#4095278 - 02/07/21 10:16 PM Gear whine after new ring and pinion
dixiebandit69 Offline
5.4 Club
Loc: Texas
Let me start off by saying: This is not for a Panther, but a 2013 F150.
Before anyone jumps down my throat, just pretend that I swapped a Ford 9.75" differential into my Grand Marquis.
As I said, it's a Ford 9.75" axle (Dana 60 clone).
The truck had 3.55s, and I got a set of 4.10s by SVL (a Dana aftermarket brand).
I installed all new pinion and carrier bearings (Koyo pinion bearings, Timken carrier bearings), and the installation specs are as follows:
Pinion preload: 25 in/lbs
Backlash: .012" (max allowable)
The whining is light, but it's definitely there. You can hear it during cruise (but not acceleration), but especially upon deceleration. If you've got the radio on, you wouldn't notice it, but I know this isn't right.
Here are some shots of the final patterns:
#4095292 - 02/08/21 01:38 AM Re: Gear whine after new ring and pinion [Re: dixiebandit69]
5.4 Club
Loc: Texas
Sorry, I couldn't get the pictures to load.
Here's drive:
https://i.imgur.com/IldDNI0.jpg
Coast side:
https://i.imgur.com/FXP9jWH.jpg
I wish I could post the actual pictures on here, but Imgur isn't letting me. Or this site isn't.
This site used to run a lot better before 2017...
#4095344 - 02/08/21 02:42 PM Re: Gear whine after new ring and pinion [Re: dixiebandit69]
MIHAYLA Offline
Loc: UA
Hard to say. I think pinion is too close.
MGM92
LTC05
#4095446 - 02/09/21 07:10 AM Re: Gear whine after new ring and pinion [Re: dixiebandit69]
Dixie, remember when the site was down for like 4 months a couple of years ago? That's when the picture attachment program broke and Vertical Scope has been unable or unwilling to fix it since then.
#4095488 - 02/09/21 12:19 PM Re: Gear whine after new ring and pinion [Re: MIHAYLA]
I second
comming back this fall
#4095612 - 02/09/21 07:20 PM Re: Gear whine after new ring and pinion [Re: RF_Overlord]
5.4 Club
Loc: Texas
Yeah, I remember... I also lost a bunch of my attached pictures on here.
Anyway, do y'all think that reducing pinion depth and resetting the backlash would get rid of the noise?
#4096110 - 02/11/21 10:03 PM Re: Gear whine after new ring and pinion [Re: dixiebandit69]
yes it should help .
#4096158 - 02/12/21 07:40 AM Re: Gear whine after new ring and pinion [Re: dixiebandit69]
BlackNFast Offline
It’s a Tricky thing to get right,kinda like Muddin drywall!!
We did my brothers 91 GT not long ago,had to take it out several times and repress again and again until we finally got it to hit right on the gears.Keep at it I think u are onto something.
98 Marquis ultimate edition - Forged 4.6 2v w/Vortech v2 @ 14 pounds Max boost.
458 Rwhp and 441 FPT
Currently own:
1979 f250 Camper Special w/460 4 Barrel stock
2003 Silverado 2500hd w/ 6.0 LQ4 stock
#4096300 - 02/12/21 07:23 PM Re: Gear whine after new ring and pinion [Re: dixiebandit69]
5.4 Club
Loc: Texas
Thanks for the input, guys.
After looking at the pictures, how much do y'all think I should reduce the depth?
I'm using a .027" shim right now; maybe take out .004"?
#4096372 - 02/13/21 08:25 AM Re: Gear whine after new ring and pinion [Re: dixiebandit69]
Yup smile
4 registered (gmerkt, 01boatman, smokeybandit2, TheShadow), 70 Guests and 108 Spiders online.
bluejay_32 108
Moby_Vic 74
JeffBoudah 74
Old_Guy_Stu 70
Armada Master 54
DudeAbides 50
Dmblanch 46
Ponyguy 43
SocalSam 40
