]
Checked the tire pressures, adjusted the car cover, and added light weight wind straps. Is it outside? It's in a car port that is usually facing away from windage, but occasionally currents somehow blow the cover up over the roof of the car ? The straps are very light weight and have plastic coated hooks that I hook to the wheel spokes ... and adjust just enough to keep the cover on it.
#4093032 - 01/23/21 10:00 PM
[Re: a_d_a_m]
Car warsh. As I've often told my sister who runs out of gas ... "It cost about near the same per mile to drive if you keep gas in it".
